• Online: 709
benzsport
Star Diagnose, Xentry, Vediamo, Codierungen und Nachrüstungen für Mercedes
Mon Feb 20 14:12:01 CET 2017    |    benzsport    |    Kommentare (8)
Heute die Gelegenheit gehabt die Kalibrierung der Multifunktionskamera durchzuführen.
Ist relativ einfach.
Target ausrichten und Kalibrierung starten.
Nach ein paar Versuchen war es erfolgreich.
Kalibrierung wird nötig beim Tausch der Kamera.
Aber auch bei Fehlfunktionen kann eine Kalibrierung helfen.
Starten der Kalibrierung.
Hat Dir der Artikel gefallen?
Thu Feb 23 09:26:34 CET 2017    |    benzsport
Without calibration the camera don't work and make a fault.
This state don't change.
Your spam is not required.
Tue Feb 12 14:56:30 CET 2019    |    ralphkarim
Do you have the template of the calibration target, it's copied from the original MB calibration Target. is it printed on A4 paper? or it's larger than A4. Please state the dimensions of target, as am using a hand made target printed on A4 paper and the camera calibrated but the pitch angel is over allowed tolerance.
Regards
Tue Feb 12 15:02:28 CET 2019    |    ralphkarim
Sorry there is a miss translation on the last sentence, I meant i have calibrated my MFK by a target made on A4 paper but the pitch angel is over allowed tolerance. the Yaw and Roll angel is within the tolerance.
Thank you
Tue Feb 12 15:26:11 CET 2019    |    benzsport
You need a right target.
Sometimes camera is broken.
Try Steuergeräteprogrammierung and after calibration.
Tue Feb 12 15:34:26 CET 2019    |    ralphkarim
My Camera is good and working well except the pitch angel and its already calibrated, but i want to adjust the pitch angel to be within the accepted tolerance, for that am asking for the measurement of the target you have as it is copied from the original MB calibration target. So, if you have a copy of your target i will be thankful if you send it to me, or if you know the measurements it will fine also as am looking for the exact measurements of MB target.
Mon Oct 09 19:34:53 CEST 2023    |    JoachimT
Wo bekomme ich die Kalibrierhilfe? Gibt es die irgendwo als PDF?
Deine Antwort auf "Kalibrierung Multifunktionskamera W212 W218 W207 und neuer"
Kontak und Anfragen
Bekomme immer wieder Anfragen zu Anleitungen oder Support für die Software, sowas setzt das nötige Wissen vorraus.
An einem gegenseitigen Erfahrungsaustausch bin ich interessiert, jedoch muss dazu auch was zurückkommen.
Kontakt nur in Deutsch oder Englisch
Contact only german or english.
Bei Anfragen, bitte Fahrzeugtyp und Baujahr angeben, auch Ausstattung wie z.B. Comand oder Audio20, MPC usw.
Eine Angabe 1313 ist zeimlich sinnfrei weil es nur bedeutet das Mercedes der Hersteller ist.
Übersicht der Codierungen nach Modell
Alles zum AMG-Menü
Alles zur Schildererkennung
Alles zur RFK
Video in Motion
Alles zur Heckklappe
Firmwareupdate NTG 4.5 Silberdesign
Firmware KI Silber Design
CarPlay
Aufdecken Tachomanipulation
Gebrauchte Tachos
VIN Decoder (externer LINK)
Kontakt:
Per Whatsapp unter 01575/1749233 aber nur Whatsapp/SMS/Signal/Telegram oder per Email, imessage (benzsport@me.com) und Skype/WeChat (benzsport).
Kontakt am besten über Whatsapp oder Mail aber bitte nicht parallel, das ist unmöglich für mich dann zuzuordnen.
Dann bitte ich auch um Verständnis, das ich keine 24h Hotline bin.
Ich komme aus Berlin, bin aber gelegentlich in ganz Deutschland unterwegs.
Corona hat einiges durcheinander gebracht, auch bei mir sind viele Termine und Veranstaltungen abgesagt worden.
(Abgesagt) Anfang Dezember 2021 in Hamburg.
(Abgesagt) Ende Januar 2022 vorraussichtlich wieder Düsseldorf.
Sommer 2022 Rostock/Strahlsund/Stettin/Kühlungsborn/Lübeck/Wolfsburg und Dänemark/Schweden.
Termine sind fix.
Anfragen über die genannten Mail oder Nummer.
Die Bilder und Texte in meinem Blog sind mein geistiges Eigentum, eine Verwendung ohne meine Einwilligung ist untersagt.
SCN Codierung und Seed Keys
Bei mir ist es möglich nach Absprache SCN Codierungen zu machen und auch zum Codieren nötige Seed Keys zum entsperren der Steuergeräte zu erhalten.
Spezielle Files für Steuergeräte- Entriegelung, keine Seed Key Berechnung nötig.
SeedKey Generator auf Anfrage
Kann auch EEPROM Datensätze anpassen und überarbeiten.
OBD-Dongles zur Codierung des AMG-Menü IC222 (205), IC204 und IC172.
Ich richte aber keine Software zum Codieren ein oder gebe Anleitungen zum Vorgehen.
Mopf Tacho im 205 Vormopf
In Arbeit ist die Nachrüstung des Mopf-Voll-LCD Tacho in den Vormopf.
Hardware ist bestellt und eingetroffen. Ein Mopf AMG Voll-LCD. :D
Suche derzeit noch nach Schaltplänen und der Bestellnummer für den Stecker, der wurde geändert.
Angeblich hat sich auch einiges im Bussystem geändert, kann man aber nur probieren.
Neuigkeiten bald hier.
Phase 2: erster Test im 2015er 205
Phase 3 neuer Versuch, Software läuft fehlerlos!
Der Tacho vom W222 läuft fehlerfrei und passt nach einigen Modifikationen auch in das Amaturenbrett des W205 oder W253.
AMG Menü 205 253 447 222 217 213 238
EEPROM entschlüsselt.
Finale Phase.
Aktivierung in den Tachos von W205 S205 X253 W447 und W463 möglich.
Blogartikel
OBD Programmier-Adapter in Finaler Phase!
W222 W217 noch in Arbeit, Anpassung der verschieden Firmwareversionen. Finale Phase.
Blogartikel
AMG Menü im Mopf
IC213 Volle Funktion.
Blogartikel
AMG Menü läuft!!!
Blogartikel
IC213 Virgin möglich!
Blog Favoriten
Blog Ticker
Übersicht der Artikel im Monat
Blogleser (470)
