erste Erfahrung / Probefahrt mit dem 300de oder 300e
Hello guys, first of all sorry to open a new topic in English, but this is by far the biggest Europe car forum I found, and I find a lot of interesting discussions in here, however I have to use the google translator to understand them 🙄
I've always been a BMW fan, and owned several of them, I currently drive a 1M (as a daily).
3 months ago I ordered a G20 330e for myself as my next daily, but I saw that Mercedes recently released the C 300 de, and it made me think twice about if I made the right decision or not, even though I never owned a Mercedes before, the Mercedes has more power (306 hp) and it is faster, also it has a diesel engine which consumes a lot less fuel, and has a 66 liters fuel tank. I recently discovered that the 330e only has a 40 liter tank (!!), with a petrol engine I cannot see myself making more than 350 klms with a tank, which is very little, by contrast I believe that the Mercedes will do 1000 klms easy on a tank. If the BMW gasoline engine was an exciting one I wouldn't mind this too much, but the engine is not sporty or a very good one, so it makes me think that a diesel engine would be just as exciting and fun when driving faster. What is your opinion on this?
Also my question is, does any of you tried the C 300 de or even the E 300 de? How they drive? The BMW better be much better dynamically and much more fun, because otherwise I don't see anything in favour of the 330e compared to the C 300 de, other than looks and a bit more modern feel. I really hope I'm wrong about this though!
[Von Motor-Talk aus dem Thema 'BMW 330e vs Mercedes 300de' überführt.]
[Von Motor-Talk aus dem Thema 'C300de Erfahrungen/Lieferung/Bestellung/Dauer' überführt.]
Ihr führt das Konzept "Hybrid" ad absurdum.....
203 Antworten
Definitiv nicht .
Kann es deswegen ausschließen, weil ich lange hin- und herüberlegt habe...
Was nicht ging war Panoramaschiebedach in Verbindung mit Anhängerkupplung. Warum auch immer man das nicht zusammen bestellen kann..
Ich weiß nicht ob es beim 300e die Ausnahme gibt, aber beim 300de war Airmatic bei 19“ verpflichtend.
@BullZ47 schrieb am 27. Januar 2020 um 21:05:19 Uhr:
War bei meiner 300e Bestellung genauso (Vielspeiche, AMG-Ext.)
@ruuubbldiekatz schrieb am 27. Januar 2020 um 20:44:36 Uhr:
Definitiv nicht .
Kann es deswegen ausschließen, weil ich lange hin- und herüberlegt habe...Was nicht ging war Panoramaschiebedach in Verbindung mit Anhängerkupplung. Warum auch immer man das nicht zusammen bestellen kann..
Also was bei mir im August gegangen wäre war die „Anhängerkupplungsvorbereitung“, die komplette Anhängerkupplung ging nicht, ich denke mal das es eventuell mit dem Gewicht zu tun hat?!
Ich habe den 300e als T-Modell bestellt und hatte auch die Info mit ABC als Pflicht bei 19 Zoll erfahren.
Wusste jetzt nur nicht ob hier Limo und Kombi unterschieden werden.
@ruuubbldiekatz
deshalb mein Einwurf.
Aber wenn du ABC eh wolltest ist es ja egal, bzw. eine Fehlinfo deines Verkäufers.
18“ Winterreifen sind bei mir drauf von daher gehen bei ABC auch 18“
Grad nochmal im Konfigurator geschaut:
ABC mit 18“ geht auch, kann man auswählen.
Edit:
Gleiches beim 300de lt. Konfigurator
Meine Konfiguration M6RVJZML
300e mit ABC
Edit2:
Sorry-war ein langer Tag heute - ihr hattet Recht
19“ geht nur in Verbindung mit ABC
Wer lesen kann ist klar im Vorteil 😁
Bei den 19“ muss in der Konfiguration ABC dazu genommen werden.
Alternativ wenn man kein ABC-Fahrwerk will 18“ mit Winterbereifung bestellen und nach Auslieferung bei der NL gesondert die 19“ mit Sommerreifen bestellen.
Laut COC Papier spricht beim 300e / 300de nichts gegen ein nachträgliches Ausrüsten mit 19“ ohne ABC.
Mal ein Update zu meinen ersten Erfahrungen mit dem C300 de T. Die ersten 8 TKM waren prima. Bin absolut zufrieden mit Fahrleistungen und Ausstattung (volle Hütte) gewesen. Seit zwei Wochen steht das Fahrzeug allerdings bei Mercedes wg. Getriebestörung. Kein Gangwechsel möglich. Ersatzteile sollen Ende Februar kommen. Gibt es bei Euch ähnliche Erfahrungen?
@mgms schrieb am 30. Januar 2020 um 11:35:09 Uhr:
Gua, 6 Woche auf Ersatzteile warten?
Ich habe an dich eine Frage. Mein C300e blockiert das Ladenkabel beim Laden nicht. Wie sieht es bei dir.
@Igortsi schrieb am 30. Januar 2020 um 12:16:21 Uhr:
Mal ein Update zu meinen ersten Erfahrungen mit dem C300 de T. Die ersten 8 TKM waren prima. Bin absolut zufrieden mit Fahrleistungen und Ausstattung (volle Hütte) gewesen. Seit zwei Wochen steht das Fahrzeug allerdings bei Mercedes wg. Getriebestörung. Kein Gangwechsel möglich. Ersatzteile sollen Ende Februar kommen. Gibt es bei Euch ähnliche Erfahrungen?Ich habe an dich eine Frage. Mein C300e blockiert das Ladenkabel beim Laden nicht. Wie sieht es bei dir.
Ist bei mir kein Problem gewesen. Habe ich einige Male getestet.
@mgms schrieb am 30. Januar 2020 um 12:40:11 Uhr:
Danke!! Dann muss ich meine Werkstatt ansprechen.
Hab schon einige Male unseren C300de und c350 Hybrid angesteckt am Strom-beim Ladevorgang ist das Kabel blockiert und kann nicht gelöst werden.
