Werkstattaktion Rückrufaktion 170 PS PD-TDI Motor
VW Touran 1 (1T)
heute herausgefunden das es angeblich ein Rückrufaktion gibt in England für den 170 PS BMN Motoren.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006 1x Wiring loom adapter 03G 971 033 M 4x Adjustment screw WHT 000 530 5x M8x58 socket head bolt N 105 811 01 8x M6x88 socket head bolt 03G 103 385 A 4x Pump injectors
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Weisst euch ob das auch in Deutschland/der Schweiz dem Fall ist?
Habe am 30. Dezember mal wieder eine kaputte Pumpedüse gehabt, und das für die 2. Mal in 2011 und mir reicht das langsam. Beide Fälle auf den Autobahn und volle Familie drin, also super gefährlich.
Zusätzlich wäre es noch gut zu wissen ob die Probleme nun wirklich bestehen für den 073 D und 073 M Teilenummern oder auch für dein 073 TX. Weisst euch das?
Danke!!!
Dieser Brief ist ein Info der britischen VW Service Action 23H9 Piezo-Injektor-Pumpe.
Die Reparaturanleitung ist in Technische Produktinformation (TPI) Transaktionsnummer 2027647 enthaltenen
Dies gilt für 2.0TDI PD Golf, Passat, Touran und Piezo-Injektoren mit PD
Es gibt ungefähr 78.800 (Baujahre 2006 bis 2010) Betroffene Fahrzeuge in Großbritannien.
Besitzer erhalten Kommunikation von Volkswagen UK in mehreren Phasen.
Die folgenden Fahrzeuge mit Motor-Codes aufgeführt sind Betroffene.
Passat 3C 2006-2008 mit der BKP, BMA, BWV, ESO, BKP, ESO, BMA, BWV, MMR, und BUZ-Motoren
Golf 5 2006-2009 mit dem BMN-Engine
Touran 2006-2010 mit dem BMN-Engine
Technischer Hintergrund:
Bei einigen Fahrzeugen mit dem 2,0 l TDI-Motor können auf der Piezo-Injektor-Pumpe Partikel verbleiben, wegen verschmutztes Motoröl. Dies kann zu Problemen führen. Nicht alle Fahrzeuge sind von dieser Kampagne betroffen! Bei der Betroffene Fahrzeuge müssen die Piezo-Injektor Pumpenelemente überprüft und gegebenenfalls ausgetauscht werden.
Teile, die als Teil dieser Kampagne eingebaut werden:
1x Sticker-Kampagne 23H9 000 010 006
1x Kabelbaum Adapter 03G 971 033 M
4x WHT Stellschraube WHT 000 530
5x M8x58 Zylinderkopfschrauben N 105 811 01
8x M6x88 Zylinderkopfschrauben 03G 103 385 A
4x Pumpe-Düse
Anleitung:
Entferne Ventildeckel und überprüfen Sie die Teilenummer auf der Pumpe-Düse-Element. Alle Einspritzpumpen mit der Teilenummer "03G 130 073 D" oder "03G 130 073 M" müssen ersetzt werden. Alle anderen Einspritzpumpen sind korrekt und müssen nicht ersetzt werden.
162 weitere Antworten
162 Antworten
Original geschrieben von Ulysee1997
Hi Leute!
Ich war heute weg bei meinem Händler. Der hat ohne zu murren sofort die PD-Elemente gewächselt. Kostenlos da es sich um eine offizielle Rückrufaktion handelt. Hatte auch welche auf Lager.
Vorher wird nur geprüft ob schon mal einzelne ersetzt worden sind. Ist dies nicht geschehen werden alle 4 ersetzt. Sonst nur die noch nicht getauschten.
Kaputt gehen in den Elementen die Elektonik. So die Info des Mechanikers der die heute gewechselt hat.
Betroffen ist angeblich nur der TDI 125kw Motor. Nicht nur im Touran verbaut. So die Info des Meisters.
Letzte Woche bei 110kmh verbrauch von 6,5 bei Tempomat auf der Autobahn. Heute nach dem Tausch 5,0!
Ob das jetzt nur gefühlt weniger ist oder tatsächlich wird die Zeit zeigen.
Ein schönes Weekend
Hi
Seit dem wechsel meiner PD Elemente habe ich auch 1 - 1,5l weniger Verbrauch auf 100km.
Zudem auch mehr Leistung. Der Motor hatte 116tkm runter.
Also der kostenlose wechsel hat sich definitiv gelohnt.
Original geschrieben von SERC 10
Stehen die Motorkennbuchstaben in meinen Fahrzeugpapieren, oder nur auf irgendein Motorbauteil?
Gruß RC
Hi
Motorhaube öffnen
Motorabdeckung runterziehen
Wenn du auf die Zahnriemenverkleidung schaust siehst du einen Aufkleber
Dort steht der Motorkennbuchstabe drauf.
Christian
Gruß RC
Hi
Motorhaube öffnen
Christian
Alles klärchen, danke 😉
Habe heute in diesem Beitrag gelesen.
Hatten letztes Jahr im Juni (2012) bereits einen Schaden wg. der PD-Elemente auf der Autobahn mit Abschleppen durch ACE und Reparatur. Ein PD-Element wurde auf Garantie getauscht. Nun ist es anscheinend eine offizielle Rückrufaktion geworden (ohne großes öffentliches Aufsehen).
Habe jetzt einen Termin für die Überprüfung beim VW-Händler vereinbart. Bin gespannt, was am nächsten Mittwoch dabei herauskommt.
Werde hier darüber berichten.
Vielen Dank an alle, die dies im Forum aufgegriffen und veröffentlicht haben.
hans-wolfgang1951
habe vor einigen Tagen auf der VW-HP noch die anstehende Aktion bestätigt bekommen( BMN-Motor) und nun sagt die HP keine anstehenden Aktionen. Seltsam.
Herbert
Kann hier eigentlich jemand definitiv bestätigen, dass es eine offizielle Rückrufaktion gibt diesbezüglich?
Ein Freund von mir bekommt die Teile nicht gewechselt, weil keine Fehler mit dem Diagnosegerät auszulesen waren.
Gruß RC
Ich kann dir definitiv bestätigen das es
keine Rückrufaktion
ist. Man sollte sich mal schlau machen was eine Rückrufaktion ist, welche Gründe und Bedingungen dafür vorliegen müssen, dann wäre es einfacher.
Alles andere zu dieser Werkstattaktion ist hier schon gesagt und mit Dokumenten belegt worden.
Ich hab kommende Woche einen Termin.
Ist auch kostenfrei, trotz 160.000KM, da es eine Rückrufaktion für gewisse Düsen ist.
Allerdings auch nur diese Düsen, alle anderen sind nicht betroffen.
Na dann schreiben wir halt richtiger "Werkstattüberprüfungsaktion" und nicht "Rückrufaktion" von VW....
hans-wolfgang1951
Ich kann dir definitiv bestätigen das es keine Rückrufaktion ist. Man sollte sich mal schlau machen was eine Rückrufaktion ist, welche Gründe und Bedingungen dafür vorliegen müssen, dann wäre es einfacher.
Gruß RC
Heute wurden bei mir alle vier Elemente gewechselt ohne einen Cent !!!!!!!!! Meine Frau und mein Kind sind gestern auf der Autobahn fast ums Leben gekommen!!!!!!!!!!Auto durch Defektes PD Element einfach ausgegangen!!!!!Auf der Autobahn!!!!Was denkt sich VW dabei???????Wagen wurde sofort ohne Diskussion repariert. Was wäre gewesen wenn meine Familie jetzt durch Auffahrunfall Tod wäre??????
Vw macht es heimlich!!!!! Die Japaner haben Charakter und rufen Tausende zurück!!!!!!!!!!Scheiß aufs Geld. vw schämt Euch!!!!!!!!!!!!!
Übrigens fahre ich einen Passat!,,,betrifft alle Motoren dieser Baureihen -Garantiert!!!
Last Euch den Diagnosebericht aushändigen!!!!!!!!!!
Zum Glück übertreibst du nicht maßlos....🙄🙄🙄🙄
Hallole ...
Denke , diese Aktion ist VAG - übergreifend .
Z.B. die °°°° A3 's bekommen auch frische Düsen .
http://www.motor-talk.de/.../...pruefung-der-pd-elemente-t4367461.html
... nach X Jahren des Leidens endlich eine Lösung bei den Piezo - PDE's der BMN - Motoren 😰
Hermy
Danach fragt keiner mehr was war--oder????
