Werkstattaktion Rückrufaktion 170 PS PD-TDI Motor
VW Touran 1 (1T)
heute herausgefunden das es angeblich ein Rückrufaktion gibt in England für den 170 PS BMN Motoren.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006 1x Wiring loom adapter 03G 971 033 M 4x Adjustment screw WHT 000 530 5x M8x58 socket head bolt N 105 811 01 8x M6x88 socket head bolt 03G 103 385 A 4x Pump injectors
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Weisst euch ob das auch in Deutschland/der Schweiz dem Fall ist?
Habe am 30. Dezember mal wieder eine kaputte Pumpedüse gehabt, und das für die 2. Mal in 2011 und mir reicht das langsam. Beide Fälle auf den Autobahn und volle Familie drin, also super gefährlich.
Zusätzlich wäre es noch gut zu wissen ob die Probleme nun wirklich bestehen für den 073 D und 073 M Teilenummern oder auch für dein 073 TX. Weisst euch das?
Danke!!!
Dieser Brief ist ein Info der britischen VW Service Action 23H9 Piezo-Injektor-Pumpe.
Die Reparaturanleitung ist in Technische Produktinformation (TPI) Transaktionsnummer 2027647 enthaltenen
Dies gilt für 2.0TDI PD Golf, Passat, Touran und Piezo-Injektoren mit PD
Es gibt ungefähr 78.800 (Baujahre 2006 bis 2010) Betroffene Fahrzeuge in Großbritannien.
Besitzer erhalten Kommunikation von Volkswagen UK in mehreren Phasen.
Die folgenden Fahrzeuge mit Motor-Codes aufgeführt sind Betroffene.
Passat 3C 2006-2008 mit der BKP, BMA, BWV, ESO, BKP, ESO, BMA, BWV, MMR, und BUZ-Motoren
Golf 5 2006-2009 mit dem BMN-Engine
Touran 2006-2010 mit dem BMN-Engine
Technischer Hintergrund:
Bei einigen Fahrzeugen mit dem 2,0 l TDI-Motor können auf der Piezo-Injektor-Pumpe Partikel verbleiben, wegen verschmutztes Motoröl. Dies kann zu Problemen führen. Nicht alle Fahrzeuge sind von dieser Kampagne betroffen! Bei der Betroffene Fahrzeuge müssen die Piezo-Injektor Pumpenelemente überprüft und gegebenenfalls ausgetauscht werden.
Teile, die als Teil dieser Kampagne eingebaut werden:
1x Sticker-Kampagne 23H9 000 010 006
1x Kabelbaum Adapter 03G 971 033 M
4x WHT Stellschraube WHT 000 530
5x M8x58 Zylinderkopfschrauben N 105 811 01
8x M6x88 Zylinderkopfschrauben 03G 103 385 A
4x Pumpe-Düse
Anleitung:
Entferne Ventildeckel und überprüfen Sie die Teilenummer auf der Pumpe-Düse-Element. Alle Einspritzpumpen mit der Teilenummer "03G 130 073 D" oder "03G 130 073 M" müssen ersetzt werden. Alle anderen Einspritzpumpen sind korrekt und müssen nicht ersetzt werden.
162 weitere Antworten
162 Antworten
Wenn das Fahrzeug in den letzten Jahren regelmäßig bei VW war kannst du davon ausgehen das die Aktion gemacht wurde wenn sie fällig war.
Macht der 🙂 nämlich eine fällige Aktion nicht mit während eines Werkstattaufenthaltes bekommt er von VW in kürzester Zeit die Erinnerung dies schnellstens nachzuholen 😉.
Hallo, mein Touran 1t2 ist BJ 09/07, MKB:BMN
Ich vermute langsam das ich auch pd Probleme habe, er springt zur Zeit sehr schlecht an, ruckelt ab und zu während der Fahrt deutlich.
Habe aktuell 150.000 km drauf, bis wann ist diese Rückrufaktion gültig? Mittlerweile sind ja auch einige Jahre vergangen, kenne mich in der Materie schlecht aus, habe den Touran jetzt seid 3 Monaten und 12.000 km gefahren.
Hallo Touran1T2,
fahr doch mal bei VW vorbei und frag deinen :-) unter Angabe deiner FG.-Nr ob die Aktion schon
durchgeführt wurde. Der Aktionszeitraum ist schon lange überschritten.
Umfang waren damals Austausch aller Injektoren sowie der Kabelbaum im Zylinderkopf.
Mithilfe der Wartungshistorie kann dir dein 🙂 sagen, ob diese Aktion (23H9) gemacht wurde.
Hallo zusammen
Fahrzeugdaten:
VW GOLF 5 GT 2.0 TDI 125kw / 170PS
Schlüsselnummer: 0603 / ADT
Erstzulassung: 04.05.2007
Fahrgestellnummer: WVWZZZ1KZ7W247418
Motor: BMN
Getriebe: JMA
Seit 1 Monat im Besitz !!
Ist jetzt vielleicht schon lange her die Aktion,aber würde gerne die PD-Elemente auch beheben lassen, falls dies noch nicht geschehen ist.
Möchte sie aus Prinzip unbedingt gewechselt haben um das Gewissen zu beruhigen.
Nur weiß jetzt nicht ob sie schon gewechselt wurden sind oder nicht !!
Wie gehe ich da am besten vor ??
Hast du schon im Serviceplan geschaut ob es dort einen Eintrag zur Aktion gibt oder ob der Aufkleber dafür im Kofferraum ist?
Bei mir z.B ist im Serviceplan leider nichts zu finden. Auch im Kofferraum nichts
In der Wartungshistorie ist es jedoch vermerkt.
Man kann beim VW Autohaus danach fragen.
Die werden es Dir zeigen, aber ausdrucken dürfen die es normalerweise nicht
Habe jetzt gerade im Kofferraum und im Serviceheft nachgeschaut und folgendes entdeckt !!
Heißt das alle 4 wurden komplett gewechselt und ich brauche mir jetzt keine Sorgen mehr zu machen oder irgendwie nachzuhaken ?
Das heisst es wurden alle geprüft und alle alten ersetzt, wenn zu dem Zeitpunkt halt noch alle alt waren gab es 4 neue.
Kann ich bei dem Autohaus die Reparatur Daten-Historie des Fahrzeugs anfordern ?
Du kannst sie dir mit dem Mitarbeiter ansehen, aber ausdrucken dürfen die es aus Datenschutzgründen nicht.
Moin
Mein Audi A4 B7 2.0 TDI 170 PS
Hat ebenfalls die genannten PD Elemente drin.
Und sie machen bereits auch die Probleme wie ihr schreibt lauft schlecht wenig Leistung.
Hab aber 210k runter denkt ihr das ist egal?
