Feldaktion 23H9 - Tausch aller anfälligen PPD Elemente in England
Ich bin gestern über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil.
This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector
elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open
campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is
attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been
performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part
number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war gestern schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung
warum diese Feldaktion nicht auch für Deutschland gilt.
Quelle : http://vagdrivers.net/forums/index.php?showtopic=74194
Juhu, die Feldaktion ist nun (seit dem 14.01.2013) auch für Deutschland gültig.
Wer wissen will ob sein PPD davon betroffen ist kann das hier anhand der FIN prüfen.
163 Antworten
Hallo an alle,
habe gerade unter volkswagen.de mal meinen Touran gecheckt, die Feldaktion 23H9
ist nun auch für D gültig.
Werde bekloppt...meiner ist auch davon betroffen...hatte schon mal ein defektes PD-Element gehabt...dann mal schnell kontakt aufnehmen mit VW 😁
Komisch nur das ich Motorbuchstaben BFF habe...
Servus,
mein Touran ist auch dabei. Ist nach dem Austausch eine Veränderung der Fahreigenschaften/des Verbrauchs spürbar? Oft merkt man ja gar nicht, wenn der Wagen schleichend an Spritzigkeit verliert (bzw. man gewöhnt sich, wie bei dem Stoßdämpferverschleiß, daran).
Gruß,
1T19E
Du wirst dich wundern =)
Jetzt machst Du mich neugierig 😉 Inwiefern, ist der Unterschied soooo drastisch spürbar?
Wenn du ein schleichenden Leistungsverlust nicht spührst, spührst du die zeitnahe Wiederherstellung. Angenommen du hast nur noch 150PS, dann merkst du das, wenn er wieder 170PS hast.
Beim 140ps BKP wird das natürlich nicht so extrem sein, da du da vielleicht eine Verlustleistung von maximal 20ps haben wirst. dennoch wird der Verbrauch wieder etwas sinken. Schon allein, weil die Düsen neu abgedichtet werden.
Ich habe den Unterschied ganz schön bemerkt,
wenn man jetzt Gas gibt, kommt er wieder wie Thors Hammer, der Verbrauch
auf AB Langstrecke ist um knapp 2l/100km gesunken.
Macht jetzt wieder richtig gaudi
LG
Swen
Mal sehen wie lange das hält.
He Shanny, nicht immer so pessimistisch sein 😉
Wir wollen mal hoffen das durch diese Aktion 23H9 die Zuverlässigkeit der Motoren weiter gesteigert wird 🙂
So hab ein Termin am Montag für u.a 23H9. Es ist ja erst mal eine Kontrolle ob mein Fahrzeug davon betroffen ist. Mal sehen ob meine PD Elemente getauscht werden müssen.
Mein Touran hat einen 170 PS "BMN"-Motor. Jetzt bin ich wirklich mal gespannt wie ein Flitzebogen. Leistungstechnisch habe ich eigentlich nie etwas vermisst, fahre aber ehrlich gesagt auch nicht wirklich "scharf" 😉
Ja,meiner fällt auch in diese Aktion! Mal sehen wie viel € der Spaß kosten soll😕
Ich gehe davon aus, dass eine Rückrufaktion für den Kunden gratis ist. Die gesamten Kosten werden von VW getragen. Das Autohaus wird mir dann noch ein Ersatzauto für einen Tag bereitstellen. Am Freitag kann ich dann berichten.
Habe Rücksprache mit VW gehalten und die Feldaktion ist für den Kunden kostenlos!
Mein Passat hat am Mittwoch auch einen Wechseltermin. Dann mal schauen was es bringt, denn aktuell hat er 51000km runter hat bei 140km/h einen Verbrauch von um die 7 Liter.
