Feldaktion 23H9 - Tausch aller anfälligen PPD Elemente in England
Ich bin gestern über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil.
This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector
elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open
campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is
attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been
performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part
number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war gestern schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung
warum diese Feldaktion nicht auch für Deutschland gilt.
Quelle : http://vagdrivers.net/forums/index.php?showtopic=74194
Juhu, die Feldaktion ist nun (seit dem 14.01.2013) auch für Deutschland gültig.
Wer wissen will ob sein PPD davon betroffen ist kann das hier anhand der FIN prüfen.
163 Antworten
Hallo ich habe jetzt auch Post vom Freundlichen bekommen wegen der Aktion 23H9, habe ihn gestern wieder abgeholt und bin jetzt stolzer Besitzer von 4 neuen PD Elementen und einen neuen Kabelbaum kostenlos natürlich. Mein Passat ist Baujahr 01/2006 und hat schon 246000 auf der Uhr. Ich habe Anfang des Jahres schon ein PD Element wechseln müssen weil der Passat leider ausgefallen ist, jetzt habe ich 4 neue.
Servus,
war die letzte Woche mit einem BMN Touran (BJ 2008 145000km) beim Freundlichen wegen der Werkstattaktion 23H9. Er ist nicht betroffen, also wurde auch nichts gewechselt. Wenn er betroffen gewesen wäre, hätte VW die Kosten übernommen so der aktuelle Stand.
grüße
Shakrat
Wenn die Dir 4 neue PD's eingebaut haben, bist Du beschissen worden. Da gehören PPD-Elemente rein! 😁
Brain
PD-Element = Pumpe-Düse-Element (allgemein und damit egal ob Piezo- oder Magnet-Aktuator).
Nur beim Einbau von Magnetventil-PD-Elementen würde ich mir Gedanken machen
Und ich gehe stark davon aus das nur noch drei neu verbaut worden ist. Weil einer noch gar nicht so alt ist und somit auch Index T hat.
erstmal frohes Neues Jahr!
Ich möchte diesen Treath nochmal aktualisieren.
Habe meinen Passat Bj.02/2008 mit 170 PS BMR zur Inspektion abgegeben wollen. Dabei wurde auch bei mir, die Pumpe-Düse-Elemente überprüft und alle 4 erneuert! Ich bin begeistert, das VW selbst noch bei einen 7 Jahre alten Auto eine 100% Kostenübernahme macht, obwohl über die Garantiezeit und einer Laufleistung von gut 85Tkm kein Fehler auftrat! Daumen hoch sag ich da nur!
Ist ein Rückruf, ganz offiziell! So mit spielt das alles keine Geige mehr (vom KBA durch Brüssel EU verordnet)! Alle bei denen nicht 23H9 gemacht wurde, machen VW heist es.
Hi Leute,
weiß einer von euch wo der Unterschied zwischen der Aktion 23H9 Kr.1 und 23H9 Kr.2 liegt? Ich bin im Serviceheft eines potentiellen Fahrzeuges auf die "Kr.2" gestoßen und kann damit nicht wirklich etwas anfangen.
Würde mich freuen, wenn einer von euch dazu etwas weiß.
grüße T-mak
Hängt mit dem 140 PS PPD und den 170PS PPD zusammen
Welcher 140ps hat denn PPD?
@The_sentinel2 schrieb am 6. Januar 2016 um 19:40:41 Uhr:
BKP
Schade.
Leute ich weiß uralter Tread hänge mich trotzdem nochmal ran.
Mich hat es jetzt wohl auch erwischt.
Passat 2.0 tdi, Bj 04/2006, 135000 km.
Springt nur noch selten an, und wenn läuft er nicht mehr so toll.
Nach einiger Recherche ahh 23h9 gab es ja mal für den BMN Motor.
Also auf nach VW nachfragen.
Gesagt getan Aussage zweier VW Händlern in meiner Nähe mein Passat war nie betroffen.
Komisch das Netz sagt was anderes.
Vielleicht kann mir das hier jemand erklären, oder sogar Tips geben wie ich das Update trotz das es ausgelaufen ist doch noch bekommen kann.
Möchte ungern in den saueren Apfel beißen und die 2600 Euro bezahlen.
Also her mit euren Meinungen.
Das ist korrekt, dass es sowas gibt für den BMR und BKP Motor beim Passat.
23H9 gibt es aber leider nicht mehr.
