Feldaktion 23H9 - Tausch aller anfälligen PPD Elemente in England
VW Passat
Ich bin gestern über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil.
This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector
elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open
campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is
attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been
performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part
number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war gestern schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung
warum diese Feldaktion nicht auch für Deutschland gilt.
Quelle : http://vagdrivers.net/forums/index.php?showtopic=74194
Campainsticker
Faultypiezoinjectors
Juhu, die Feldaktion ist nun (seit dem 14.01.2013) auch für Deutschland gültig.
Wer wissen will ob sein PPD davon betroffen ist kann das hier anhand der FIN prüfen.
163 weitere Antworten
163 Antworten
Original geschrieben von Masterfrost
Mein Passat hat am Mittwoch auch einen Wechseltermin. Dann mal schauen was es bringt, denn aktuell hat er 51000km runter hat bei 140km/h einen Verbrauch von um die 7 Liter.
den Verbrauch habe ich auch!
Da liegt meiner auch!Schon immer, auch nocht mit vier alten.
Ich hätte gedacht, dass ein Handschalter etwas weniger Sprit braucht.
Halloo
so ich bin letztes Jahr im Juli mit defekten Elementen auf der Autobahn ausgerollt und habe dann vorsichtshalber alle 4 tauschen lassen.
Damals keine Übernahme seitens VW.
Gestern nachgeschaut auch meiner fällt unter die Aktion.
Hab mich gleich mit VW in Verbindung gesetzt aber im nachhinein nichts mehr zu machen.
Allerdings hielten meine Elemente 210000km (Tachostand als er ausrollte: 210001 km)
zum Thema Verbrauch meiner nimmt 6,2l/100km und ich fahr schon zügig.
Aber ich ärgere mich jetzt doch sehr das ich da 1400Euro ausgegeben hab und jetzt würde es nichts mehr kosten.
Im Dezember brauchte ich ne neue Kupplung wobei nur das ZMS sehr großes Spiel hatte und die Druckplatte defekt war.
Da kommt jetzt bestimmt in nem halben Jahr auch ne Rückrufaktion 🙂
Gruß Abi
So heute mit dem Autohaus telefoniert bei mir werden tatsächlich 3 PD - Elemente erneuert. 1 war ja schon mal defekt gewesen. Dann hoffe ich mal stark das ich erst mal ruhe habe mit dem Thema. 🙂
So meiner ist heute bei VW wegen der Aktion und wegen der spinnenden Aussentemperaturanzeige.
Laut Meister wird geschaut welche PPD-Elemente verbaut sind, und wenn die in der Aktion sind werden Sie getauscht...
Schauen wir mal...
Schauen wir mal...
Dido 😉
Ich habe meinen auch heute morgen zur Aktion abgegeben.
Bin mal gespannt 🙄
hatte meinen letzte Woche zum Tausch weil er nicht mehr ansprang. Kann nur sagen das es ein perfekter Service war vom Reinschleppen bis zur Abholung. Er läuft wieder super. Ein Dank ans Autohaus.
Gruß Emmel
Gerade kam der Anruf vom 🙂 es wurden alle vier PPD Elemente ausgetauscht 😁 😁 Yeah 😁
Mal schauen in wie fern sich das Fahrverhalten und der Verbrauch sich jetzt geändert haben.
Beim Topspeed würdest (wegen Wetterlage) merken und wenn du jetzt den Lamdawert logst, merkst es auch! Sonst eigendlich weniger. Eventuell noch am Kaltstartverhalten.
Habe meinen vorhin abgeholt mit 4 neuen Injektoren. Kaltstartverhalten ist definitiv besser, Verbrauch kann ich erst im Februar sagen, dann ist wieder lange Tour angesagt. Aber auf jeden Fall wurde der Wagen sehr gut von innen und außen gereinigt mit Wachs und Politur. :-D
Wow, innen und außen auch noch gereinigt!!!
Das wurde heute bei meinem nach der Aktion leider nicht vom 🙂 gemacht 🙁 naja....
Ausser einen Stempel im Scheckheft habe ich nichts weiter bekommen. Habt ihr noch vielleicht etwas bei der Abholung, so wie eine Art Rechnung bekommen?
Eine Außenwäsche ist ja auch nicht unbedingt empfehlenswert bei derzeitigen Außentemperaturen... Wenn man da keine beheizte Garage hat um ihn sofort da reinzustellen, dann kann man schon mal ne böse Überraschung am nächsten Tag haben... 😉
Warum, oder weil er dann wieder schmutzig ist?
Brain
Zu früh gefreut, ich konnte heute morgen wieder zum Freundlichen fahren, massiver Ölverlust am Ventildeckel 😠 !!!!
Oh man.....
