Feldaktion 23H9 - Tausch aller anfälligen PPD Elemente in England
Ich bin gestern über folgende interessante Neuigkeit gestolpert, welche ich Euch auf keinen Fall vorenthalten möchte.
Volkswagen lässt in England alle anfälligen PPD Elemente mit einer Feldaktion (23H9) tauschen.
(Seit dem 01.10.2010 gibt es nämlich überarbeitete PPD Elemente!)
Hier ein Auszug aus dem Anschreiben.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil.
This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector
elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open
campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
If the vehicle is listed in the system as not completed, check whether a campaign sticker with the entry "23H9 date/stamp" is
attached in the spare wheel well area (next to data sticker):If the campaign sticker is attached, the campaign has already been
performed. Make the entry “23H9 date/stamp” in the service schedule under “Space for workshop entries”.
If the campaign sticker with entry "23H9" is not fitted, carry out the work according to the repair instructions.
Identifying the potentially faulty injectors.
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part
number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Ich war gestern schon mal so nett und habe Autobild sowie das KBA informiert, mit der bitte um Klärung
warum diese Feldaktion nicht auch für Deutschland gilt.
Quelle : http://vagdrivers.net/forums/index.php?showtopic=74194
Juhu, die Feldaktion ist nun (seit dem 14.01.2013) auch für Deutschland gültig.
Wer wissen will ob sein PPD davon betroffen ist kann das hier anhand der FIN prüfen.
163 Antworten
Gestern kam der Anruf vom freundlichen.... Hallo Ihr Auto ist abholbereit.
Der ADAC hatte ihn zum Feiertag auf den Hof vom ;-) gestellt.. und der freundliche hat ihn direkt am 2 . Mai dran genommen... Es waren natürlich die 2 alten PPD Elemente... Austausch auf 100 % Kulanz.. Auto ist Bj. 09/06 mit 135.000 KM...!!! Cool... Jetzt geht er wieder voll ab... und durch die neuen PPD´s solls jetzt mal länger halten...!! Mal schauen...!!
So nach knapp 3 Monaten hat Volkwwagen auf meine E-Mail geantwortet.
Sehr geehrter Herr *****,
vielen Dank fuer Ihre E-Mail. Entschuldigen Sie bitte, dass wir uns erst heute bei Ihnen melden.
Sie fragen uns, warum es nur in Grossbritannien eine Serviceaktion zum Austausch der Pumpe Duese-Elemente gibt.
Gestatten Sie uns dazu einige Hinweise: Die in Grossbritannien durchgefuehrte Serviceaktion zu diesem Thema erfolgt anhand umfangreicher Recherchen und Reaktionen am Markt in Abstimmung mit den dortigen Behoerden. Solche Serviceaktionen sind jedoch immer an einen bestimmten Markt gebunden. Aus diesem Grund gibt es fuer den deutschen Markt nicht automatisch dieselben Serviceaktionen wie in anderen europaeischen Laendern. Wir bitten um Ihr Verstaendnis.
Sehr geehrter Herr *****, wir hoffen dass diese Informationen hilfreich fuer Sie sind und wuenschen Ihnen fuer die Zukunft alles Gute.
Mit freundlichen Gruessen
i. V. ******Volkswagen AG
38436 Wolfsburg
Fazit:
Nur wenn Papa Staat Druck macht wird etwas unternommen!
Demnach wird VW die 7 Jahre aussitzen und keine verbesserte Version einbauen?
Doch es gibt ja mittlerweile (seit Oktober 2010) verbesserte Elemente.
Defekte Elemente werden gegen die neuen Elemente getauscht.
In England werden aber alle alten Elemente gegen die neuen getauscht.
Da interessiert mich doch jetzt: was passiert, wenn ich mit meinem Wagen dort drüben liegenbleibe?
...dann wird dein Wagen nach Deutschland überführt 😁
Also ich kenne es vom E250CDI so, dass die Instandsetzung vor Ort erfolgte... da gabs aber keine Feldaktionen von MB... Gab nen Land Rover als Leihwagen, war sonst nichts mit AHK verfügbar und am Folgetag den Wagen wieder...
Daher frag ich mihc nu, ob man unter die Feldaktion fällt..
Also ich kenne es vom E250CDI so, dass die Instandsetzung vor Ort erfolgte... da gabs aber keine Feldaktionen von MB... Gab nen Land Rover als Leihwagen, war sonst nichts mit AHK verfügbar und am Folgetag den Wagen wieder...Daher frag ich mihc nu, ob man unter die Feldaktion fällt..
Die Feldaktion ist ja an der Fahrgestellnummer festgemacht und dementsprechend für die für den englischen Markt bestimmten Fahrzeuge.
Einzige Möglichkeit würde sein das man im Besitz eines solchen Fahrzeuges ist , aber dann sollte es aufgefallen sein das das Lenkrad auf der falschen (richtigen !?) Seite verbaut ist 😉
Original geschrieben von joemecanic
Die Feldaktion ist ja an der Fahrgestellnummer festgemacht und dementsprechend für die für den englischen Markt bestimmten Fahrzeuge.Zitat:
Hallo, in Italien ist die Aktion soeben unter der selben Nummer angelaufen.
... dann wird es ja langsam Zeit, dass AutoBild bei VW bzgl. des deutschen (für VW angesichts der hier verkauften Stückzahlen des 3c um ein Vielfaches teureren) Markts nachfragt?
Wir werden eingekreist! Gibt es dazu was Schriftliches?
Brain
Sorry, betrifft in meinem Falle aber den Touran.. Ist jedoch der selbe Motor wie im Passat und sollte deshalb in dieser Hinsicht keinen unterschied machen.
Siehe auch Link im Touran Forum:
http://www.motor-talk.de/.../...-170-ps-pd-tdi-motor-t3676050.html?...
Ich bin die nächsten Tage mal beim Freundlichen vorstellig und checke mal die Sachlage.
Wie gesagt. 23H9 ist nur die Prüfung! Erst danach werden die Injektoren und der Kabelbaum gegebenenfalls getauscht. Weis jemand, wieviele Injektoren VW vorgeordert hat? Sonst gibt es bestimmt einen ordentlich Rep.-Stau.
Brain
Meiner ist laut FIN auch von der Rückrufaktion betroffen.
Denn werde ich mal demnächst beim 🙂 vorbei schauen. Bis jetzt habe ich noch keine Probleme, aber meiner hat auch erst 60000 km runter.
Vielen Dank für die Info 😉
