Der neue
Mercedes G-Klasse
Das ist er dann wohl,,,er scheint Starrachsen zu haben, schönere Türtafeln, nur ein Facelift? Oder ganz neu ?
Second-Generation Mercedes-Benz G-Class Makes Spy Photo Debut
Lovers and haters of the legendary Mercedes-Benz G-Class are about to find out about a rather interesting piece of news regarding the boxy off-roader.
There have been plenty of rumors suggesting that Mercedes-Benz is working on a G-Class replacement, but these spyshots are the first proof that it is indeed the case. Lo and behold, the G-Wagen will soon be dead, long live the G-Wagen!
Before jumping to early conclusions and accuse us of showing you a plain ol' G-Class with some fancy camouflage, take a moment and observe the images in the adjacent gallery a bit closer. In fact, you can also compare the 2018 G-Class with a current model in a couple of photos.
Despite looking almost identical from the distance, the new G-Wagen is much wider, while the body seems to be a bit lower, despite featuring a similar ground clearance. In other words, the Bauhaus exterior design will be kept, but almost everything underneath that chiseled body will be all-new.
That said, at least the rear suspension looks like it continues to use a live axle system, although our untrained eyes think they've spotted some extra cylinders. This may translate in the addition of a pneumatic suspension system for the first time in a G-Class, giving owners the option of a higher or a lower ground clearance at the push of a button or a switch of a knob.
The interior will be all new, with most of the bits and bobs being borrowed from the latest E-Class (W213), including a gargantuan center display and massage seats. Fans of the ruggedness of the G-Wagen shouldn't fret, though, as the new model should keep the three locking differentials, as useless as they are for most of its current customers.
Despite the wider body, the addition of pneumatic suspension and plenty of extra safety gizmos, the 2018 G-Class will shed plenty of kilos, with the most recent estimates revolving around 400 kg (882 pounds). Parts of the new suspension and most of the body will switch to an assortment of high-strength steel and aluminum to achieve this hefty weight drop.
Engine wise, we are expecting an array of inline six gasoline and diesel engines, with the gasoline ones using a 48-Volt system to offer a mild-hybrid function. Fans of the good ol' V8 will not be disappointed either, as the Mercedes-AMG G63 will switch to a more powerful version of the same 4.0-liter V8 recently introduced on the G500 and G500 “squared.”
Given the overall look of the pre-production prototype spied by our friends at SB-Medien, this is not exactly a mule so Mercedes-Benz could be ready to unveil it as early as the second half of 2017, as a 2018 model year.
We're really trying to contain our excitement until we learn more about the G-Class Part Deux, but that doesn't mean you have to. Remember, this is a car that has been continuously produced using the same body molds for over 37 years now. Speaking of which, it goes without saying that the second generation will also be hand built by Magna in Graz, Austria, even though nothing official has transpired about this subject so far.
+5
Also Leute, keinen Katzenjammer. Der Neue bekommt alles, was (auch hier) gewünscht wurde. Alu Karosse = kein Rost! Breitere Sitze (wurde hier bemängelt), weniger Windgeräusch. Niedriger, d. h. weniger Verbrauch (siehe Beiträge - was verbraucht mein G). Aktuelles Infotainment - siehe mein iPhone xxy wird nicht erkannt. Wahrscheinlich gibt es sogar einen flachen Ladeboden und rausnehmbare Rücksitze. Natürlich alle selbstfahr Helferlein. Ins Parkhaus und in die Waschstrasse mit 1,9 m Begrenzung wird er auch passen. Die Vmax wird höher sein, der AMG wird die 250 km/h wohl knacken, das ist er schon der Konkurrenz schuldig. Gelände? Nun ja, leichter, drei Sperren, Untersetzung, im Offroad Park wird er schon jeden Range stehen lassen. Und Expedition? Macht mit einem +100 TEuro (Euro 6) Fahrzeug ohnehin niemand, ausser vielleicht einem Werksteam mit drei Unimog als Begleitfahrzeuge. Der geht wie geschnitten Brot und holt auch noch die ganzen Range Käufer ins Boot, welche die VerSUVung des aktuellen RangeRover nicht verkraften. Und wenn man auch weiterhin noch einen Worker bekommen kann: alles richtig gemacht!
OpenAirFan
1554 weitere Antworten
1554 Antworten
Mercedes kann - und will - nicht zaubern, wenn es um einen neuen G geht. Die Maschinen zur Herstellung können nicht
großartig verändert werden, ohne massive Eingriffe vornehmen zu müssen. Daher wird man sich darauf beschränken, die Spur etwas Breiter zu bekommen, den Innenraum etwas aufzuhübschen (was Platzbedingt bei 1,60m Innenbreite nur extrem gering möglich ist) und dann war es das aber auch schon. Vor allem ist der G eine CashCow, die wie eine heilige Kuh nicht angefasst werden wird. Man wird noch zum 40. Geburtstag etliche Sondermodelle raus bringen und die Kuh
richtig melken ... danach wird der G dann aber doch in der Versenkung verschwinden, da er eben doch halt 40 Jahre alt ist und bei manchen Standards schon getrickst wird.
Ich glaube, dass genau das Gegenteil der Fall ist. Der neue G wird außer dem Design nicht viel mit dem alten gemeinsam haben. Kleinteile, wie Blinker, Scharniere und so Kram. Sonst wird mehr neu sein, als man ihm ansieht.
Es waren beides neue Gs. Der zweite hatte auch den neuen Kühlergrill. Hatte mich für ein kurzes Stück zwischen die beiden gesetzt und es im Spieel betrachtet.
@Mike03 der neue G ist ein 463 der in der mitte Auseinander gesägt wurde und um 10cm verbreitert ist. Das kann man ganz deutlich sehen wenn man hinter einem Steht, dazu braucht man nicht mal einen vergleich.
hier ist er
Ich glaube nicht das sie den "neuen" G kleiner machen. Irgendwo habe ich was gelesen von +10cm in der Breite,... und flacher wird er auch nicht werden.
Aber wenn man mal ehrlich ist, ist es kein neues Auto sondern lediglich ein größeres Facelift,.. das ist auch gut so! Denn der G ist und bleibt eine Legende
@alex-n schrieb am 4. Februar 2017 um 19:16:44 Uhr:
hier ist er
Interessant,
Also ein 4x4 hoch2 als Cabrio/Landaulet...
mehr kann man nicht erkennen.
@ alex-n: wo hast du das Bild her?
G-russ
MPS12
hier ist er
Das ist er leider nicht es gibt auch ein Foto komplettes von dem Fahrzeug das war ein Auftrag ich glaube gfg
@Magnetimarelli schrieb am 5. Februar 2017 um 10:22:14 Uhr:
hier ist er
ich denke schon! kommt von der offiziellen MB G Klasse Facebookseite mit folgendem comment: "First we built the G 63 AMG 6x6 – Now the ultimate off-roader has another surprise up its sleeve.
Stay tuned…"
@alex-n schrieb am 5. Februar 2017 um 10:34:12 Uhr:
Stay tuned…"
Stimmt grade gesehen .... Cool
Hallo G-emeinde,
es wird definitiv einen 500 4x4 hoch 2 als Landaulet geben, diese soll aller Voraussicht in Genf vorgestellt werden.
Schönen Abend noch und für Morgen einen schönen Wochenanfang.
G-olesinon
Hab dazu auf Instagram ein interessantes bild gefunden...
@smarty32 Jetzt hast Du uns mehr Antworten gegeben als die Journalisten:
http://....mercedes-benz-passion.com/.../
Bin gerade zufällig auf das foto gestoßen.zumal im intranet von daimler ein foto von hinten ist,auf dem man nur das reserverad samt bügel für die 3.bremsleuchte sieht,dazu das es ein 4x4 sein könnte.das kennzeichen darauf ist bis auf die endzahl identisch mit dem Instagram -foto...
Ja,der link von dir verweist auf endzahl 6501 , der Instagram auf 6502. Wäre ein dummer zufall. Ganz interessant auch die bezeichnung auf Instagram,maybach g650 landaulet....
@smarty32 schrieb am 6. Februar 2017 um 15:43:52 Uhr:
Dazu gibt es einen ganzen Film😉 https://www.instagram.com/p/BQKy65QB8Nz/
