Brauche Hilfe bei Logfahrt Auswertung
Habe eine Log Fahrt gemacht.
Habe darüber noch keine Ahnung.
Vieleicht könnt ihr mir dabei Helfen
Kriege die Datei leider nicht hier hochgeladen
8D0 907 558 E,,1.8L R4/5VT MOTR HS D02,
,Group A:,'001,,,,Group B:,'006,,,,Group C:,'007
,,RPM,Time,T.B. Angle,Ign. Timing,,RPM,Lambda,Lambda,Ign. Timing,,Lambda,Voltage,Duty Cycle,(no units)
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, ms,°, °BTDC,STAMP, /min,%,%, °BTDC,STAMP,%, V, %,
,0.01,840,1.05,0.4,12.0,0.39,860,-0.8,4.7,12.0,0.81,8.6,0.145,5.9,0.93
,1.19,840,1.05,0.4,12.0,1.58,870,-0.8,6.3,12.0,2.03,7.8,0.430,5.9,0.93
,2.44,840,1.05,0.4,12.0,2.86,880,-0.8,6.3,12.0,3.26,8.6,0.085,9.0,0.93
,3.66,1440,2.00,8.7,26.3,4.08,1480,-1.6,7.0,27.0,4.49,3.9,0.765,13.3,0.97
,4.89,1200,2.30,9.5,24.0,5.28,1120,-0.8,2.3,21.8,5.79,0.0,0.695,8.2,0.98
,6.16,1000,0.90,0.4,12.0,6.56,930,-1.6,2.3,12.0,6.95,3.9,0.080,2.7,0.98
,7.36,800,1.05,0.4,12.0,7.78,840,0.0,3.1,12.0,8.16,1.6,0.780,3.5,0.98
,8.61,840,1.10,0.9,12.0,9.02,840,0.0,1.6,3.8,9.41,-0.8,0.840,14.1,0.98
,9.81,1400,2.20,10.4,26.3,10.21,1150,0.0,-1.6,22.5,10.61,-0.8,0.725,14.1,0.98
,11.05,1240,1.15,0.0,18.0,11.45,1090,4.7,0.8,13.5,11.83,2.3,0.070,6.6,0.98
,12.23,1240,0.85,0.0,18.0,12.63,1080,0.0,-1.6,13.5,13.17,2.3,0.085,3.5,0.98
,13.56,840,0.95,0.4,12.0,13.95,790,0.8,0.0,12.0,14.35,-0.8,0.770,3.9,0.98
,14.75,840,1.20,0.9,12.0,15.15,870,1.6,-3.1,12.0,15.57,-4.7,0.630,3.9,0.98
,15.96,840,1.20,1.3,12.0,16.40,870,1.6,0.0,12.0,16.84,0.8,0.465,12.1,0.98
,17.27,1360,2.30,10.4,25.5,17.71,1080,0.0,0.0,21.0,18.15,-2.3,0.770,16.8,0.98
,18.54,1200,2.90,11.7,19.5,18.94,1390,-2.3,0.8,22.5,19.37,0.0,0.760,36.3,0.98
,19.79,1800,3.95,21.7,19.5,20.21,2170,-3.9,-2.3,18.8,20.61,-2.3,0.090,91.0,0.99
,21.00,3200,6.15,59.5,18.8,21.43,2550,-4.7,0.0,23.3,21.84,0.0,0.835,99.6,0.99
,22.24,5120,7.25,85.9,25.5,22.65,2550,-4.7,0.0,25.5,23.08,0.0,0.885,99.6,0.99
,23.50,6400,0.95,15.6,29.3,23.91,2550,-4.7,-6.3,37.5,24.31,-12.5,0.890,85.2,0.98
,24.71,4480,7.00,86.4,27.0,25.12,2550,-4.7,0.0,26.3,25.51,0.0,0.855,99.6,0.98
,25.96,5240,6.95,86.4,26.3,26.36,2550,-4.7,0.0,27.0,26.78,0.0,0.870,99.6,0.99
,27.21,5920,6.75,85.9,26.3,27.61,2550,-4.7,0.0,27.0,28.04,0.0,0.900,99.6,0.99
,28.42,6160,0.75,13.9,37.5,28.82,2550,-4.7,-1.6,37.5,29.23,-7.8,0.610,0.8,0.99
,29.68,5160,0.75,11.7,37.5,30.07,2550,-4.7,0.0,37.5,30.52,0.0,0.020,0.0,1.00
,30.92,3360,0.70,6.5,36.0,31.36,2550,-4.7,0.0,32.3,31.80,0.0,0.020,0.0,1.00
,32.24,1760,0.80,3.5,25.5,32.66,1320,8.6,0.0,6.8,33.08,0.0,0.085,0.4,0.98
,33.59,960,0.95,0.4,2.3,34.10,900,-0.8,-5.5,12.0,34.52,-6.3,0.695,0.0,0.98
,34.91,840,1.05,0.4,12.0,35.39,870,0.0,-3.1,12.0,35.79,-1.6,0.175,0.4,0.98
,36.30,840,1.05,0.4,12.0,36.68,860,0.0,-2.3,12.0,37.07,-1.6,0.125,0.4,0.97
,37.45,880,1.05,0.4,12.0,37.87,870,-0.8,-3.9,12.0,38.33,-2.3,0.375,0.8,0.96
,38.74,840,1.05,0.9,12.0,39.18,860,0.0,0.0,12.0,39.65,0.8,0.130,0.8,0.95
,40.04,840,1.05,0.4,12.0,40.47,860,0.0,3.1,12.0,40.91,3.9,0.110,1.2,0.94
69 Antworten
Habe mir sonst immer Hylomar gekauft, ist eine Blaue Dichtmasse.
Habe mir jetzt mal eine Ladedruckanzeige gekauft um den Ladedruck zumessen.
Habe heute auch nicht nach geguckt nach den Steuerzeiten, war mir zu Kalt und da ich mich Erkältet habe.
Habe leider in der Garage kein Heizung.
Habe heute noch ein fehler am Wagen gefunden, wie ich schon der Arbeit gekommen bin, mein Arbeitsweg Beträgt 30km fast nur Autobahn zuhause angekommen und unten am Kühlerschlauch
angefast.
Der war Kalt.
Eben noch mal so 40km gefahren das gleiche der Schlauch ist Kalt, muss ich wohl bald mein Thermostat
austauschen.
Die Temp bleibt immer zwischen 80 und 90grad oder sogar so 20 km auf 90grad stehen
Die temp Anzeige ist auch immer sehr am Schwangen zwischen 80 und 90 grad.
Kenne es von useren Golf 4 her der bleibt immer auf 90 grad stehen
schau erst mal deine steuerzeiten nach bevor du andere baustellen anfängst ,solange deine Heizung gut funktioniert und deine Temp Anzeige auf 90 Grad geht ist alles in Ordnung 🙂
zwischen 80° und 90° ist doch in einem völlig normalen rahmen. und gerade auf der autobahn ist eine etwas niedrigere tempetatur völlig normal - erst recht im winter.
daran liegt dein leistungsverlust unter garantie nicht.
Habe endlich alles zusammen. Habe das Dirko HT, werde die Tage die Steuerzeiten 'Kontrolieren.
Gestern ist endlich meine Ladedruckanzeige gekommen direkt Ausprobiert er macht 0,5 bis 0,6 Bar.
Habe grade den Ventildeckel abgenommen, die Steuerzeiten stimmen Überall.
Das einzige was mir aufgefallen ist an der VentildeckelDichtung war keine Flüssigedichtmasse
dran
Mache gleich noch ein Paar Fotos davon
Habe eben mal am N75 den Schlauch der zu Druckdose geht abgezogen und eine Testfahrt gemacht.
Dann zieht er richtig durch nur ab 2500 geht er in den Notlauf fängt an zu Rucken.
Habe das N75 druch gemessen mach seine 28Ohm.
Weiß keiner wodran das noch liegen kann das ich keine Leistung habe.
Könnten das vieleicht auch die Zündkerzen sein, die haben schon am weißen Keramik so einen
Gelbebraunlichen Ring.
Ich meine Leistung wird immer weniger.
Hatte die Tage auch mal ein Ruckeln beim Fahren.
Nabend,
ich will mich hier mal kurz einklinken, da ich für eine (vllt schon bestehende) frage keinen extra Thread aufmachen will 😉
Mein Passat 3B, 1.9 TDI, ATJ zieht nicht so, wie er eigentlich sollte. Möchte morgen eine Logfahrt mit vag-com machen. Ich hab am anfang des thread gelesen das man die MWB 3,8 & 11 loggen soll.
gibt es sonst noch interessant mwb die sich lohnen mitzuloggen?
gruß
