Brauche Hilfe bei Logfahrt Auswertung
VW Passat B5/3BG
Habe eine Log Fahrt gemacht.
Habe darüber noch keine Ahnung.
Vieleicht könnt ihr mir dabei Helfen
Kriege die Datei leider nicht hier hochgeladen
8D0 907 558 E,,1.8L R4/5VT MOTR HS D02,
,Group A:,'001,,,,Group B:,'006,,,,Group C:,'007
,,RPM,Time,T.B. Angle,Ign. Timing,,RPM,Lambda,Lambda,Ign. Timing,,Lambda,Voltage,Duty Cycle,(no units)
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, ms,°, °BTDC,STAMP, /min,%,%, °BTDC,STAMP,%, V, %,
,0.01,840,1.05,0.4,12.0,0.39,860,-0.8,4.7,12.0,0.81,8.6,0.145,5.9,0.93
,1.19,840,1.05,0.4,12.0,1.58,870,-0.8,6.3,12.0,2.03,7.8,0.430,5.9,0.93
,2.44,840,1.05,0.4,12.0,2.86,880,-0.8,6.3,12.0,3.26,8.6,0.085,9.0,0.93
,3.66,1440,2.00,8.7,26.3,4.08,1480,-1.6,7.0,27.0,4.49,3.9,0.765,13.3,0.97
,4.89,1200,2.30,9.5,24.0,5.28,1120,-0.8,2.3,21.8,5.79,0.0,0.695,8.2,0.98
,6.16,1000,0.90,0.4,12.0,6.56,930,-1.6,2.3,12.0,6.95,3.9,0.080,2.7,0.98
,7.36,800,1.05,0.4,12.0,7.78,840,0.0,3.1,12.0,8.16,1.6,0.780,3.5,0.98
,8.61,840,1.10,0.9,12.0,9.02,840,0.0,1.6,3.8,9.41,-0.8,0.840,14.1,0.98
,9.81,1400,2.20,10.4,26.3,10.21,1150,0.0,-1.6,22.5,10.61,-0.8,0.725,14.1,0.98
,11.05,1240,1.15,0.0,18.0,11.45,1090,4.7,0.8,13.5,11.83,2.3,0.070,6.6,0.98
,12.23,1240,0.85,0.0,18.0,12.63,1080,0.0,-1.6,13.5,13.17,2.3,0.085,3.5,0.98
,13.56,840,0.95,0.4,12.0,13.95,790,0.8,0.0,12.0,14.35,-0.8,0.770,3.9,0.98
,14.75,840,1.20,0.9,12.0,15.15,870,1.6,-3.1,12.0,15.57,-4.7,0.630,3.9,0.98
,15.96,840,1.20,1.3,12.0,16.40,870,1.6,0.0,12.0,16.84,0.8,0.465,12.1,0.98
,17.27,1360,2.30,10.4,25.5,17.71,1080,0.0,0.0,21.0,18.15,-2.3,0.770,16.8,0.98
,18.54,1200,2.90,11.7,19.5,18.94,1390,-2.3,0.8,22.5,19.37,0.0,0.760,36.3,0.98
,19.79,1800,3.95,21.7,19.5,20.21,2170,-3.9,-2.3,18.8,20.61,-2.3,0.090,91.0,0.99
,21.00,3200,6.15,59.5,18.8,21.43,2550,-4.7,0.0,23.3,21.84,0.0,0.835,99.6,0.99
,22.24,5120,7.25,85.9,25.5,22.65,2550,-4.7,0.0,25.5,23.08,0.0,0.885,99.6,0.99
,23.50,6400,0.95,15.6,29.3,23.91,2550,-4.7,-6.3,37.5,24.31,-12.5,0.890,85.2,0.98
,24.71,4480,7.00,86.4,27.0,25.12,2550,-4.7,0.0,26.3,25.51,0.0,0.855,99.6,0.98
,25.96,5240,6.95,86.4,26.3,26.36,2550,-4.7,0.0,27.0,26.78,0.0,0.870,99.6,0.99
,27.21,5920,6.75,85.9,26.3,27.61,2550,-4.7,0.0,27.0,28.04,0.0,0.900,99.6,0.99
,28.42,6160,0.75,13.9,37.5,28.82,2550,-4.7,-1.6,37.5,29.23,-7.8,0.610,0.8,0.99
,29.68,5160,0.75,11.7,37.5,30.07,2550,-4.7,0.0,37.5,30.52,0.0,0.020,0.0,1.00
,30.92,3360,0.70,6.5,36.0,31.36,2550,-4.7,0.0,32.3,31.80,0.0,0.020,0.0,1.00
,32.24,1760,0.80,3.5,25.5,32.66,1320,8.6,0.0,6.8,33.08,0.0,0.085,0.4,0.98
,33.59,960,0.95,0.4,2.3,34.10,900,-0.8,-5.5,12.0,34.52,-6.3,0.695,0.0,0.98
,34.91,840,1.05,0.4,12.0,35.39,870,0.0,-3.1,12.0,35.79,-1.6,0.175,0.4,0.98
,36.30,840,1.05,0.4,12.0,36.68,860,0.0,-2.3,12.0,37.07,-1.6,0.125,0.4,0.97
,37.45,880,1.05,0.4,12.0,37.87,870,-0.8,-3.9,12.0,38.33,-2.3,0.375,0.8,0.96
,38.74,840,1.05,0.9,12.0,39.18,860,0.0,0.0,12.0,39.65,0.8,0.130,0.8,0.95
,40.04,840,1.05,0.4,12.0,40.47,860,0.0,3.1,12.0,40.91,3.9,0.110,1.2,0.94
69 Antworten
Original geschrieben von florian84z
gibt es sonst noch interessant mwb die sich lohnen mitzuloggen?
Pro Log gehen sowieso nur 3 MWBe.
Aber mach doch dann einen eigenen Thread. Benziner und Diesel in einem Thread
gehen nicht gut zusammen.
Grüße Klaus
Gut, dann mache ich morgen gleich nach der logfahrt einen neuen thread auf. kannst du mir kurz sagen ob 3,8 & 11 soweit richtig ist?! Wollte morgen Vormittag gleich loslegen ...
Ja, das passt.
Grüße Klaus
So, neuer Thread ist auch offen. Werde morgen mal den Log posten... danke schonmal!
so da ich ja auch mit einem 3B 1.8T AEB rum gurke und meine frau sagt das er seit 2 tagen nicht mehr oder nicht immer zieht habe ich auch mal eine Logfahrt gemacht, hoffe MWB 3,8 & 11 Sind richtig ansonsten mit welche MWB soll ich noch ein erstellen?
ich kann mit den Daten nicht viel Anfangen daher bitte um unterstützung, siehe Anhang.
wie ihr sehen könnt hab ich es mal im 4. Gang gemacht bis knapp 6000 und einmal im 3. Gang.
danke
gruß
Original geschrieben von marccash
... hoffe MWB 3,8 & 11 Sind richtig ansonsten mit welche MWB soll ich noch ein erstellen?
MWB 3, 8, 11 sind für den TDI geeignet, Benziner ticken anders.
Am besten, Du machst einen neuen Thread auf und fragst nochmal
explizit, wie die Logfahrt für Deinen AEB gemacht werden soll.
Ich kann Dir da leider nicht helfen.
Grüße Klaus
Wiso regelt deine Lamda nicht ?
Grüße Klaus
hätte ich auch ab er bei dem TE handelt es sich auch um ein
1.8T AEB
daher hab ich eben extra kein neues Thread aufgemacht
ist dem so? kann ich dir nicht sagen. habe keine fehler einträge ausser meine Spiegelheizung aber das hat ja hier nichst mit zu tun.
Welche MWB´s soll ich Loggen?
hätte ich auch ab er bei dem TE handelt es sich auch um ein 1.8T AEB daher hab ich eben extra kein neues Thread aufgemacht
Ach ja, es war ja der TDI (florian84z), der sich reingemogelt hatte, sorry. 😛
Grüße Klaus
Grüße Klaus
wenn du noch wüsstets ob die MWB`s passen oder ob ich heute abend mal anderen Loggen soll
edit: ups hab gerade gesehen das du schon sagtest das du es beim AEB bzw. benziner nicht weißt.
