Werkstattaktion Rückrufaktion 170 PS PD-TDI Motor
VW Touran 1 (1T)
heute herausgefunden das es angeblich ein Rückrufaktion gibt in England für den 170 PS BMN Motoren.
... This is a brief précis of the VW UK Service Action 23H9 regarding Piezo pump injectors.
The repair instructions are contained in Technical Product Information (TPI) transaction number 2027647
This applies to 2.0TDI PD Golf, Passat, and Touran with PD Piezo Injectors
There are approximately 78,800 (model years 2006 – 2010) affected vehicles in the UK.
Owners will receive communications from Volkswagen UK on a phased basis.
The following vehicles with the engine codes listed are affected.
Passat 3C 2006-2008 with the BKP, BMA, BWV, BVE, BKP, BVE, BMA, BWV, BMR, and BUZ engines
Golf 5 2006-2009 with the BMN engine
Touran 2006-2010 with the BMN engine
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006 1x Wiring loom adapter 03G 971 033 M 4x Adjustment screw WHT 000 530 5x M8x58 socket head bolt N 105 811 01 8x M6x88 socket head bolt 03G 103 385 A 4x Pump injectors
Remove cam cover and check the part number –see arrow- on the pump injector element. All pump injector elements with the part number 03G 130 073 D or 03G 130 073 M must be replaced. All other pump injector elements are correct and must not be replaced.
Weisst euch ob das auch in Deutschland/der Schweiz dem Fall ist?
Habe am 30. Dezember mal wieder eine kaputte Pumpedüse gehabt, und das für die 2. Mal in 2011 und mir reicht das langsam. Beide Fälle auf den Autobahn und volle Familie drin, also super gefährlich.
Zusätzlich wäre es noch gut zu wissen ob die Probleme nun wirklich bestehen für den 073 D und 073 M Teilenummern oder auch für dein 073 TX. Weisst euch das?
Danke!!!
Dieser Brief ist ein Info der britischen VW Service Action 23H9 Piezo-Injektor-Pumpe.
Die Reparaturanleitung ist in Technische Produktinformation (TPI) Transaktionsnummer 2027647 enthaltenen
Dies gilt für 2.0TDI PD Golf, Passat, Touran und Piezo-Injektoren mit PD
Es gibt ungefähr 78.800 (Baujahre 2006 bis 2010) Betroffene Fahrzeuge in Großbritannien.
Besitzer erhalten Kommunikation von Volkswagen UK in mehreren Phasen.
Die folgenden Fahrzeuge mit Motor-Codes aufgeführt sind Betroffene.
Passat 3C 2006-2008 mit der BKP, BMA, BWV, ESO, BKP, ESO, BMA, BWV, MMR, und BUZ-Motoren
Golf 5 2006-2009 mit dem BMN-Engine
Touran 2006-2010 mit dem BMN-Engine
Technischer Hintergrund:
Bei einigen Fahrzeugen mit dem 2,0 l TDI-Motor können auf der Piezo-Injektor-Pumpe Partikel verbleiben, wegen verschmutztes Motoröl. Dies kann zu Problemen führen. Nicht alle Fahrzeuge sind von dieser Kampagne betroffen! Bei der Betroffene Fahrzeuge müssen die Piezo-Injektor Pumpenelemente überprüft und gegebenenfalls ausgetauscht werden.
Teile, die als Teil dieser Kampagne eingebaut werden:
1x Sticker-Kampagne 23H9 000 010 006
1x Kabelbaum Adapter 03G 971 033 M
4x WHT Stellschraube WHT 000 530
5x M8x58 Zylinderkopfschrauben N 105 811 01
8x M6x88 Zylinderkopfschrauben 03G 103 385 A
4x Pumpe-Düse
Anleitung:
Entferne Ventildeckel und überprüfen Sie die Teilenummer auf der Pumpe-Düse-Element. Alle Einspritzpumpen mit der Teilenummer "03G 130 073 D" oder "03G 130 073 M" müssen ersetzt werden. Alle anderen Einspritzpumpen sind korrekt und müssen nicht ersetzt werden.
162 weitere Antworten
162 Antworten
Vielen Dank für die schnelle Antwort. Genau das habe ich ihm auch gesagt. Der hat dann außer den von dir genannten Teilen sogar den Motorblock aufgezählt 😁 Am besten drohe ich mal mit einem Anwalt, vielleicht wird er dann ja weich.
Auf folgender Hompage wurde leider keine Aktion für mein Auto gefunden: http://origin-www.audi.com/.../rueckrufaktionen.html
Ich gehe aber noch einmal persönlich zu einem Audi Händler.
VG
Emre
So liebe Leidensgenossen,
war heute Mittag bei Audi. Nach 2 Minuten Recherche im System wurde mir gesagt, dass Audi 100% der Kosten übernimmt und ich hab am Mittwoch schon einen Termin. Unglaublich, ich freu mich einen Keks!
VG
Emre
Ist es eventuell mal möglich eine Kopie mir zu zusenden vom Auftrag bzw. Auftragsnummer oder sowas. die wollen es einfach nicht machen bei mir da nicht im Rechner steht.
Die TIP steht hundert Prozent noch in System von VW Audi... Ich guck später mal wie die TIP kennun war
super danke dir.
Kann dir die Seite aus meinem Bordbuch kopieren
Dort steht die ausgeführte Aktion drin, mit Audi Stempel
23H9 Dass ist die Kennung für die TPI der PD Elemente
Eine richtige Rückruf Aktion war es eigentlich nie.
Die Werkstattaktion hieß wohl eher 23H9 😉.
Eine TPI Nummer besteht nur aus Zahlen (8stellig oder so).
Hallo. Hab mir vor eine woche ein touran bj2007 mit 170ps gekauft 190tkm von einem kleinem Händler. ich lese heute zum 1.mal über diese Problematik. Der wagen ist jetzt bei mir 2.hand war immer vw Vertragspartner scheckheft geführt. Wie kann ich herausfinden ob bei meinem wagen was gemacht wurde? Werde bei uns mal zur vw fahren und fragen ob die was über mein Fahrzeug wissen. Angenommen bei mir wurde nix gemacht. Würden die es jetzt noch reparieren obwohl der normal fährt?
Schau ins Serviceheft da steht in den Bemerkungen 23H9 dann ist es bereits gemacht worden. Wenn nicht hin zu vw ,die werden es mit hoher Wahrscheinlichkeit dann noch machen da vw S_heft gepflegt.
Alternativ könnte sich auch im Kofferraum bzw. in der Reserveradmulde ein Aufkleber dieser Aktion befinden.
Guten morgen. War eben bei vw die Dame hat im pc nachgeschaut und mir gesagt das mein Fahrzeug nicht von dieser PD elemente werkstatt aktion betroffen ist bzw war....mmh ok im serviceheft ist auch keine bemerkung 23H9 mein Touran ist ez.03.2007 Motor BMN-JMA
125kw. Also kann ich beruhigt sein?
Seite 1 steht ja betroffene motoren Touran 2006-2010 mit dem BMN-Engine
Bei mir steht ja BMN -JMA da ist ja ein unterschied.
Jma sollte doch dein 6gang Schaltgetriebe sein ?!
Touran BMN von 2006-2010 war betroffen. Nochmal genauer nach Haken
Hab woanders bei vw angerufen erwarte rückruf. Aber die dame zeigte mir am pc das da kein eintrag ist mit 23H9 pd elemente ich schreibe hier rein wenn ich rückruf von dem andere vw bekomme
Der Herr sagt es gibt keine werkstattaktion. Auch auf die frage ob meiner betroffen ist bekomme ich dieselben antworten
