Update für Concert 3 auf mindestens SW 0300
Hallo Community,
gibt es die Möglichkeit (außer in der Werkstatt), mein Audi Concert 3 auf die SW 0300 oder höher zu updaten? Ziel ist es, dann auch SDHC Karten verwenden zu können, da diese Funktion ja nur durch den Softwarestand blockiert wird. Ich hoffe darauf, die aktuelle Firmware per CD-Update oder über VCDS einspielen zu können. Also wenn jemand Ideen zum Update hat, immer her damit 🙂
Die Versionsinfos des Radios lauten wie folgt:
Radio-Nr: 8T1035186C
Display-Nr: 8T0919603A
HW: H02
SW: 0210
Mit freundlichem Gruß,
Martin
RG3Mid_ECE_0310.sgo
50 Antworten
Firmware 0350 after update from 0310 though it works (100%), it gives a fault of incorrect software version. How does it know that it is incorrect, I dont have a clue. (Fault cannot be erased, reappears). Did not have this fault initially.
Address 56: Radio Labels: 8Tx-035-1xx-56.clb
Control Module Part Number: 8T2 035 186 P HW: 8T2 035 186 P
Component and/or Version: Concert3 H01 0350
01043 - Control Module; Incorrect Software Version
000 - - - Intermittent
Answer:
This only happens when you upgrade your HVAC to 3Zone Facelift. Better not to because you will also need to upgrade your radio concert to facelift B8.5 too.
Really happy with firmware 0350. Replaced back HVAC from B8.
Upgraded radio concert prefacelift to facelift with 0460 firmware (retrofit and CP removal+dab antenna)
Updated radio concert to firmware 0480.
Does anyone have the TPI information of what firmware 0480 corrects from firmware 0460?? I did not observe a difference, however it may have to do with dab quality or dab station scan which I have no interest.
p.s. why is this retrofit not discussed??
TPI 2030907/4 maybe??
yes...
I had retrofit my B8 Saloon with concert + DAB+. It's was discussed in "DAB+ nachrüsten"... but not much discussed...mainly DAB retrofit on MMI3G
Nice. Thanks for confirmation.
Did the upgrade this year together with a 7” android Touch screen fully integrated with back up camera (radar lines working) Bluetooth hands free telephone, a2dp stereo music streaming, Navigation, 4g hotspot support from phone, external CarPlay with Bluetooth connection, playstore, facelift steering wheel with paddles....B8 Audi feels like facelift B8.5 internally. I am really happy with radio concert especially after adding the Android 7” multimedia touch screen and wireless CarPlay.
I added Dab antenna and cable and original amplifier because I wanted to get the error removed however no support of Dab at my region.
