Blaupunkt Gamma 2 zeigt "6 Safe"
Da mein Radio "6 Safe" anzeigt und auch nach Stunden auf Spannung nicht freischaltet um den Code einzugeben, habe ich nochmals im Netz gesucht und diesen Trick gefunden. Anscheinend ist bei 6 Safe das Radio definitiv blockiert, sprich es muss eingeschickt werden.
Leider verstehe ich da net alles, vielleicht kann ja jemand helfen, wo genau soll ich da was mit ner Metallklammer fummeln ???
P ELECTRO:
BLAUPUNKT HIB CERAMIC
The 'peasant' way for Blaupunct Gamma II(M327)
Start up the tape,on the display will appear '6 SAFe'.You bring it in working state by introducing parasite signals to the Quartz terminal( I use a metalic clip with a bended end ,touching the quartz terminal until the radio starts.)I verify the functioning of the radio on all the channels.Press simultaneously on M and VF tasts.On the screen should appear 'CODe'(if it's writen 'SAFe' then you repeat the operation describe up to this point) After relesing the tasts on the screen should apear'1000'.
Now from the the 4 tasts whith numbers ,introduce a code,any code (ex.0211)after that, you press again M and VF,and on the screen will apear SAFe.From this moment on, the tape will have the code introduced by me(0211)When started again on the screen will appear 'SAFE' you press M and VF and as a result 1000 will be displayed.Introduce the code( 0211) and the radio starts normaly.For blocking the code when the radio is started you press simultaneously M and VF and on the screen you'll find “SAFe� and “1000� Introduce the code( 0211) you press again M and VF and on the screen you'll find 'CODe'.Now for a general start up the radio won't aske the code.
For the models based on hibrid procesor,-ceramic Audi Gamma III, Blaupunkt Bremen SQR 46 and Delta II for function start ,you supply the procesor with +5V(the pin Nr7 of the stabiliser L498B) on the litle metalic square from the procesor,next to letter A.(see the diagram)
Costas@netsoft.ro
Audi Gamma III
mit dem tape is das radio gemeint und nicht das eine kassete eingelegt werden muss oder so.
ich eubersetz dann mal.
schalte das radio an, auf dem display erscheint dann 6 safe. beim ueberbrucken vom quartz terminal mit einer buroklamma mit gebogenen enden auf dem quartz terminal bis das radio startet. (leider nich rauslesbar von wo er es direkt ueberbruckt).
ich kontrolliere auf die funktion aller radio stationen (damit ist gemeint fm und am),
druecke gleichzeitig die M und VF taste. auf dem display sollte CODe zulesen sein, wenn immer noch safe zu lesen ist dann wiederholen bis CODe da steht. nachdem ihr dann die beiden tasten loslasst sollte 1000 da stehen.
jetze von den 4 tasten mit nummern drauf. gebe einen neuen code ein egal welchen (zb. 0211)
nachdem du den neuen code eingegeben hast drueckst du wieder M und VF zusammen, auf dem display sollte dann SAFe erscheinen. von da aus sollte nun der neue code den du vorher eingegen hast gespeichert sein.
beim einschalten sollte dann nochmal SAFe erscheinen und du drueckst M und F wieder gleichzeitig und es sollte 1000 erscheinen. dann tippe ein deinen zuvor gespeicherten code ein und dein radio sollte normal funktionieren danach.
so der rest ist nur um deinen code zu sperren das der eben nicht mehr funzt aber das willst du ja nicht.
hoffe das hilft und macht es etwas klarer fuer dich.
und vergebt mir fuer die schreibweise ohne das o mit den strichen und so habe die leider net auf meiner tastatur weil ich in england lebe und diese tasten hier normaler weise nicht brauch und ich keine lust habe es mit der virtuelle tastatur zu schreiben.
gruss horst
47 Antworten
Keine Ahnung... Hab ich mich auch schon gefragt. Vielleicht ist das für jemanden, der sich mit so alter µC-Technik auskennt, ganz logisch.
Der Ursprung kam doch aus einem ausländischen Forum, wenn ich mich recht erinnere.
hallo ich habe das selbe problem mit gamma 2.
meine frage, geht dieses vorgehen mit der büroklammer auch bei anderen autoradios von vw
zb gamma 4 golf 3 und beta golf 3 sowie gamma v golf 4.
es gibt da aber zb auch philips oder grundig geräte
besitzt jedes radio so einen prozessor und kann man jedes x beliebige radio so überlisten oder geht es explizit nur bei diesem gamma 2 mit dieser methode?
würde das vorgehen auch bei sonstigen zubehör radios funktionieren zb philips becker blaupunkt.
grüsse
Ich glaube nicht das dir hier jemand erklärt wie man die Diebstahlsicherung verschiedenster Autoradios umgeht.
Wenn du das jeweilige Radio gekauft hast kannst du zu VW fahren und das da freischalten lassen. Das funktioniert selbst dann wenn du das Teil gebraucht gekauft hast.
Hab ich selbst schon gemacht. Du wirst dann da registriert. Denn wenn das, bei ebay gekaufte Teil, geklaut sein sollte. Findet man so den neuen "Besitzer" schneller.
