Adaptive Cruise Control nachrüsten
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 Antworten
Index C ist Nachfolger von Index A und für den vFL. Da ist irgendwas anders mit der Kommunikation auf dem CAN-Bus als bei Index B.
@spuerer schrieb am 19. Mai 2021 um 20:00:08 Uhr:
das liegt u.a. am Motorstg ; FL stg sind auch nicht im vor FL kompatibel (bus technisch)
Danke für die Info.
Was zahlt man ungefähr für so ein gebrauchtes Gerät?
Minimum 200 €.
Sei dort sehr vorsichtig, es sind viele gestohlene Stg im Umlauf. Diese bekommt man nicht angelernt, stattdessen gibt‘s ne Anzeige!
daher immer vom Händler und mit Rechnung; alles andere würde ich auch hier vor Ort nicht freischalten (Komponentenschutz)
@darklordjr8 schrieb am 20. Mai 2021 um 17:08:36 Uhr:
Minimum 200 €.Sei dort sehr vorsichtig, es sind viele gestohlene Stg im Umlauf. Diese bekommt man nicht angelernt, stattdessen gibt‘s ne Anzeige!
Jetzt bin ich ein bisschen irritiert, ich habe nämlich heute ein Radarsensor gefunden. Der Verkäufer meint das Gerät hätte kein Komponentenschutz. Jetzt weiß ich nicht ob das Teil bereits freigeschaltet ist oder nicht!
@Scotty18
Ich werde dein Rat folgen und das Gerät beim Händler kaufen soweit ich ein gutes Angebot finde.
Danke euch
Ich wollte noch fragen was der Unterschied zwischen beide Radarsensoren 8K0907561B (Version H09 0090, H09 0100) und 8R0907561A (H11 0100) ist?
Ich sehe da nur die Hardware Version ist anders, ich meine ich hätte irgendwo gelesen, dass man den 8R0907561A zusammen mit dem 8R0 STG FL in einem 8k5 verwenden kann..
Stimmt das so? Kann ich das in meinem Fall in mein Auto einbauen? Ich suche die ganze Zeit nach einem pasenden Radarsensor.
Danke
Guten Morgen,
ich habe noch eine Frage was das Lenkrad angeht. Hier ist das VCDS Log:
Fahrzeugtyp: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D
72
Fahrzeug-Ident.-Nr.: WAUZZZ8K5FAXXX Kilometerstand: 130710km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
42-Türelektr. Fahrer -- Status: Fehler 0010
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: Fehler 0010
53-Feststellbremse -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CJCD) Labeldatei:. DRV\03L-906-018-CGL.clb
Teilenummer SW: 03L 906 018 SK HW: 03L 906 018 JL
Bauteil: R4 2.0l TDI H25 9978
Revision: 45H25---
Codierung: 12034012243401080000
Betriebsnr.: WSC 15188 002 1048576
ASAM Datensatz: EV_ECM20TDI01103L906018SK 003005
ROD: EV_ECM20TDI01103L906018SK.rod
VCID: 0501241384212FA3F0-8050
Kein(e) Fehlercode(s) gefunden.
Readiness: 0 0 0 0 0
Adresse 02: Getriebe (J217) Labeldatei:| DRV\0AW-927-156.clb
Teilenummer SW: 8K5 927 155 K HW: 0AW 927 156 K
Bauteil: 0AW_20TDI_RdW H08 0004
Revision: --H08--- Seriennummer: 0000000004
Codierung: 000002
Betriebsnr.: WSC 06325 000 00000
ASAM Datensatz: EV_TCMVL381 A02433
ROD: EV_TCMVL381.rod
VCID: 408FF507DB83CA8B83-8014
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\8K0-907-379-V2.clb
Teilenummer SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Bauteil: ESP8 front H09 0020
Revision: -------- Seriennummer: --------------
Codierung: 179DCC01
VCID: 071D2E1BB62D3DB382-8052
1 Fehler gefunden:
00446 - Funktionseinschränkung durch Unterspannung
002 - unterer Grenzwert unterschritten - Sporadisch
Umgebungsbedingungen:
Fehlerstatus: 00100010
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 125
Kilometerstand: 130697 km
Zeitangabe: 0
Datum: 2021.05.31
Zeit: 17:54:03
Hex Wert: 0x00C0
Hex Wert: 0x0006
Hex Wert: 0x1232
Hex Wert: 0x1694
Hex Wert: 0x0000
Adresse 05: Zugangs-/Startber. (J393) Labeldatei:. DRV\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 KH HW: 8K0 907 064 KH
Bauteil: BCM2 2.0 H15 0711
Revision: 00002001
Codierung: 05A24000000000000000
VCID: 000F350793030A8BC3-8054
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:. DRV\8Kx-820-043-3Z.clb
Teilenummer SW: 8K1 820 043 BB HW: 8K1 820 043 BB
Bauteil: KLIMA 3 ZONEN H04 0123
Revision: C1000000 Seriennummer: 01160320150776
Codierung: 342002E000
VCID: 69D908A38079EBC374-803C
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Bauteil: BCM1 1.0 H16 0103
Revision: 08016001 Seriennummer: 00001033555401
Codierung: 260000108034AFC00081400300001D0D0F1C670826090201000008004401020100000020000000
VCID: 78FF5DE7CBD3424BFB-802C
Subsystem 1 - Teilenummer SW: 8K1 955 119 B HW: 8K1 955 119 B Labeldatei: DRV\1KX-955-119.CLB
Bauteil: MITSUBA160215 H19 0461
Seriennummer: 1502120603123
Codierung: 004577
Subsystem 2 - Teilenummer SW: 8U0 955 559 C HW: 8U0 955 559 B Labeldatei: DRV\8U0-955-559.CLB
Bauteil: G397_RLFS H06 0004
Seriennummer: 62379565
Codierung: 02006C
Subsystem 3 - Teilenummer SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Bauteil: E1 - LDS H03 0031
Seriennummer: 00000000001103150534
Subsystem 4 - Teilenummer SW: 4H0 907 658 HW: 4H0 907 658
Bauteil: AQ_Hum_Sensor H03 0003
Seriennummer: 41588A97000000000001
Adresse 15: Airbag (J234) Labeldatei:| DRV\8K0-959-655.clb
Teilenummer SW: 8K0 959 655 N HW: 8K0 959 655 N
Bauteil: AirbagVW-AU10 H48 0610
Seriennummer: 003KFDC6GZ90
Codierung: 30524435363030303030554A304C384B3053
ASAM Datensatz: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489FED27F3B3F2CB4B-801C
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 6334MSME502874201
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 6344MSME4F4A281DV
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 6352QSME074E4576O
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 6362QSME3E4E1650P
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 63732SME08584842
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 63832SME0B580E6CD
Adresse 16: Lenkradelektronik (J527) Labeldatei:. DRV\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Bauteil: Lenks.Modul H03 0003
Revision: C0062331 Seriennummer: 90862OCL0005V
Codierung: 000017
VCID: 489FED27FBB3F2CB4B-801C
Bauteil: E221 - MFL H03 0004
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:. DRV\8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 932 D HW: 8K0 920 932 D
Bauteil: KOMBIINSTR. H36 0567
Revision: 00100000 Seriennummer: 61-53KJ3G
Codierung: 13A6100003010008000000
VCID: 306FA5C763235A0B73-8064
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\8T0-907-468.clb
Teilenummer SW: 8R0 907 468 N HW: 8R0 907 468 C
Bauteil: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Seriennummer: 3041Y15309059E
Codierung: 80CF07FF00
VCID: 4A9BD72FE5BF00DB5D-801E
Subsystem 1 - Teilenummer SW: 8T0 915 181 HW: 8T0 915 181
Bauteil: J367-BDMHella H03 8041
Seriennummer: 7740886003
Subsystem 2 - Teilenummer SW: 8K0 959 663 HW: 8K0 959 663
Bauteil: J532_DCDCStab H17 0042
Seriennummer: 15071002939011200181
1 Fehler gefunden:
00384 - Optischer Datenbus
011 - Unterbrechung - Sporadisch
Fehlerstatus: 00101011
Fehlerpriorität: 5
Fehlerhäufigkeit: 1
Verlernzähler: 105
Kilometerstand: 130291 km
Zeitangabe: 0
Datum: 2021.05.11
Zeit: 15:39:53
Binärwert: 10000
Spannung: 11.90 V
Anzahl: 7
Binärwert: 00000
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:. 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 R HW: 8K0 959 793 P
Bauteil: TSG FA H02 0510
Revision: Seriennummer: 0000139786787
Codierung: 011C12204000410001
VCID: 4FADC63B1EDD25F30A-801A
2 Fehlercodes gefunden:
00109 - Lampe für Spiegelblinker Fahrerseite (L131)
012 - elektrischer Fehler im Stromkreis - Sporadisch
Fehlerstatus: 00101100
Fehlerpriorität: 3
Fehlerhäufigkeit: 29
Verlernzähler: 119
Kilometerstand: 130240 km
Zeitangabe: 0
Datum: 2021.05.07
Zeit: 18:03:25
00920 - beheizbare Außenspiegel (Z4/Z5)
Fehlerstatus: 01101100
Fehlerpriorität: 3
Verlernzähler: 86
Kilometerstand: 130591 km
Zeitangabe: 0
Datum: 2021.05.25
Zeit: 17:02:48
Adresse 44: Lenkhilfe (J500) Labeldatei:| DRV\8K0-909-144.clb
Teilenummer SW: 8K0 909 144 P HW: 8K0 909 144 B
Bauteil: RCEPS H43 0510
Revision: 00001000 Seriennummer: 0025552058
Codierung: 100000000001
Betriebsnr.: WSC 06324 000 00000
ASAM Datensatz: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E738BFFA177BC7BF1-806A
Adresse 46: Komfortsystem (J393) Labeldatei:. DRV\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0362691479
Codierung: 013A0E20A0B930018320023680000047
Subsystem 1 - Teilenummer: 8K0 951 177
Bauteil: DWA-Sensor H02 0040
Subsystem 2 - Teilenummer: 1K0 951 605 C
Bauteil: LIN BACKUP HO H05 1501
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:. 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 R HW: 8K0 959 792 P
Bauteil: TSG BF H02 0510
Revision: Seriennummer: 0000140802409
VCID: 4E93DB3F19D72CFB01-801A
1 Fehler gefunden:
00110 - Lampe für Spiegelblinker Beifahrerseite (L132)
Fehlerpriorität: 3
Fehlerhäufigkeit: 23
Verlernzähler: 120
Zeitangabe: 0
Datum: 2021.05.07
Zeit: 18:03:33
Adresse 53: Feststellbremse (----) Labeldatei: DRV\8K0-907-801-V2.clb
Teilenummer SW: 8K0 907 801 N HW: 8K0 907 801 J
Bauteil: EPB-4 H02 0005
Revision: -------- Seriennummer: 10000000516645
ASAM Datensatz: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B87EFBD5F905BCD-806E
Adresse 56: Radio (R) Labeldatei:. DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G0 035 056 J HW: 4G0 035 056
Bauteil: Radio U STD H60 0133
Revision: AB001007 Seriennummer: 230CL0F3302554
Codierung: 010003020100000001
VCID: 285F4DA75BF312CBAB-807C
Adresse 5F: Informationselek. I (J794) Labeldatei:. DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 8R1 035 670 J HW: 8R1 035 670 J
Bauteil: H-BNT-EU H49 0897
Revision: -------- Seriennummer: 516EV0G7524310
Codierung: 0F0100010006A1ED0180AB5E00000403040000000000000000
Betriebsnr.: WSC 18117 004 1048576
VCID: 3A7B87EFB55F905BCD-806E
Subsystem 1 - Teilenummer: 8R0 060 884 CH
Bauteil: EUR 2014 2004
Subsystem 2 - Teilenummer SW: 8R0 919 604 A HW: 8R0 919 604 A
Bauteil: DU7 High H42 0104
Seriennummer: A130CS0F3296217
Subsystem 3 - Teilenummer SW: 8T0 919 611 L HW: 8T0 919 611 C
Bauteil: E0380 Bedient H02 0030
Seriennummer: 00000002171263
Subsystem 4 - Teilenummer: 8R0 060 961 G
Bauteil: CD-Database 5950
00862 - Antenne für Navigation (GPS) (R50)/(R52)
Fehlerpriorität: 5
Fehlerhäufigkeit: 1
Verlernzähler: 105
Zeitangabe: 0
Datum: 2021.05.11
Zeit: 15:14:30
Spannung: 12.00 V
02612 - Audioleitung Adapterset
Fehlerpriorität: 5
Fehlerhäufigkeit: 1
Verlernzähler: 105
Zeitangabe: 0
Datum: 2021.05.11
Zeit: 15:14:30
Spannung: 12.10 V
Adresse 62: Türelektr. hi. li. (J388) Labeldatei:. 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 G HW: 8K0 959 795 D
Bauteil: TSG HL H01 0510
Revision: Seriennummer: 0000141147364
Codierung: 010C12204000210001
VCID: 4683E31FF1A7E4BBB9-8012
Adresse 69: Anhänger (J345) Labeldatei:. DRV\8K0-907-383.clb
Teilenummer SW: 8K0 907 383 E HW: 8K0 907 383 E
Bauteil: Anhaenger H12 0100
Revision: 1A001001 Seriennummer: 00000361666413
Codierung: 010D000000000000
Betriebsnr.: WSC 25381 000 00000
VCID: 366393DF8147743B29-8062
Adresse 6D: Heckklappe (J605) Labeldatei: 8K9-827-851.clb
Teilenummer SW: 8K9 827 851 C HW: 8K9 827 851 C
Bauteil: J605 Master H53 0330
Revision: -------- Seriennummer: 8K9827851C
VCID: 3E738BFFA977BC7BF1-806A
Subsystem 1 - Teilenummer SW: 8K9 827 852 C HW: 8K9 827 852 C
Bauteil: J756 Slave H53 0330
Seriennummer: 8K9827852C
Adresse 72: Türelektr. hi. re. (J389) Labeldatei:. 8K0-959-795.clb
Bauteil: TSG HR H01 0510
Revision: Seriennummer: 0000141145660
Ende----------------------------(Dauer: 03:42)-----------------------------
Bei mir ist das 8K0 953 568 Q eingebaut, ich wollte ACC und Lane Assist nachrüsten, jetzt habe ich das so verstanden, dass ich ich ein 8K0 953 568 G /M nehmen kann, aber das bezieht sich nur auf den Wickelfederring.
Für die 2 Schalter (ACC-Distance) und (Lane-Assist) muss ich noch die Hebel haben, ich habe schon gesucht aber ich weiß nicht welche Teilenummer ich da haben muss. Ich habe Z.B das hier gefunden bin mir aber nicht sicher.
https://allegro.pl/.../...zespolony-a4-b8-a5-q5-4g8953502al-7485336763
https://allegro.pl/.../...asma-audi-a4-a5-a6-a7-4g8953502ah-9100259134
https://allegro.pl/.../...-q5-tasma-8k0953568m-4g8953502al-10155129359
Passt einer davon in meinem Auto?
Danke
Es macht keinen Spaß, Informationen für dich herauszusuchen, die andere Foren-Mitglieder schon mit viel Aufwand erarbeitet haben!
Nutze bitte die Suchfunktion.
Hier die Antwort auf deine Frage…
https://www.motor-talk.de/.../...baut-geld-verbrannt-t2515251.html?...
[Edit: Link war falsch]
Ich habe doch die Suchfunktion benutzt, leider habe ich aber nix dazu gefunden. In deinem Link ist der Beitrag aus dem Jahr 2011 und mein Auto ist 2015, also FL, deshalb war ich mir nicht sicher ob die Teile passen. Ich will nix falsches kaufen und danach viel mehr fragen müssen. Trotzdem danke für deine Antwort, obwohl du ein bisschen genervt warst.
Meines Wissens ist ein Forum da um hilfe zu suchen und fragen zu stellen, mehr wollte ich auch nicht haben.
Danke
Übersicht Lenksäulensteuergerät/Schleifring Varianten B8 Audi A4 / A5 / Q5:
Wickelfeder mit Elektronik und Lenkwinkelsensor:
Firma KOSTAL:
8K0 953 568 B : GRA, MUFU, FIS (nur bei A5 MJ 2008 bis 09/2007, anderer Airbaganschluss als bei den neueren, das gilt auch für ohne Index bis Index C, passt auf keinen Fall in den A4 8K!)
8K0 953 568 D : FIS, kein GRA, kein MUFU
8K0 953 568 E : GRA, FIS, kein MUFU!
8K0 953 568 F : GRA, MUFU, FIS, kein ACC!
8K0 953 568 G : GRA, ACC, MUFU, FIS,...
FL:
8K0 953 568 J : FIS, kein GRA, kein MUFU
8K0 953 568 K :GRA, FIS, kein MUFU!
8K0 953 568 L : GRA, MUFU, FIS, kein ACC!
8K0 953 568 M : FIS, GRA, MUFU,ACC
Firma VALEO (ab 1/2011):
8R0 953 568 H : FIS, kein GRA, kein MUFU
8R0 953 568 J : GRA, FIS, kein MUFU!
8R0 953 568 K : MuFu-tauglich, GRA, FIS, kein ACC
8R0 953 568 M : GRA,FIS,MuFu, ACC
FL:
8R0 953 568 N : FIS, kein GRA, kein MUFU
8R0 953 568 P : FIS, GRA, kein Mufu
8R0 953 568 Q : GRA, MUFU, FIS, kein ACC!
8R0 953 568 R : Mufu; GRA; ACC; Side Assist; FIS
8R0 953 568 S : FIS, GRA, MUFU, ACC
Lenkstockhebel und Lenksäulenstg müssen vom gleichen Hersteller sein!
8R0...=VALEO
8K0...=KOSTAL
4G0...=VALEO
4G8...=KOSTAL
Welcher Hersteller verbaut ist, ist nur durch Auslesen oder Ausbau erkenntlich!
Die Variante 8K0 953 568 G,M und 8R0 953 568 M,S sind die mit allen Funktionen, 8K0 953 568 M und 8R0 953 568 M,S werden über den Ersatzteilweg für den A4,A5,Q5 angeboten.
Die Steuergeräte vom FL passen auch im Vorfacelift, umgekehrt nicht, da einige Funktionen nicht unterstützt werden (z.B. Info-Taste)
@Travi:
Die Bilder hast Du Dir doch auch angeschaut in deinen Links? Da siehst du doch die Unterschiede...Kleiner Tipp: Heckwischer...
