Adaptive Cruise Control nachrüsten
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 Antworten
@spuerer schrieb am 4. Juni 2021 um 11:01:45 Uhr:
@Travi:Die Bilder hast Du Dir doch auch angeschaut in deinen Links? Da siehst du doch die Unterschiede...Kleiner Tipp: Heckwischer...
Ja vielen Dank für dein Tipp. Ich nehme das auf dem ersten Link, das sollte dann passen 😛
Deshalb finde ich dieses Forum hier das beste überhaupt um Hilfe zu suchen.
Danke euch allen.
Beim ersten ist kein Steuergerät (Wickelfeder) dabei...
@spuerer schrieb am 4. Juni 2021 um 11:17:38 Uhr:
Danke habe ich gerade gemerkt und wollte das ändern 🙂
sorry ich bins nochmal. Ich habe das Problem, dass ich bis heute nicht die passende Luftführungsgitter (Rechts und Links) für mein Auto finden kann. Laut Teilenummer sollte ich 8K0 807 682K 01C (Rechts) kaufen. Das Teil ist nirgendwo zu finden. Wenn ich die Nummer eingebe dann kommen welche ohne das Loch für ACC. Kann mir jemand helfen und sagen ob es eine andere Lüftungsgitter auch passen wird ohne lange suchen zu müssen. Ich habe soweit alles montiert und warte nur auf die Lüftungsgitter.
Vielen Dank
Vielen Dank
8k0 807 682 b01C ist die Teilenummer. Ist schwierig zu finden. Habe ACC auch nachgerüstet und habe auch lange suchen müssen. Kann auch sein, dass ich sie damals direkt bei Audi bestellt habe. Blende ist ja net so teuer
Ich musste sie Anfang 2019 auch bei Audi kaufen, hat 46,35 € gekostet.
8K0 807 682 B 01C - für Fahrzeuge ohne S-Line Exterieur
und mit sline ? die Teilenummer konnte ich nämlich damals nicht finden
@flying_horst schrieb am 3. August 2021 um 12:06:17 Uhr:
VFL
8K0 807 682 B 01C - Fahrzeuge ohne S-Line Exterieur
8K0 807 682 E 01C - Fahrzeuge mit S-Line Exterieur
FL
8K0 807 682 L 01C - Fz ohne S-Line Exterieur
8K0 807 682 N 01C - Fz mit S-Line Exterieur (2011-2012)
8K0 807 682 Q 01C - Fz mit S-Line Exterieur (2012-…)
8K0 807 682 AA 01C - Fz mit S-Line Competition Plus
thank you. sicher das die teilenummer vom VFL ist? die müssten doch normalerweise 3 streifen haben
@flying_horst schrieb am 3. August 2021 um 12:13:04 Uhr:
Hab den Post oben nochmal ergänzt.
Beim VFL hatte S-Line zwei Streben, non-S Line hatte drei. Google mal 😉
Ich danke Euch. Ich werde morgen bei einem Audi Händler in der Nähe versuchen. Ich habe nämlich bei meinem Händler versucht leider ohne Erfolg.
Danke nochmal
Ich habe heute Morgen bei Audi angerufen und das Teil wird nach Mittag geliefert kostet nur 33,90€ inkl. Mwst... Super Sache.
@Travi schrieb am 4. August 2021 um 09:19:21 Uhr:
Ich muss das korrigieren, es sind 87,90€ und nicht nur 33,90€. Ich wollte gestern das Teil abholen, dann habe ich festgestellt, dass es um das normale ohne ACC Loch handelte, dann habe ich das richtige Teil für 87,90€ bestellt. Die richtige Bezeichnung laut meiner Rechnung:
8K0 807 682 L 01C obwohl FZ mit S-Line Exterieur (2012-2015)
Ohje Mist, du hast Recht! Ich habe die Codes für S-Line und nicht-S-Line vertauscht. Korrigiert ist die Liste also:
VFL
FL
8K0 807 682 L 01C - Fz mit S-Line Exterieur
8K0 807 682 N 01C - Fz ohne S-Line Exterieur (2011-2012)
8K0 807 682 Q 01C - Fz ohne S-Line Exterieur (2012-…)
@spuerer schrieb am 19. Mai 2021 um 20:00:08 Uhr:
Index C ist Nachfolger von Index A und für den vFL. Da ist irgendwas anders mit der Kommunikation auf dem CAN-Bus als bei Index B.
Aus aktuellem Anlass:
Ich kann also für meinen MJ 2010 vFL (mit ACC ab Werk aber Sensor defekt) nur folgende Sensoren hernehmen:
8K0907561A
8K0907561C
Oder gibt's auch noch andere?
Was ist z.B. mit Sensoren ohne Kennbuchstaben, kann ich die auch verwenden?
