ACC Upgrade
Wer von Euch hat Interesse an einem Upgrade?
ACC bis 200km/h, falls nur ACC Low verbaut ist.
Habe die Nachrüstung schon mehrfach am Octavia 5E, Leon 5F und Golf7 durchgeführt.
Für alle die ACC Low haben und neugierig sind, einfach eine PN an mich.
Gruß Trust2k
Gruß Trust2k
52 Antworten
Thanks for the info
I don't have Odis/Geko, only vcds 18.2
I don't have any protection in ACC module
Those are my errors, but all related to miss codification
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 09061503212718
Coding: 00001B01FE033B
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3A7B84EABD5F9F9416-806E
6 Faults Found:
1807 - No Enable Indentifications Active
B2032 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
Control Module temperature: 25 °C
Voltage terminal 15: 12.4 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1024 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
0284 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1027 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1028 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 47128 km
Date: 2018.03.12
Time: 17:58:31
"1807 - No Enable Indentifications Active "
As I said before, this is only possible with ODIS etc.
@hadez16 schrieb am 13. März 2018 um 12:31:44 Uhr:
"1807 - No Enable Indentifications Active "As I said before, this is only possible with ODIS etc.
I'm from Portugal, what is the best solution for me?? Going to Bosh service or only in Audi?
Thanks
The best solution is subscribe to the english Ross-Tech Forum and seek the right threads about that topic. The people who know how to solve this are active there.
moin,
habe bei mir das Pre Sense Front verbaut kann ich das irgendwie umrüsten auf acc?
Hast du denn den großen Radarsensor mitten unten im Grill?
Also reines Interesse von meiner Seite, weil ich eigentlich dachte, dass man Per Sense Front auch nur in Verbindung mit ACC bekommt.
der a3 ist von 11/2013 kann ich dir erst montag sagen dann hole ich den ab^^
Also wenn er Pre Sense Front hat, dann muss er (soweit ich weiß) den großen Radarsensor haben.
Und meiner Meinung nach hat er dann auch bereits ACC.
Aber ich lasse mich auch gerne eines besseren belehren.
@Hoaschter schrieb am 7. September 2019 um 17:53:13 Uhr:
Das ist leider so nicht richtig. Hab bei meinem a3 auch pre sense front, aber acc müsste ich dennoch nachrüsten mit dem auge, da bei dem flachen sensor wohl selbst acc low nicht geht 🙂
Ok, dann sorry, für die falschaussagen 😉
@sh1n schrieb am 7. September 2019 um 18:23:44 Uhr:
Aber ich lasse mich auch gerne eines besseren belehren.Das ist leider so nicht richtig. Hab bei meinem a3 auch pre sense front, aber acc müsste ich dennoch nachrüsten mit dem auge, da bei dem flachen sensor wohl selbst acc low nicht geht 🙂
was genau musstest du nachrüsten?
@tony130 schrieb am 8. September 2019 um 01:42:03 Uhr:
Das große acc auge (Long range Radar von bosch), die bedieneinheit am Lenkrad und wie mir gesagt wurde auch Steuergerät und Kühlergrill. Gekostet hätte das ganze in meinem fall rund 850 (je nach wie günstig du an gebrauchte teile rankommst). Habs mir aber nicht einbauen lassen, da ich das auto hätte vor ort lassen müssen.
@sh1n schrieb am 8. September 2019 um 10:44:40 Uhr:
Welches Steuergerät wurde Dir da genannt?
Ich habe ACC Komplett von null nachgerüstet.
Wichtig ist das du das passende ABS hast. Könnte aber dank Per Sense schon verbaut sein.
Die richtigen ABS Radsensoren hinten.
Hebel am Lenkrad.
Und entsprechend muss alles codiert werden. Dir wird im Tacho die volle Anzeige fehlen. Was aber nicht weiter schlimm ist.
Natürlich den ACC Sensor der ja das Steuergerät an sich schon ist. Dieser muss dann freigeschaltet werden „komponentenschutz“
Auch nicht zu vergessen die Kalibrierung des Sensors.
könnt ihr mir die Teilenummern nennen das wäre hilfreich danke
@tony130 schrieb am 8. September 2019 um 12:27:47 Uhr:
Ich teile dir jetzt die nummern mit welche mir vermittelt wurden, ist also gut möglich das es bei dir abweichen kann, weil ich bis auf acc alle assistenzsysteme habe.
Abs: WHT003864A
Acc sensor: 5Q0907541H
Hebel: 8V0953502BT
