Spurverbreiterung
Audi A3 8V
Da ich meinen A3 nächste Woche bekomme, möchte ich auch gleich eine Spurverbreiterung einbauen.
Da ich 0,0 von dem Ahnung habe, meine frage an euch:
Welche sind empfehlenswert und eventuell einen link oder Werkstatt um Ingolstadt
Die sollen auch nicht voll breit sein, etwas dezent...
Danke schon mal
Oz
Original geschrieben von JT30
Wo sind die Bilder?!?
So,....hier nun endlich ein paar Bilder von meinem A3 mit den H&R Verbreiterungen.
Vorne ohne Verbreiterungen,hinten 10 mm pro Rad.
525 weitere Antworten
525 Antworten
PS: I found a topic on audi-sport.net, but they all use 15mm front and 20mm rear, like these examples:
https://www.audi-sport.net/.../#post-2253626
Or do those stock 19" wheels have a different ET? (not 7.5j et51)
@Tuttivini schrieb am 13. Juni 2019 um 14:22:41 Uhr:
Actually those are 18“ at least on the grey one. But they should be 19“. I didn’t now that those are also available in 18“.
The 19“ are 8x19 ET 49.
If you like I can show you a photo of 8x19 ET 45 with 15mm on the rear.
So 15mm spacers with 8x19 ET 45 (ET30 with the spacer) is definitely to much. Even it’s wider anyway, because of the wheel dimension (7,5j to 8j).
.jpg
Bought 4 x H&R 10mm spacers today, second hand, for a good price.
Going to install them on the front and try the other 2, placed on each other (so 20mm total) with longer bolts, on one rear side.
No, not to drive, just to have al look at how 20mm looks at the rear.
If it looks good, I sell the 2 10mm ones ( and keep the two on the front) and buy 20mm ones.
If it looks bad/sticks out, I'm going to buy 15mm ones on the rear :-)
The ones I bought are H&R Trak+ Dr type spacers, partnummer 2055571
But I see they also sell 2055571A and 2055571B versions - > something to do with the INNER WHEEL BEVEL / OUTER SPACER BEVEL, which is different, like 4.0x45 degrees, 6.5x45 degrees or 7.0x45degrees?!?
What do our A3's need? I don't understand...
http://www.trakplus.com/trakguidelines/
And a question about lowering my E-tron:
I always looked at the Eibach Pro kit, 30mm front and 35mm rear,
But what about H&R Sport lowering springs?
They should lower it 45mm (better look?) :
https://www.ecstuning.com/.../
Any experiences looks and handing?
Ich fahre eine A3 8VS Limo und habe mir vor ein paar Tagen eine Spurverbreiterung von H&R 30 mm an der HA bestellt.
Meine Reifen haben die Maße 8 J x 19, 235/35 R 19 und eine ET von 49mm.
Die Spurplatten: H&R Spurverbreiterung ABE DR 30mm HA oder VA.
Kann ich die problemlos montieren und mit ABE mit der originalen Rad Reifen Kombination muss ich auch nichts eintragen lassen oder?
Wenn es diese Artikelnummer B55573-15 ist musst du nichts eintragen wenn du die originale Radreifen Kombi sowie das original Fahrwerk hast.
Hast du die B3055571 musst du zum TÜV
@Lecavalier81 schrieb am 4. Mai 2020 um 16:24:37 Uhr:
Danke erstmal 🙂. Ja diese habe ich mir bestellt. Also sollten die auch problemlos passen oder, alles ist noch im Originalzustand.
Kommando zurück...sehe gerade bei 19 Zoll steht die Auflage A1...musst also doch zum TÜV...kostet aber nicht die Welt...glaube so 40€
@Lecavalier81 schrieb am 4. Mai 2020 um 17:19:51 Uhr:
Alles klar, danke. Leider doch nicht so einfach wie gedacht ;D
@Julian_99 schrieb am 4. Mai 2020 um 15:03:04 Uhr:
Zeig mal Danach ein Foto. Will mir auch Platten kaufen.
Ich hab meine H&R nun auch bekommen, 16mm vrne und 40mm hinten, mit den originalen 19er ists hinten schon sehr breit, aber ich werds so lassen.
@Boardi05 schrieb am 5. Mai 2020 um 14:13:59 Uhr:
Könntest du mal bitte Bilder reinstellen?
Hab wieder die winterräder drauf, aber auf dem handy irgndwo glaub ich sind bilder drauf.
Doch n paar Schnappschüsse gmacht. In 4 Wochen sollten die Winterschlappen fertig sein, dann kommen die Sommerröder wieder drauf, dann werd ich mal bissl Zeit nehmen zum Bildermachen.
Verbaut ist das Sportfahrwerk (nicht S-Line)
20200501
20200501
20200501
+3
@Boardi05 schrieb am 5. Mai 2020 um 20:17:30 Uhr:
Sieht gut aus, danke!
mal ein Update von meinem S3 , bin auf 20Zoll umgestiegen.
