Led Rückleuchten Highline Nachrüsten VCDS Codierung nötig?
VW Passat B8
Möchte die Highline Rückleuchten nachrüsten , muss man die dann noch Codieren ?
Vw Passat B8 Var 05/2015 Led Scheinwerfer vorne (keine voll Led)
Und Bitte ohne warum und wieso
Danke an die, die Helfen können
354 Antworten
@Redadair13 The complete coding for left hand drive can be found on page 12 (17.06.20). I dont know the differences for right hand drive! Sorry! Br yaabbaa
@yaabbaa schrieb am 13. September 2021 um 12:14:57 Uhr:
Coding will be very much the same except for the rear fog light. You know how to code fog light from Yaabbaa's description, you just need to figure out which lamp/channel is rear right inside lamp.
In terms of instructions I can only provide a PDF scan of 3G9 052 400 which you obviously have and there should be no problem with it...
Thanks for the reply guys, I have just pulled out module c from the bcm, has anyone got a diagram or know where pin 6 location is please, no diagrams in instructions and can't find it on Google, thanks again for your help.
Page 11, Yaabbaa's post....
Hi after fitting the wire into the bcm, my lights are all over the place, with ignition on, one side brake light is on and the opposite front side light is on, I'm going to take it all back off and put my original comfort led,s back in.
Have you done the coding (changing the adjustment channels) yet?
That's normal. You need to do the coding now.
Hi I've got vagcom but don't know what to do, really don't understand the instructions or what modules to go into
Central Electronics - Security Access - Adaptions. You should know at least some sort of minimum about it. Otherwise you could end up destroying your car...
Do i then just go through the channels and adjust as necessary thanks
Nearly there, what does NIX mean below?
18BLK (turn signal rear left) -> NIX
19BLK (indicator rear right) -> NIX
20BR (brake light left) -> NIX
21BR (right brake light) -> NIX
Yes. Make changes according to Yaabbaa's instructions.
Nix .... Nothing to do ;-)
Hi all stuck on these, as the drop down box is mainly in German, if some has time could you number them in the drop down menu please ie, 4th down or 6th down.
17TFL
ENG116953 -ENG116569
23SL
ENG116959 - ENG116316
24SL
ENG11690 -ENG116335
27NSL
ENG116963 -ENG116388
ENG116963 -ENG116396
28RFL
ENG116964 -ENG116407
Sorry to be a pain, thanks for your help.
It's OK was struggling to translate to English but found if I write what's on the vagcom in German then translate to English it works better
