Großbildschirm nachrüsten
Ist es möglich einen neuen bildschirm nachrüsten ? Ich habe jezt die kleine bildschirm und möchte gern grossere bildshirm haben?
42 Antworten
@Cartin schrieb am 3. Oktober 2020 um 15:18:58 Uhr:
Ich habe einen Bekannten das xentry habe. Kann er es tun?
Das musst du ihn fragen ;-)
Hi, I am from London, I have also changed my widescreen analogue to full digital, I already had command, this was also not plug and play, needed extra cables, and also cooling fan, and coding, cost was €3000 euros, brand new screen though.
I also traveled to Germany from London to retrofit multibeam headlights from hp headlights.
How far is Denmark from where you live
I live in Denmark
How much work and money did it cost to have multi beam? And is multi beam like ILS?
I was very lucky, I found a pair of brand new headlights on eBay Germany €1200 for the pair, the price was also very good, normally they are €600-€800 for one and that is used. Fitting with coding was €1000,.
It took him around 4 hours to complete the job, have to remove front bumper.
Yes ils is part of multibeam.
I had the w212 before with ILS and I’m not sure if I can get it on my w213 how do I recognizes if my car have prepared multi beam?
If you have multibeam, then it will be written inside the headlight,
If you have high performance headlights, then that will be written in the headlights
The difference is that they won’t have the ils function, and won’t have high beam assist, they are standard static led headlights.
If you do a search on the site, there are plenty of topics on the difference between High Performance headlights, and Multibeam, many people prefer the multibeam, as it has different functions, and also the light range is far greater then the High Performance, this was the main reason I changed over from High Performance, but many are also satisfied with the High Performance ones.
