Der neue
Mercedes G-Klasse
Das ist er dann wohl,,,er scheint Starrachsen zu haben, schönere Türtafeln, nur ein Facelift? Oder ganz neu ?
Second-Generation Mercedes-Benz G-Class Makes Spy Photo Debut
Lovers and haters of the legendary Mercedes-Benz G-Class are about to find out about a rather interesting piece of news regarding the boxy off-roader.
There have been plenty of rumors suggesting that Mercedes-Benz is working on a G-Class replacement, but these spyshots are the first proof that it is indeed the case. Lo and behold, the G-Wagen will soon be dead, long live the G-Wagen!
Before jumping to early conclusions and accuse us of showing you a plain ol' G-Class with some fancy camouflage, take a moment and observe the images in the adjacent gallery a bit closer. In fact, you can also compare the 2018 G-Class with a current model in a couple of photos.
Despite looking almost identical from the distance, the new G-Wagen is much wider, while the body seems to be a bit lower, despite featuring a similar ground clearance. In other words, the Bauhaus exterior design will be kept, but almost everything underneath that chiseled body will be all-new.
That said, at least the rear suspension looks like it continues to use a live axle system, although our untrained eyes think they've spotted some extra cylinders. This may translate in the addition of a pneumatic suspension system for the first time in a G-Class, giving owners the option of a higher or a lower ground clearance at the push of a button or a switch of a knob.
The interior will be all new, with most of the bits and bobs being borrowed from the latest E-Class (W213), including a gargantuan center display and massage seats. Fans of the ruggedness of the G-Wagen shouldn't fret, though, as the new model should keep the three locking differentials, as useless as they are for most of its current customers.
Despite the wider body, the addition of pneumatic suspension and plenty of extra safety gizmos, the 2018 G-Class will shed plenty of kilos, with the most recent estimates revolving around 400 kg (882 pounds). Parts of the new suspension and most of the body will switch to an assortment of high-strength steel and aluminum to achieve this hefty weight drop.
Engine wise, we are expecting an array of inline six gasoline and diesel engines, with the gasoline ones using a 48-Volt system to offer a mild-hybrid function. Fans of the good ol' V8 will not be disappointed either, as the Mercedes-AMG G63 will switch to a more powerful version of the same 4.0-liter V8 recently introduced on the G500 and G500 “squared.”
Given the overall look of the pre-production prototype spied by our friends at SB-Medien, this is not exactly a mule so Mercedes-Benz could be ready to unveil it as early as the second half of 2017, as a 2018 model year.
We're really trying to contain our excitement until we learn more about the G-Class Part Deux, but that doesn't mean you have to. Remember, this is a car that has been continuously produced using the same body molds for over 37 years now. Speaking of which, it goes without saying that the second generation will also be hand built by Magna in Graz, Austria, even though nothing official has transpired about this subject so far.
+5
Also Leute, keinen Katzenjammer. Der Neue bekommt alles, was (auch hier) gewünscht wurde. Alu Karosse = kein Rost! Breitere Sitze (wurde hier bemängelt), weniger Windgeräusch. Niedriger, d. h. weniger Verbrauch (siehe Beiträge - was verbraucht mein G). Aktuelles Infotainment - siehe mein iPhone xxy wird nicht erkannt. Wahrscheinlich gibt es sogar einen flachen Ladeboden und rausnehmbare Rücksitze. Natürlich alle selbstfahr Helferlein. Ins Parkhaus und in die Waschstrasse mit 1,9 m Begrenzung wird er auch passen. Die Vmax wird höher sein, der AMG wird die 250 km/h wohl knacken, das ist er schon der Konkurrenz schuldig. Gelände? Nun ja, leichter, drei Sperren, Untersetzung, im Offroad Park wird er schon jeden Range stehen lassen. Und Expedition? Macht mit einem +100 TEuro (Euro 6) Fahrzeug ohnehin niemand, ausser vielleicht einem Werksteam mit drei Unimog als Begleitfahrzeuge. Der geht wie geschnitten Brot und holt auch noch die ganzen Range Käufer ins Boot, welche die VerSUVung des aktuellen RangeRover nicht verkraften. Und wenn man auch weiterhin noch einen Worker bekommen kann: alles richtig gemacht!
OpenAirFan
1554 weitere Antworten
1554 Antworten
Eine Hybridform wird sicherlich kommen,. Hoffe ich,,
Kennt jemand das genaue Maß der Türöffnung am Kofferraum (Breite!)
wurde doch schon vom @Der_Landgraf gepostet
https://www.motor-talk.de/.../w463-2019-kofferraum2-i209371959.html
@Tomtr schrieb am 8. Februar 2019 um 21:30:50 Uhr:
Da stehen beinahe alle Maße - leider nur nicht die Breite der Türöffnung, nach der der TE gefragt hat...😉
Die Türöffnung liegt bei ca. 98cm, habe es selbst nachgemessen.
Danke Atelier14 Genau dieses Maß hab ich gebraucht! Hab erst einen Diesel bestellt und muss noch 1 Jahr warten.
@ESerieEins schrieb am 8. Februar 2019 um 22:08:14 Uhr:
Gern - auch wg. Hundebox?
Nein, werde mir aufs Dach von Alu Cab ein Dachzelt kaufen und in den Kofferraum eine Campingbox von Ququq. Mich hat der Abenteuervirus befallen.
Cool, welche Destinationen sind angedacht?
Schottland, Skandinavien, Georgien....dann mal sehen was mein Mut macht
Klingt aufregend 🙂 Würde ich auch wieder mal gern machen, aber nach einem Überfall in Kroatien habe ich etwas die Nase voll...
Du machst mir ja Mut! Was ist passiert?
Bisschen zu sehr offtopic 😉
Ich habe da schonmal woanders einen kleinen Bericht zu geschrieben, schicke ich dir später mal per pN.
Frage an die G63-"Treiber", die mit ihren Schätzchen unterwegs sein dürfen:
Kann im KI zusätzlich zu den Temperaturanzeigen für Kühlwasser und Motoröl auch die Temperatur des Getriebes angezeigt werden? (wie oder ähnlich dem angeh. Foto? )
G-ruß von ottogustav
Amg-sl63
@ottogustav schrieb am 18. Februar 2019 um 16:50:13 Uhr:
ja, wird angezeigt
Schnee kann er nicht....
54194c17-d77a-41aa-a4b8-63eeb79aff70
Aa25db92-d6f3-4f97-bff1-38db1b31615f
