Adaptive Cruise Control nachrüsten
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 Antworten
Ja, alles was größer als 0,8 ist bedeutet das er verstellt ist. Die ersten beiden Werte lösen den Fehler aus. Der Sensor muss entsprechend kalibriert werden.
I finished my Instrument Cluster.
After two days it's fully functional.
So it's doable/possible BUT it's not easy job. There are too many components. 23 LED's, 23 resistors, 3 IC, 12 transistors, and other components some of them extremly small. I saved all of them from damaged IC. So no place for errors.
Only one LED (for 45 Km/h) is not working and I have to check it but I will do that later 🙂
I used two ordinary ERSA 25W and 40W, 10X and 15X lupe, smd twezers, measuring instrument, NO-CLEAN WICK etc...
After two days it's fully functional.So it's doable/possible BUT it's not easy job. There are too many components. 23 LED's, 23 resistors, 3 IC, 12 transistors, and other components some of them extremly small. I saved all of them from damaged IC. So no place for errors.
Would be nice if you have some pictures of it... 🙂
Original geschrieben von Frederikclaes
Would be nice if you have some pictures of it... 🙂Zitat:
I took some with mu iPhone 4. You have mail 😉
Original geschrieben von Surfjenser
I think these photos would be enlightening for the whole audience. Can you publish them here?
I sent photos to Frederikclaes. But you can't see on these photos anything that can help you.
If you don't have really good working experience with smd components and if you are not ready to pay for new IC and all other costs that will follow do not attempt to make this mod! You can damage your Instrument Cluster easilly.
This is first and last time that I did something like this.
Next time I'll order ACC already installed.
Hopefully with new BOSCH 4th generation Radar Sensor with 6 beams 😉
habe meine ACC erfolgreich eingebaut und codiert. Funktion ist gegeben
Habe folgendes Problem das im STG 13 als fehler nicht angemeldet steht und im STG 19 Fehler 10 ( Falsch Codier steht ) kann mir jemand behilflich seine was ich Falsch gemacht habe ? Im STG 13 habe ich die Codierung von 00C7D9 auf 002B99 geändert. Aber leider auch ohne Erfolg.
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: nicht angemeldet 0001
14-Raddämpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
1B-Aktive Lenkung -- Status: i.O. 0000
20-Fernlichtassistent -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAKA) Labeldatei: 06E-907-551-CAK.clb
Teilenummer SW: 8K0 907 551 C HW: 8K0 907 551
Bauteil: 3.0T SIMOS84 H08 0005
Revision: --H08---
Codierung: 010C000C240F0A28
Betriebsnr.: WSC 06334 123 12345
ASAM Datensatz: EV_ECM30TFS0218K0907551C 001005
ROD: EV_ECM30TFS0218K0907551C.rod
VCID: 316F4A016039D0962BD-8064
Kein(e) Fehlercode(s) gefunden.
Readiness: 0010 0001
Adresse 02: Getriebe (J217) Labeldatei: PCI\0B5-927-156.clb
Teilenummer SW: 8K1 927 156 J HW: 0B5 927 156 F
Bauteil: 0B5 30TFSIRdW H10 0010
Revision: --H10--- Seriennummer: 0000000913
Codierung: 000001
Betriebsnr.: WSC 06335 000 00000
ASAM Datensatz: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3C716B35B77B2DFE88B-8069
Adresse 03: Bremsenelektronik (J104) Labeldatei: PCI\8K0-907-379.clb
Teilenummer SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Bauteil: ESP8 quattro H04 0060
Revision: -------- Seriennummer: --------------
Codierung: 29AD0A
Betriebsnr.: WSC 06334 000 00000
VCID: 820D55CD1D1F1B0E027-80D7
Adresse 05: Zugangs-/Startber. (J393) Labeldatei: PCI\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 CQ HW: 8K0 907 064 CQ
Bauteil: BCM2 2.0 H05 0435
Revision: 00002001
Codierung: 050200
VCID: 810F5AC1181900161BD-80D4
Subsystem 1 - Teilenummer SW: 8T0 959 754 AM HW: 8T0 959 754 AM
Bauteil: FBSAUDIB8 IDG H61 0072
Subsystem 2 - Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Bauteil: J764 ELV MLB H37 0042
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: Umleit. fehlgeschl.!
Teilenummer SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Bauteil: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Seriennummer: 01101120110042
Codierung: 66100000
VCID: 80095FC51313091E143-80D5
Adresse 09: Zentralelektrik (J519) Labeldatei: PCI\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 P HW: 8K0 907 063 P
Bauteil: BCM1 1.0 H30 0392
Revision: 10030001 Seriennummer: 00000001125157
Codierung: 260050914074AF313F01000300001D0D4F9CE74802010141000000
Betriebsnr.: WSC 06335 123 12345
VCID: 3C716B35BF7B2DFE88B-8069
Subsystem 1 - Teilenummer SW: 8K1 955 119 A HW: 8T1 955 119 Labeldatei: PCI\1KX-955-119.CLB
Bauteil: WWS 101111 H07 0070
Codierung: 00FD11
Subsystem 2 - Teilenummer SW: 8K0 955 559 HW: 8K0 955 559 Labeldatei: PCI\8K0-955-559.CLB
Bauteil: RLS H04 0003
Codierung: 025028
Subsystem 3 - Teilenummer SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Bauteil: E1 - LDS H03 0031
Adresse 10: Einparkhilfe 2 (J446) Labeldatei: PCI\8K0-919-475.clb
Teilenummer SW: 8K0 919 475 AA HW: 8P0 919 475 N
Bauteil: PARKHILFE 8K H01 0081
Revision: 11001001 Seriennummer: 12501130600056
Codierung: 11010D
VCID: 78F9B725CBC3C1DEAC3-802D
Adresse 13: Distanzregelung (J428) Labeldatei: PCI\8K0-907-561.clb
Teilenummer SW: 8K0 907 561 HW: 8K0 907 561
Bauteil: ACC2 H07 0080
Seriennummer: 00000000000000
Codierung: 002B99
Betriebsnr.: WSC 06745 128 38157
VCID: EFEB0C793E8D0666FD9-80BA
Adresse 14: Raddämpfung (J250) Labeldatei: PCI\8R0-907-364.clb
Teilenummer SW: 8R0 907 364 B HW: 8K0 907 364
Bauteil: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Seriennummer: 15101102840002
Codierung: 050181
VCID: 397F7221B04918D693D-806C
Adresse 15: Airbag (J234) Labeldatei: PCI\8K0-959-655.clb
Teilenummer SW: 8K0 959 655 L HW: 8K0 959 655 L
Bauteil: AirbagVW-AU10 H44 0610
Seriennummer: 003JMD0HCET0
Codierung: 30523435363030303030554A304C384B3053
ASAM Datensatz: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 468509DDF9B7672EEEF-8013
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 6334MSME661115722
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 6344MSME6611180DA
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 6352QSME0364284AE
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 6362QSME6D5E105CY
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 63732SME18643974+
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 63832SME3564545E3
Adresse 16: Lenkradelektronik (J527) Labeldatei: PCI\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 G HW: 8K0 953 568 G
Bauteil: Lenks.Modul H17 0014
Revision: -------- Seriennummer: 90372KK20001O
Codierung: 00003F
VCID: 3E75613DA9673FEEA6F-806B
Bauteil: E221 - MFL H02 0010
Adresse 17: Schalttafeleinsatz (J285) Labeldatei: PCI\8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 931 HW: 8K0 920 931
Bauteil: KOMBIINSTR. H12 0258
Revision: 00000000 Seriennummer: EJE57J3CC
Codierung: 030D1100B7000008000000
VCID: EBD318690A95FA46D11-80BE
Adresse 19: Diagnoseinterface (J533) Labeldatei: PCI\8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AJ HW: 8T0 907 468 L
Bauteil: GW-BEM 5CAN-M H10 0120
Revision: FC201059 Seriennummer: 5900F11A25041C
Codierung: 00C303
VCID: 891F42E12029485643D-80DC
Subsystem 1 - Teilenummer SW: 8T0 915 181 HW: 8T0 915 181
Bauteil: J367-BDMHella H03 8040
1 Fehler gefunden:
01044 - Steuergerät falsch codiert
000 - -
Freeze Frame:
Fehlerstatus: 01100000
Fehlerpriorität: 1
Fehlerhäufigkeit: 1
Verlernzähler: 140
Kilometerstand: 36773 km
Zeitangabe: 0
Datum: 2013.12.02
Zeit: 19:11:15
Freeze Frame:
Binärwert: 10111
Spannung: 11.80 V
Anzahl: 6
Adresse 1B: Aktive Lenkung (J792) Labeldatei: PCI\8K0-907-144.clb
Teilenummer SW: 8K0 907 144 E HW: 8K0 907 144 E
Bauteil: DYNAMIKLENK. H06 0580
Revision: 50001005 Seriennummer: --------------
Codierung: 840000
VCID: 316F4A016839D0962BD-8064
Adresse 20: Fernlichtassistent (J844) Labeldatei: PCI\8K0-857-511.clb
Teilenummer SW: 8K0 857 511 E HW: 8K0 857 511 A
Bauteil: FLA H04 0004
Revision: AA001002
Codierung: 02019164747464545425363E
VCID: 336340099225E286591-8066
Adresse 22: Allrad (J492) Labeldatei: 8K0-907-163.clb
Teilenummer SW: 8K0 907 163 A HW: 8K0 907 163 A
Bauteil: 4 Wheel Drive H13 0025
Seriennummer: 002610110001001
ASAM Datensatz: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E55517D7107CF6E36F-807B
Adresse 42: Türelektr. Fahrer (J386) Labeldatei: 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 M HW: 8K0 959 793 M
Bauteil: TSG FA H12 0357
Revision: Seriennummer: 0000121716871
Codierung: 011C12205000410001
VCID: 4A9D3DEDE5AF834E0A7-801F
Adresse 46: Komfortsystem (J393) Labeldatei: PCI\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0161900438
Codierung: 01000E2020B934958230023280000000
Subsystem 1 - Teilenummer SW: 8K0 959 591 B HW: 8K0 959 591
Bauteil: J245 PS150 H08 0043
Subsystem 2 - Teilenummer SW: 8K0 959 591 B HW: 8K0 959 591
Bauteil: J394 PS240 H08 0043
Adresse 47: Soundsystem (J525) Labeldatei: PCI\8T0-035-223-BOM.clb
Teilenummer SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Bauteil: DSP Prem H10 0190
Revision: 00010001 Seriennummer: 34804011264903
VCID: 7AFDAD2DF5CFD3CEDA7-802F
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei: 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 M HW: 8K0 959 792 M
Bauteil: TSG BF H12 0357
Revision: Seriennummer: 0000017542929
Codierung: 011C12205C00410001
VCID: 499F02E1E0A9885603D-801C
Adresse 53: Feststellbremse (J540) Labeldatei: PCI\8K0-907-801-V1.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0100
Revision: 00000003 Seriennummer: 00000001048810
Betriebsnr.: WSC 00000 000 00000
VCID: 34614315972BE5BE40B-8061
Adresse 55: Leuchtweitenreg. (J431) Labeldatei: Keine
Teilenummer SW: 4H0 907 357 B HW: 4H0 907 357 B
Bauteil: ....LWR12.... H02 0010
Seriennummer: 111106-0002-005
Codierung: 11726E1010028200
ASAM Datensatz: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5756717C01B4760F5-8078
Adresse 56: Radio (R) Labeldatei: PCI\4F0-035-0xx-56.clb
Teilenummer SW: 4G1 035 053 HW: 4G1 035 053
Bauteil: Radio U Basic H41 0051
Revision: AB001007 Seriennummer: 048J90BB085919
Codierung: 010003010000000001
VCID: DCB14BB5DF3B8DFE28B-8089
Adresse 5F: Informationselek. I (J794) Labeldatei: PCI\4E0-035-6xx-5F.clb
Teilenummer SW: 8T1 035 666 K HW: 8T1 035 666 E
Bauteil: H-BN-EU H52 0167
Revision: -------- Seriennummer: 483KC0B7746586
Codierung: 010100010206E9ED25000F1E000000030001
VCID: 428D15CDDD9F5B0EC27-8017
Subsystem 1 - Teilenummer: 8R0 060 884 N
Bauteil: EUR 2011 1205
Subsystem 2 - Teilenummer SW: 8R0 919 604 HW: 8R0 919 604
Bauteil: DU7 High H41 0104
Subsystem 3 - Teilenummer SW: 8T0 919 609 G HW: 8T0 919 609 G
Bauteil: E0380 Bedient H08 0100
Subsystem 4 - Teilenummer: 8R0 060 961 A
Bauteil: CD-Database 2712
Adresse 62: Türelektr. hi. li. (J388) Labeldatei: 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 F HW: 8K0 959 795 F
Bauteil: TSG HL H11 0357
Revision: Seriennummer: 0000018120668
Codierung: 010C12204000210001
VCID: 45870ED1CCB16C36E75-8010
Adresse 69: Anhänger (J345) Labeldatei: PCI\8K0-907-383.clb
Teilenummer SW: 8K0 907 383 E HW: 8K0 907 383 E
Bauteil: Anhaenger H09 0100
Revision: 1A001001 Seriennummer: 00000162618292
Codierung: 010D000000000000
Betriebsnr.: WSC 25397 000 00000
VCID: 3665791D8157F7AE7EF-8063
Adresse 6D: Heckklappe (J605) Labeldatei: PCI\4L0-910-945.lbl
Teilenummer SW: 8K9 827 851 A HW: 8K9 827 851 A
Bauteil: J605 Master H52 0330
Revision: -------- Seriennummer: 8K9827851A
Subsystem 1 - Teilenummer SW: 8K9 827 852 A HW: 8K9 827 852 A
Bauteil: J756 Slave H52 0330
Adresse 72: Türelektr. hi. re. (J389) Labeldatei: 8K0-959-795.clb
Bauteil: TSG HR H11 0357
Revision: Seriennummer: 0000018120607
Ende --------------------------------------------------------------------
Wow das ging ja schenll. Super DANKE hat geklappt mußte nur im STG 19 bei Verbauliste die Distansmessung aktivieren und dann war der Fehler weg.
Eine Frage habe ich noch der Code im STG 13 002B99 ist das der richtig für einen S4 mit Serienmässiger Anhängerkupplung ?
Grüße Timo
Original geschrieben von Kasperfunsurfer1
Wow das ging ja schenll. Super DANKE hat geklappt mußte nur im STG 19 bei Verbauliste die Distansmessung aktivieren und dann war der Fehler weg.Eine Frage habe ich noch der Code im STG 13 002B99 ist das der richtig für einen S4 mit Serienmässiger Anhängerkupplung ?
Grüße Timo
ja- sofern du keine Fehler im Stg 13 hast ist alles richtig codiert !
Hallo!
Auch ich bin gerade dabei, ACC bei meinem A4 B8/8K nachzurüsten. Zunächst einmal vielen Dank an alle Beteiligten für die hilfreichen Informationen hier im Thread; den Umbau konnte ich nach einigem Lesen sehr gut vorbereiten und für die meisten Probleme habe ich direkt eine Lösung finden können.
Der Sensor ist nun eingebaut und die abhängigen Steuergeräte sind auf ACC codiert. Abgesehen vom aktiven Komponentenschutz im ACC-Steuergerät habe ich allerdings seit dem Austausch des Lenkstockschalters inkl. Lenkradelektronik einen Fehler im Motorsteuergerät:
4481 - Schalter für GRA (E45)
P0568 00 [039] - unplausibles Signal
Im Steuergerät der Lenkradelektronik werden über die Messwertblöcke alle Schalterstellungen und Taster des Lenkstockschalters einwandfrei erkannt, also würde ich nicht auf einen Defekt des Schalters tippen.
Das Lenksäulensteuergerät habe ich wie das alte codiert und habe zusätzlich das Bit für ACC gesetzt. Interessanterweise wurde es nur zusammen mit dem GRA-Bit akzeptiert; GRA raus und ACC rein wurde nicht akzeptiert. Das Steuergerät ist neu; vorher hatte ich Index K und jetzt Index M.
Das Motorsteuergerät habe ich wie alle anderen Steuergeräte codiert. Hätte ich hier vorher eine Zugriffsberechtigung setzen müssen? Die Codierung wurde jedenfalls akzeptiert.
Hat jemand eine Idee, was die Ursache für den Fehler im Motorsteuergerät sein könnte?
Hier mein VCDS Scan:
Fahrzeugtyp: 8K (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 36 42 46 47 52 53
55 56 5F 62 69 6D 72
Fahrzeug-Ident.-Nr.: WAUZZZ8K9BA08****
01-Motorelektronik -- Status: Fehler 0010
13-Distanzregelung -- Status: Fehler 0010
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
Adresse 01: Motorelektronik (J623-CCWA) Labeldatei: 059-907-401-CAP.clb
Teilenummer SW: 8R0 907 401 J HW: 8K1 907 401 A
Bauteil: 3.0TDI EDC17 H14 0008
Revision: 15H14---
Codierung: 010C002C241F0A28
Betriebsnr.: WSC 76287 146 187741
ASAM Datensatz: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397F7B79B8DFEAD693D-806C
1 Fehler gefunden:
unbestätigt - geprüft seit letzter Löschung
Freeze Frame:
Fehlerstatus: 00000001
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Kilometerstand: 67678 km
Datum: 2013.12.04
Zeit: 19:08:33
Readiness: 0 0 0 0 1
Teilenummer SW: 8K1 927 156 H HW: 0B5 927 156 F
Bauteil: 0B5 30 TDIRdW H05 0008
Revision: --H05--- Seriennummer: 0000001500
Codierung: 000001
VCID: 3A7D6475BDD9E1CE9A7-806F
Bauteil: ESP8 quattro H04 0050
Codierung: 1C8D08
VCID: 820D5C951D89E90E027-80D7
Bauteil: BCM2 2.0 H05 0434
Revision: 00002001
Codierung: 050200
VCID: 810F5399188FF2161BD-80D4
Subsystem 1 - Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Teilenummer SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Bauteil: KLIMA 1 ZONE H08 0180
Revision: A1000000 Seriennummer: 01161120101002
Codierung: 36180000
VCID: 7DF7AF69E47716F6FF5-8028
Revision: 10030001 Seriennummer: 00000000857570
Codierung: 2600D0914074AF210701000300001D0D419C674802010101000000
VCID: 3C71626DBFEDDFFE88B-8069
Bauteil: WWS 191110 H06 0070
Codierung: 00FD11
Codierung: 035028
Subsystem 3 - Teilenummer SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Bauteil: E1 - LDS H08 0090
Teilenummer SW: 8K0 919 475 R HW: 8K0 919 475 A
Bauteil: PARKHILFE 8K H06 0070
Revision: 11001001 Seriennummer: 50901031602012
Codierung: 110103
VCID: 48990EBDFB35835E1C3-801D
Teilenummer SW: 8K0 907 561 B HW: 8K0 907 561 B
Bauteil: ACC3 H09 0090
Codierung: 0079B9
Betriebsnr.: WSC 06325 123 12345
VCID: 316F435968AF22962BD-8064
2 Fehlercodes gefunden:
01314 - Motorsteuergerät
013 - bitte Fehlerspeicher auslesen
Freeze Frame:
Fehlerstatus: 01101101
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 198
Zeitangabe: 0
Datum: 2013.12.04
Zeit: 19:19:41
Freeze Frame:
Temperatur: 21.0°C
Spannung: 11.90 V
Hex Wert: 0x00BD
Geschwindigkeit: 0.0 km/h
Querbeschleunigung: 0.00 m/s^2
02095 - Komponentenschutz aktiv
000 - -
Freeze Frame:
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 198
Zeitangabe: 0
Datum: 2013.12.04
Zeit: 19:19:41
Freeze Frame:
Temperatur: 21.0°C
Spannung: 11.90 V
Hex Wert: 0x0061
Bauteil: AirbagVW-AU10 H41 0610
Seriennummer: 003JMD01HH17
Codierung: 30513435363030303030554A304C384B3053
VCID: 46850085F921952EEEF-8013
Seriennummer: 6334MSME592051296
Seriennummer: 6344MSME58614C58N
Seriennummer: 6352QSME48772006B
Seriennummer: 6362QSME08763A0AM
Seriennummer: 63732SME13782720T
Seriennummer: 63832SME40771B14Z
Teilenummer SW: 8R0 953 568 M HW: 8R0 953 568 M
Bauteil: Lenks.Modul H07 0156
Revision: 00000000 Seriennummer: 20130207001444
Codierung: 00001F
Betriebsnr.: WSC 05398 394 139842
VCID: 4B9331B1EA436846311-801E
Teilenummer SW: 8K0 920 930 N HW: 8K0 920 930 N
Bauteil: KOMBIINSTR. H25 0258
Revision: 00100000 Seriennummer: EJC30AACA
Codierung: 0F0F11000F000008000000
VCID: 38797E7D8BD5F3DE6C3-806D
Adresse 18: Standheizung (J364) Labeldatei: PCI\8R0-265-105.clb
Teilenummer SW: 4H0 265 105 A HW: 4H0 265 105 A
Bauteil: Standheizung H22 0240
Revision: 56005006 Seriennummer: 20101110234600
Codierung: 5D2000
VCID: 2049B61D33459B1EB43-8075
Teilenummer SW: 8T0 907 468 AE HW: 8T0 907 468 L
Bauteil: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Seriennummer: 5800F10A29801C
Codierung: 00C303
VCID: 84015A8D079DE73E30B-80D1
Subsystem 1 - Teilenummer SW: 8K0 915 181 E HW: 8K0 915 181 E
Bauteil: J367-BDM H07 0170
Teilenummer SW: 8K0 857 511 D HW: 8K0 857 511
Revision: AA001002
VCID: 326D4C556DA9198E527-8067
Adresse 36: Sitzverst. Fahr. (J136) Labeldatei: 8T0-959-760.clb
Teilenummer SW: 8K0 959 760 D HW: 8K0 959 760 D
Bauteil: MEM-FS H06 0074
Revision: AA000000 Seriennummer: 00001002185088
Codierung: 00587B00000000000000
VCID: 3B736171BAE3D8C6811-806E
Revision: Seriennummer: 0000011701742
Codierung: 011012205E00410001
VCID: 4A9D34B5E539714E0A7-801F
Revision: 00002001 Seriennummer: 0138312967
Codierung: 01000E2020B930958320023280000000
Subsystem 1 - Teilenummer SW: 8K0 959 591 A HW: 8K0 959 591
Bauteil: J245 PS133 H07 0041
Subsystem 2 - Teilenummer SW: 8K0 959 591 A HW: 8K0 959 591
Bauteil: J394 PS229 H07 0041
Revision: 00010001 Seriennummer: 34804001571201
VCID: 7AFDA475F55921CEDA7-802F
Revision: Seriennummer: 0000110553761
VCID: 499F0BB9E03F7A5603D-801C
Revision: 00000003 Seriennummer: 10000000663823
VCID: 34614A4D97BD17BE40B-8061
Adresse 55: Leuchtweitenreg. Labeldatei: PCI\8T0-907-357.clb
Teilenummer SW: 8H0 907 357 C HW: 8H0 907 357 C
Bauteil: AFS 1 H01 0030
Revision: 00000001 Seriennummer:
Codierung: 0000019
VCID: 326D4C55ADA9198E527-8067
Subsystem 1 - Teilenummer: 8K0 941 329
Bauteil: AFS-Modul links H02 S001
Subsystem 2 - Teilenummer: 8K0 941 329
Bauteil: AFS-Modul rechtsH02 S001
Teilenummer SW: 4G0 035 053 F HW: 4G0 035 053
Bauteil: Radio U Basic H52 0122
Revision: AB001007 Seriennummer: 496K80A7604757
VCID: 214FB319384F9216BBD-8074
Teilenummer SW: 8T1 035 666 L HW: 8T1 035 666 E
Bauteil: H-BN-EU H49 0180
Revision: -------- Seriennummer: 483K30AB008259
Codierung: 010100010106FBED65002F1E000000030001
VCID: 43831991C213A006C91-8016
Subsystem 2 - Teilenummer SW: 8F0 919 604 HW: 8F0 919 604
Bauteil: DU7 High H43 0098
1 Fehler gefunden:
03157 - Funktionseinschränkung wegen Kommunikationsstörung
000 - -
Freeze Frame:
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 158
Kilometerstand: 66692 km
Zeitangabe: 0
Datum: 2013.11.17
Zeit: 14:43:38
Freeze Frame:
Binärwert: 00000000 01000000
Binärwert: 00000000 00000000
Revision: Seriennummer: 0000110525011
Codierung: 010012204000210001
VCID: 45870789CC279E36E75-8010
Bauteil: Anhaenger H07 0100
Revision: 1A001001 Seriennummer: 00000138327904
VCID: 3665704581C105AE7EF-8063
Bauteil: J605 Master H50 0330
Bauteil: J756 Slave H50 0330
Revision: Seriennummer: 0000110524484
Nutze ich 8K0907561B; ACC3 H07 X 070 für A4/B8-2011 – ACC Nachrüstung? bereits installierte :-( aber Problem um das System einzuschalten
X SW drauf " daher keine endsoftware und VORSERIE
damit würde ich nicht fahren ;: u.a. kann es auch daran liegen das du es nicht zum laufen bekommst
Original geschrieben von Scotty18
X SW drauf " daher keine endsoftware und VORSERIEZitat:
Scotty18 vielen Dank für die Antwort
Leider kann ich Deutsch :-(
Ich versuche, mein Auto mit ACC Nachrüstung ACC - Limo/B8/04-2011/1.8TFSI/88KW/CDHA/NCT/Manual/CAN/Concert
Bisher gelang es mir, Nachrüstung: HomeLink, Multisteering wheel, HBA, Side Assist, Parktronic Front, Bluetooth :-)
Ich habe bereits installiert und kodiert alle anstossen, habe einige Problem :-(
Ich kaufte RADAR Breite Index "B" für Facelift 2013 ? 8K0907561 B; X060; HW: 8K0 907 561 B; H07; 15.02.11; VCDS: ACC3 H07 X070
warten noch-Komponente Schutz entfernen. Ich werde den Radar-Sensor auf Version ohne Index ändern, aber ich bin Sorgen gibt es ein weiteres Problem am Motor Codierung :-(
Ausstehende mein Instrument Cluster-8K0920930M, (GXTXQX) laut ETKA ? ersetzen
VCDS Coding
01-Engine ---> Coding –--> Long Coding Helper –--> Byte 6 Bit 1; (Bit 0 --> CCS OFF and ACC=ON)
13-Auto Dist. Reg –--> Coding 07 –--> Long Coding Helper ---> coding: 0079C0 (no trailer)
16-Steering wheel –--> Coding 07 –--> Long Coding Helper –--> Byte 2 BIT 2 and BIT 3
17-Instruments --–> Coding 07 –--> Long Coding Helper –--> Byte 4 Bit 2
19-CAN Gateway –--> Installation list –--> add 13 Auto Dist. Reg
56-RADIO ---> Coding ---> Byte 8 Bit 4
My ACC coding:
01-Engine; CDHA (1.8 TFSI); Part No SW: 8K1 907 115 C; HW: 8K1 907 11; Coding: 0104000C18070258
13-Auto Dist. Reg; Part No SW: 8K0 907 561 B; HW: 8K0 907 561 B; Coding: 0079C0
16-Steering wheel; Part No SW: 8K0 953 568 G; HW: 8K0 953 568 G; Coding: 00001E
17-Instruments; Part No SW: 8K0 920 930 M; HW: 8K0 920 930 M; Coding: 030D080007000008010000
19-CAN Gateway (CAN); Part No SW: 8T0 907 468 AC; HW: 8T0 907 468 J; Coding: 00C303
56-Radio (Concert); Part No SW: 8T1 035 186 P; HW: 8T1 035 186 P; Coding: 0500048204010500D35B270000
Address 01: Engine (DET---CDHA)
2 Faults Found:
4330 - Function Restriction due to Received Malfunction Value
U1113 00 [047] - -
Confirmed - Tested Since Memory Clear
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Address 13: Auto Dist. Reg
00234 - Sensor for Automatic Distance Regulation Misadjusted – Modul Notwendigkeit Kalibrierung
01317 - Control Module in Instrument Cluster (J285) - nicht sicher wohl Bezug auf fehlende reibende Instrumentengruppe (GX/TX/QX)
02095 - Component Protection Active – entfernt einmal alle arbeiten, um sein.
Der Rest der Log fehlerfrei
Irgendeine Idee was hier falsch?
Dank einem erweiterten,
