Adaptive Cruise Control nachrüsten
Audi A4 B8/8K
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 weitere Antworten
1798 Antworten
Warum der Komponentenschutz so zeitversetzt kommt und warum bei den anderen sofort ; weis keiner
Der Kompo kam bei mir sofort.
Man müsste mal die Verstellwinkel auslesen. Der Grenzwert liegt ja bei 0,8° alles was darüber hinausgeht schaltet sich der Sensor ab. Wenn du nun hart an der Grenze bist könnte das die Sperenzchen erklären.
hi
macht jeder audi vertragshändler die justierung ?
oder meckern die rum "das das nicht vom werk aus eingebaut ist !!"
was kostet das justieren ca?
gibts hier ne auflistung was die einzelnen teile kosten?
gitter,stecker,halter,usw
gruss Thorsten
also das kalibrieren was du meinst, machen manche händler die auch das richtige werkzeug haben ( den spiegel ) kostenpunkt sprach man hier um die 200 euro.
wenn du den thread von vorne liest, dann stehen da alle teile drin du brauchst.
sensor neu 1300 euro ( bei ebay um die 200 )
lenkstockhebel ca 170 euro neu ( bei ebay meist für 100 )
schleifring ( lenkradelektro.) ca 200 euro neu ( bei ebay meist um die 100 )
gateway ca 120 euro neu ( bei ebay um die 70 )
stoßstangen einsatz Neu ca 60 euro.
kabelsatz gibt es jedoch nicht von audi zu kaufen.
hast du lane assist oder side assist ? wenn nicht, dann brauchst du ein neues gateway.
und auch nicht jeder Audi 🙂 macht die Kalibrierung ohne Probleme, (thema sicherheitsaspekt etc) daher vorher genau nachfragen und sich versichern das er das auch kalibriert!
Immer lustig dieses ACC... 😁
Fahr jetzt eine ganze Weile (wieder) problemlos mit dem Ding, doch heute ist ein grosses, schweres Ahornblatt langsam auf mich zugeflogen gekommen und mein ACC hat in völlig freier Fahrt den Gong hören lassen und den Bremsruck ausgeführt (nur bei ca. 60km/h, daher alles kein Problem) - dann sofort wieder gelöst und weiter wie immer.
Ich nehme an, das Ahornblatt war zu lange genau vor dem Radar und hat den Stopp ausgelöst. Kann das sein? Wenn ja, was machen denn die Fahrzeuge mit Notbremsfunktion? (Oder gibts die nur mit mind. zwei Sensoren?)
Was mich noch interessiert:
Wie verhält sich das ACC bei starkem Nebel? Ist es eine große Hilfe damit zu fahren oder bringt es hier keinen Vorteil?
Hat diesbezüglich jemand Erfahrung?
ehrlich gesagt kann ich mir das nicht vorstellen. Erstens ist ein Ahornblatt ziemlich sicher nicht radarreflektiv und zweitens müsste es konstant vor dem Auto fliegen um erkannt zu werden.
Es sieht weiter als du bei dichtem Nebel.
Das war jetzt aber keine Anleitung zum Rasen!
Das habe ich mir so gedacht, danke.
bei schlechter witterung oder starkem nebel schaltet das system ab- und es gibt dazu sogar ein fehlerspeicher eintrag!
Stg 13
10240 - Sensor für automatische Distanzregelung
C110B F0 [008] - Eingeschränkte Sicht
Sporadisch - bestätigt - geprüft seit letzter Löschung
Freeze Frame:
Fehlerstatus: 00000001
Fehlerpriorität: 7
Fehlerhäufigkeit: 2
Verlernzähler: 173
Kilometerstand: 16763 km
Datum: 2012.01.05
Zeit: 18:00:26
zum ACC nachrüsten im FL ; hier ein paar Bilder von mir
https://www.facebook.com/.../?...
Ja macht es! Aus meiner Erfahrung aber nur bei sehr starkem Regen (Gischt vom Vordermann) oder dichtem Schneefall. Noch nie bei Nebel.
der fehler oben stammt von einer fahrt im starken nebel
https://www.facebook.com/.../?...¬if_t=like
Warum baust du die Stoßstange ab? Wir haben es bisher immer so geschafft.
