  4. Audi
  5. A4
  6. A4 B8
  7. Adaptive Cruise Control nachrüsten
Audi A4 B8/8K
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 weitere Antworten
1798 Antworten
... Die Sicherung vom Radar kannst du zum Strom sparen danach auch ziehen ...
Die sollte auf jeden Fall gezogen werden, ansonsten kann der CAN Bus wach bleiben und die Batterie geht leer. Außerdem verschwinden dann auch die Fehler im Gateway. Der Fehler "falsch codiert" kommt dann nur im Lenksäulensteuergerät, weil der ACC-Hebel verbaut ist.
Die Codierung im Motorsteuergerät ist abhängig vom Typ...
Der CAN-Bus kann nicht wach bleiben. Der Sensor hängt an Zündungsplus. Aber auch mit Sicherung hatte ich nur den Fehler im Lenksäulensteuergerät.
Aber unbedingt bedenken, dass du so möglicherweise keinen TÜV mehr bekommst, hatte mal jemand hier im Forum geschrieben. Keine Ahnung. Im Ernstfall den Sensor ausbauen (bringt Geld) und/oder die geschlossene Blende davorsetzen, dann sieht es der Prüfer nicht
Hat jemand eine Ahnung ob ich nur den GRA Hebel bzw ACC Hebel von Kostal in mein Vorhanden Einbauen kanm? Habe jetzt im moment auch Kostal
Ich habe schonmal den Blinkerhebel gewechselt, das ging. War ein Valeo aus’m Facelift, dürfte aber von der Mechanik vergleichbar sein. Wenn du ein bisschen Feinmotorik hast, probiere es aus - und berichte hier
Okay, finde nämlich kein Hebel mit LANE ASSIST und ACC. Habe mir ein Hebel vom A6 4G gekauft der ACC hat und von Kostal ist. Werde es dann versuchen.
Ein neuer Hebel würde mich schlappe 225€ kosten 😁
a6 hat auf der echten seite keine FIS tasten
@Scotty18 schrieb am 19. September 2019 um 06:53:59 Uhr:
Mir geht es rein nur um den unteren GRA Hebel /ACC Hebel in mein Kombinationsschalter zu bauen.
@skywalker93 schrieb am 18. September 2019 um 19:22:57 Uhr:
Wenn Du die Platine von der linken Seite mit übernehmen kannst, dann könnte es gehen...
Dscn3230
Das brauche ich glaube nichtmal, weil die Kabel vom ACC/GRA Hebel gehen direkt in den Stecker ins Lenksäulensteuergerät.
hattest du denn schon den GRA-Hebel? - dann brauchst die Platine wahrscheinlich nicht....
Genau GRA hatte er schon
Also umbau war kein Problem. Man muss halt den weißen Stecker auseinander Bauen, und die Klemmungen der Kabel rausdrücken.
Eine Frage hätte ich noch. Bei mir im MMI zeigt es kein Fahrprofil an sprich Auto/Dynamic/Comfort usw. Wo muss ich das aktivieren? Drive Select habe ich.
Das wird nur im MMI High angezeigt.
Beim Basic nur im Tacho.
Weiß ja nicht welches du hast.
Achso, hab das MMI 3G Plus also bei mir müsste es angezeigt werden.
