Lenkrad tauschen
Hallo!
Habe mal wieder eine Frage und bitte um eure Hilfe!
Möchte meine Q etwas aufwerten und würde gerne mein Lenkrad (4-Speichen) gegen ein Lenkrad mit 3-Speichen und Multifunktionstasten oder 4-Speichen mit Multifunktionstasten austauschen.
Aus welchen Audi Modellen würden die Lenkräder passen (A4,A5?) vielleicht hat sogar jemand Teilenummern für mich?
Was brauche ich zu meinem Vorhaben noch für Teile?
Meine Q ist Bj.01/2011 2,0 TFSI
Danke vorab für eure Hilfe.
8K, 8E, 8P ... are totally different airbags-systems!!! The airbag-control-unit can't check what type of airbag is built in, because it only can check the electrical resistance of the trigger(?)!
Only 8R airbag will work in Q5 correctly.
55 Antworten
meine Aussage bezog sich auf den Versand...
[Von Motor-Talk aus dem Thema 'Lenkrad Tauschen' überführt.]
Question not answered:
If one uses an 8K an 8E or an 8F or an 8P 3 spoke airbag with the same PR code (of the steering wheel) in a 3 spoke Q5 steering wheel will the airbag control module of Q5 recognise this airbag??? Note the airbag control module does not recognise airbag part numbers in VCDs so I believe there is a high possibility that all airbags (from different models) are recognised.
Note:
A Q5 user reported that he used an 8K airbag (same PR code as steering wheel) in a Q5 and works fine.
My case
I am changing my 4 spoke to a 3 spoke steering wheel with paddle shifts. New compatible airbag 8R with PR-1XX compatibility. Had to pay more to get the 8R airbag because I was not sure if other audi models airbags are compatible (same part number 8R0880201 just the R is substituded with E or K or P or F)
I have the 3 spoke smooth leather steering wheel (not pitted/punched) with red stiches from A3.
i did not read your previous reply correctly because of chrome automatic translation. I cannot modify my question so I will ask a new one.
(Admin can you please delete question above?? Thanks)
So other models airbag with same PR code may be installed but may not be 100% compatible but will inflate in case of an accident?? Is this correct??
Thanks. I always refer to airbags with PN 8?880201. ?=R, E, P, K, F with same pr code.
1. Wouldnt SRS airbag light show on instrument cluster if aibag pin programming is different??
2. Is there a way to find out the airbag part number if external label was removed??
3. would one be concerned if driver airbag serial number is read by VCDs, and their is no SRS airbag diagnostic trouble code (DTC) if label was removed??
4. can one know what airbag part number he has by the airbag serial number from VCDs, is there a database??
Any information on the above might guide some users to make informed decisions or troubleshoot a future question regarding an airbag received without the part number label.
This is the Q5 8R airbag latest model 8R0880201AC (3 spoke) just observe the plugs/connectors. I have seen different models sold as compatible but plugs look different (I believe those do not work properly). I hope this is a starting point. A confirmation that this photo is correct will be helpful to others.
I will take better photos once my 8R 3 spoke airbag arrives.
Da sich weder Motor-Talk selbst, noch wir in rechtliche Probleme bringen wollen, müssen wir an dieser Stelle auch darauf hinweisen, dass Diskussionen rund um das Thema Airbag sowie Hinweise, Tipps und auch Bastelanleitungen zum Ein...bzw,- Aus- und Umbau von Airbags und/oder Gurtstraffer bei MT nicht erlaubt sind... Bitte siehe dazu Punkt 5.3 NUB ...
Thread geschlossen
gamsrockl
MT-Mod
