LED- Umbau S6 in A6
Audi A6 C6/4F
Hallo und gesundes Neues, habe heute vom Freundlichen eine Info zur Umrüstung auf LED`s in die Frontschürze bekommen. Es müssen beide Steuergeräte zur Ansteuerung der neuen Lichtbänder vom S 6 eingebaut bzw. umgebaut werden. Kosten ca. 250,- EURO / Stk. plus Verlegen der Kabel.
Gesamtkosten ohne technischen Aufwand der Dinger selbst und Materialkosten ca. 1000,- EURO. Für mich noch zu hoch,
vielleicht probiert`s mal jemand?!
3.0 TDI, 300 PS, AVANT
51 Antworten
Hello
Have just finished mounting the S6 bumper on my standard A6 - It went very well. The bumper is ca. 1 cm weiter on the S6, but as the bumper is flexibel it fits anyway :-)
The LEDs were connected instead of the standard TFL.
It works nicely - Only one minor problem, as the LEDs on the S6 dims when used as parking-light. But I can live without this feature.
one more :-)
Hi Frank,
it`s very nice to see, that´s possible to change the original light. My English is not perfect, but I have one question about the electronicle problem. How did you install the wire. Please send it with a picture. Thank you
By Sven
What happened to your headlight cleaning cover?
They're at the painting-shop :-)
I would know gladly, how the LED borders is attached to the day headlight. What happened from your Coming Home Leaving Home? Did on board computer exhibit an error? Sorry, mine english is emergency perfect. Thanks
Original geschrieben von fva
Hello
Hi Frank,
what have you done with the original plastic gitters. Under the new LED`s are others or?!
By Sven
Hi Frank,
what did you do to your fog-lamps and how did you solve the problems with your "Coming-Home/Leaving-Home" feature?
Didn't your onboard computer show any errors?
Where did install the wires? Could you send me a picture?
With best regards
Michael
Hallo Michael,
ich glaub`, Frankiboy ist mit seinem Resultat selbst unzufrieden, sonst hätte er sicher ein paar Details mitgeteilt.
Ich bin jedenfalls noch dran und hab`mir vom S6 die Lüftungsgitter der Nebli`s besorgt. Passen schon ziemlich gut.
Meine LED´s sind noch nicht da, sollten aber seit gestern per Versand eintreffen. Dioden hab`ich mir auch schon besorgt, sobald dei Lampen eintreffen, starte ich zum Freundlichen und harre der Dinge, die da kommen.
Gruß Sven
Moin Sven,
Ich hatte heute mein A6 beim freundlichen. Der hat eine S6 Stoßstange mal bei mir angebaut. Sie würde wirklich mit etwas biegen passen. NUR, mann sieht oben am Rechten Scheinwerfer ein spalt von Ca 3 mm und am linken ein spalt von 5 mm. Sieht nicht sehr schön aus 🙁
Wirst du deine alte Stoßstange behalten, und die LED´s da mit dem S6 Gitter verbauen. Oder kaufst du dir eine S6 Stoßstange?
Michael
Hi Michael,
ich hab`ja `ne S- Line- Frontschnauze. Also bis auf das äußere untere Eckchen der Lüftungsgitter vom S 6 scheint erstmal soweit alles zu passen. Den Rest wie gesagt nach der Lieferung der LED´s. Ich werde die S 6 Frontschürze nicht anbauen, da mir der Aufwand an den Radkästen höher erscheint, als der in den Nebli`s.
Gruß Sven
Original geschrieben von tsl
Hi Frank,
By Sven
Hi
My 20mb internet connection has been down for several days -Sorry :-/
The S6 has the fog-light integreted in the headligts just next to the Grill were normally the TFL is placed.
So then the S6 do not come with gitters including holes for fog-lights.
The S6-gitters I used have these number:
4F0 807 681 F
4F0 807 682 F
Mfg Frank
Michael
I do not understand why the dealer cannot mount the bumper correctly - The headligt mountings can be ajusted in any direction. By correct the this I thing the gaps should be minimized.
I think it look all-right on my car ;-)
(The covers are out to be painted...)
Hi Frank,
I´ve got these gitters today. What have you done with the wire?!
By Sven
Hi
I have connected the LED to the TFL wiring.
Or Your can to the "Pulsweitenmodulation"
Click here...
or here:
More...
