Codierungen für Tiguan 2
VW Tiguan 2 (AD)
Auch hier soll eine Übersicht /Sammlung der Dinge entstehen was alles codiert werden kann.
Wie auch schon in anderen Modellen gibt's eine Menge was man freischalten kann nachträglich.
Video/DVD während der Fahrt geht nach wie vor nur mit vcp
Eine Übersicht bekommt ihr hier:
https://onedrive.live.com/view.aspx?...
8531 weitere Antworten
8531 Antworten
Since your german sentences don´t make any sense....maybe you should write in english? 😉
What do you mean "Monitor loslösen"?
@MartinSHL schrieb am 18. Juli 2017 um 08:56:39 Uhr:
I meant Performance monitor unlocking...
Because by coding it can't be activated.
You don´t need to activate this screen. It´s already available by default. You just have to press the "CAR"-Button a view times.
(each click will show you a different screen with different settings)
... a few times ...
Oh...my mistake! You are right.
And then you can switch it by a little wipe up/down.
@MartinSHL schrieb am 18. Juli 2017 um 09:40:58 Uhr:
OK,
could you please explain to me, how I can reach all these screens?
All, that I have in car is attached.
Thank you!
Bild #208900435
Bild #208900438
Use the arrows above the circle to change the information
Boys,
I'm speaking about another screen "Performance monitor", there you can see and choose another parameters, like Boost in Bar, kW, g...
Please look in attached picture...
Seems folder called SPORT in CAR menu and need to be activate, there contains screen Performance monitor.
Bild #208900461
Bild #208900463
We know, we only push the Car button 2 or 3 times.
Alles klar und freitags gibt es Fisch.😁
As we already explained, all you have to do is push the "CAR" Button (see attached picture) and/or the arrows on the screen 2 or 3 times.
208900438-w1188-h669
@MartinSHL schrieb am 18. Juli 2017 um 14:27:06 Uhr:
Please, press the Auswahl button and take the picture. It all that I asked.
I'm interested in quantity and names of tabs.
After that by clicking CAR button several times you will understand that you move only within quantity of tabs under the Auswahl button...
Just to satisfy you I went to my car and took a
short video. 😉
@MartinSHL schrieb am 18. Juli 2017 um 15:14:36 Uhr:
short video. 😉
Thank's for the video, but touching virtual button "Auswahl" is not present.
Actually, it's the same operation as pushing CAR button several time.
Anyway, thank's for trying to help.
Itself didn't check so far.
Increased sensitivity of the throttle pedal
Controller 01- Engine
07 - Coding
Byte 0, Bit 0-2,
Change from Škoda (01) to AUDI (02) this will dramatically reduce lag on pressing accelerator pedal.
