Adaptive Cruise Control nachrüsten
Audi A4 B8/8K
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 weitere Antworten
1798 Antworten
Did you do all other codings which are necessary for ACC?
Yes, all codings have been done on modules 01, 13, 16, 17, 19. Recalibration of G85 done.
After changing the coding for module 13, there is a new error:
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 56
Mileage: 84320 km
Time Indication: 0
Date: 2014.03.04
Time: 22:00:34
Freeze Frame:
Temperature: 24.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x05C1
Hex Value: 0x0004
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
right gateway?
with exetened can
Yes, can 8t0907468aa. If the can is the wrong version, module 13 is not accessible. CP removed for can and radar. Maybe there is a difference between fuse panels? Because my 12V wire goes to the brown panel on the passenger side and original wire goes to the trunk panel....
ACC works! It's great!
The problem was the 12V wire, it was plugged in the brown passenger fuse box where it had permanent 12V, but the original fuse box receives 12V only on ignition. So the module was remaining under 12V when ignition was off but the others did not have 12V anymore so this is why the errors apearred.
So I just had to move the wire from the brown fuse box to the black one next to it that receives 12V only on ignition.
One error still remains on module 13, but ACC works, maybe the error will clear out:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 56
Mileage: 84320 km
Time Indication: 0
Date: 2014.03.04
Time: 22:00:34
Regarding the sound warning, I have MMI 2G and have enabled via hidden menu the ACC option, so everything is available in CAR menu. I have selected the tone for the gong to medium, when I select it there is a sound, so the gong works. But when I reach 30km/h and acc deactivates, there is no gong! Any ideas why, maybe I have to select something else for the sound warnings? Same for braking guard, I have approached another slow moving vehicle and there was no sound warning.
Thanks
thats what i said !!!
Yes, you were right, thank you!
So any ideas for no sound warning? I have made this video, close to the end you will see that acc is slowing down and when it passes the 30km/h margin there is no sound, car is still in gear till close to 20km/h, so acc was not deactivated.
http://www.youtube.com/watch?v=UscN3IXBU6Y
activated breaking guard in mmi menu ?
Yes, braking guard activated, warning activated.
In ACC menu volume for warning selected to medium, driving style selected to standard.
Hi guys. I did my ACC retro last week but still having problem with coding. I tried every coding from this thread and many other websites and one error still persist '01044 - Control Module Incorrectly Coded'. I live in Ireland and I suppose it could be rhd/lhd coding problem. I drive 09 A4 2.0tdi with manual gearbox. Do you have any idea where the problem is? Thanks!
which coding do you use now?
Trailer coupling: yes/no?
do you have a facelift radar?
index?`
I've tried many codings, no change. At the moment there is 0079C0 I think. And the radar number is 8K0 907 561 with no letter. No trailer hitch.
SW version?!
X
oder 0080
Original geschrieben von Scotty18
SW version?!
X
oder 0080
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H07 0080
Serial number: 00000000000000
Coding: 0079C0
Shop #: WSC 12345 123 12345
VCID: EFE9578F855D
That's all I have.
