A5 B8 Rad Reifen Kombinationen
Audi A5 8T Coupe
Unten aufgeführt alle mir bekannten zugelassenen Rad/Reifen Kombinationen. Einige Motorvarianten fehlen mir allerdings.
Angaben ohne Gewähr 😉
A5, Coupé
Benziner
1.8 TFSI 118kW/125kW MJ 2008
7,5 J x 17 28 225/50 R 17 94Y
8 J x 17 26 245/45 R 17 95Y
8,5 J x 18 29 245/40 R 18 93Y
8,5 J x 19 32 255/35 R 19 96Y XL
9 J x 19 33 255/35 R 19 96Y XL
9 J x 20 29 265/30 R 20 94Y XL
8 J x 18 31 225/45 R 18 95H XL
8,5 J x 18 29 245/40 R 18 97H XL
1.8 TFSI 118kW/125kW MJ 2009 - 2011
7,5 J x 17 28 225/50 R 17 98H
1.8 TFSI 106kW/125kW 2012 - 2015
7,5 J x 17 28 225/50 R 17 94 Y
8 J x 17 26 245/45 R 17 95 Y
8,5 J x 18 29 245/40 R 18 93 Y
8,5 J x 19 32 255/35 R 19 96 Y XL
9 J x 19 33 255/35 R 19 96 Y XL
9 J x 20 29 265/30 R 20 94 Y XL
2.0 TFSI 132kW/155kW MJ 2008 - 2011
2.0 TFSI 155kW/165kW MJ 2012 – 2015
3.2 FSI 195kW MJ 2008
3.2 FSI 195kW MJ 2009 - 2011
S5 3.0 TFSI 245kW MJ 2009 - 2015
8,5 J x 18 29 245/40 R18 93Y
8,5 J x 19 32 255/35 R19 96Y
9 J x 19 33 255/35 R19 96Y X
9 J x 20 29 265/30 R20 94Y X
8,0 J x 18 31 245/40 R18 97V
S5 4.2 FSI 260kW MJ 2008
S5 4.2 FSI 260kW MJ 2009 - 2011
8 J x 18 31 245/40 R 18 97H XL
Diesel
2.0 TDI 120kW/125kW MJ 2008
7,5 J x 17 28 225/50 R 17 94W
8 J x 17 26 245/45 R 17 95W
2.0 TDI 100kW/105kW120kW/125kW MJ 20092011
2.0 TDI 100kW/105kW120kW/125kW/130kW MJ 2012 2015
2.7 TDI 120kW MJ 2008
7,5 J x 17 28 225/50 R 17 94V
8 J x 17 26 245/45 R 17 95V
8,5 J x 18 29 245/40 R 18 93V
8,5 J x 19 32 255/35 R 19 96W XL
9 J x 19 33 255/35 R 19 96W XL
2.7 TDI 140kW MJ 2008
8,5 J x 18 29 245/40 R 18 93W
2.7 TDI 120kW MJ 2009 2011
2.7 TDI 140kW MJ 2009
2.7 TDI 140kW MJ 2010 2011
3.0 TDI 155kW/176kW MJ 2008
3.0 TDI 155kW/176kW MJ 2009 2011
3.0 TDI 150kW MJ 2012 – 2015
8,5 J x 18 29 245/40 R 18 97 Y XL
3.0 TDI 160kW/176kW MJ 2012 – 2015
8 J x 18 31 245/40 R 18 97 V XL
3.0 TDI 180kW (MKB CDUC/CKVB) MJ 2012 – 2015
3.0 TDI 180kW (MKB CKVC) MJ 2012 – 2015
A5, Sportback
Benziner
1.8 TFSI 118kW/125kW MJ 2010 – 2011
7,5 J x 17 28 225/50 R 17 98 V XL
1.8 TFSI 106kW//118kW/130kW MJ 2012 – 2015
2.0 TFSI 132kW/155kW/165kW MJ 2010 – 2011
2.0 TFSI 132kW/155kW/165kW MJ 2012 – 2015
9 J x 19 33 255/35 R 19 Y XL
3.0 TFSI 200kW MJ 2012 2015
3,2 FSI 195kW MJ 2010 – 2011
S5 3.0 TFSI 245kW 2011 – 2015
S5 4.2 FSI 260kW 2011 – 2015
Diesel
2.0 TDI 100kW/105kW/120kW/125kW/130kW MJ 2010 2011
2.0 TDI 100kW/105kW/110kW/120kW/130kW/140kW MJ 2012 – 2015
3.0 TDI 150kW/160kW/180kW MJ 2012 – 2015
7,5 J x 17 28 225/50 R 17 94 Y XL
3.0 TDI 180kW MKB CKCV MJ 2012 – 2015
8 J x 18 31 245/40 R18 97V XL
A5, Cabrio
Benziner
1.8 TFSI 118kW MJ 2010 – 2011
7,5 J x 16 28 225/55 R 16 95 Y
7,5 J x 17 28 225/50 R 17 94 H
8,5 J x 18 29 245/40 R 18 97 V XL
1.8 TFSI 106kW/118kW/125kW/130kW MJ 2012 2015
7,5 J x 17 28 225/50 R17 94Y
8 J x 17 26 245/45 R17 95Y
7,5 J x 17 28 225/50 R17 94H
8,5 J x 18 29 245/40 R18 97V
7,5 J x 17 28 225/50 R17 98V AS
2.0 TFSI 132kW/155kW MJ 2010 – 2011
7,5 J x 17 28 225/50 R 17 98 H XL
8,5 J x 18 29 245/40 R 18 97 H XL
3.2 FSI 195kW MJ 2010 - 2011
3.0 TFSI 200kW 2012 - 2015
S5 3.0 TFSI 245kW 2010 - 2011
S5 4.2 FSI 260kW 2010 2011
Diesel
2.0 TDI 120kW/125kW MJ 2010 – 2011
2.0 TDI 100kW/105kW/110kW/120kW/130kW/140kW MJ 2012 2015
2.7 TDI 120kW/140kW MJ 2010 – 2011
7,5 J x 17 28 225/50 R 17 98 Y XL
3.0 TDI 180kW MJ 2010 – 2011
3.0 TDI 180kW MKB CKVC MJ 2010 – 2011
3.0 TDI 180kW MJ 2012 – 2015
A5, Coupé
Benziner
Diesel
A5, Sportback
Benziner
Diesel
A5, Cabrio
Benziner
Diesel
46 weitere Antworten
46 Antworten
@MA1989 schrieb am 19. Dezember 2019 um 10:24:15 Uhr:
Warum kann man kein 235/40/18 drauf machen auf 18zoll oder würde es noch gehen
(Für Winterreifen)
Lg
Erlaubt laut etrto Tabelle ist es (235/40 auf 8,5x18).
Ob sich der cm auf das Fahrverhalten positiv auswirkt, bleibt offen.
Wenn es sich um Originalfelgen handelt wird eine Eintragung schwierig, da die Felge nur mit 245 den Impact-Test durchlaufen hat.
Bei Zubehörfelgen sieht es anders aus, dort sind oft 235/40 auf 8,5x18 im Gutachten freigegeben.
235 bin ich schon auf dem schwereren A4 B7 3.0 TDI gefahren. Je nach A5 Variante gehen 235er problemlos zu fahren.
@Cokefreak schrieb am 6. März 2019 um 18:40:54 Uhr:
@Schleppi1984 schrieb am 6. März 2019 um 17:24:34 Uhr:
Das Thema interessiert mich auch. Aber wenn den Impact Test richtig verstanden habe, geht's um die Festigkeit der Felge. Die ja, weil original Audi, schon gegeben.
Reicht hier nicht die Reifenfreigabe des Reifenherstellers, welche die Unbedenklichkeit der Reifenbreite zur Felgenbreite bescheinigt?
Die 265er stehen eh nicht im Fahrzeugschein. Nur die Serienbereifung aller...245/40 R18 oder ähnlich
Kurze Erklärung zum Impact-Test:
Es kommt darauf an mit welchem Reifen die Felge den Test durchlaufen hat.
Ist die gewünschte Reifengröße kleiner bzw schmaler, ist der Test hinfällig und muss mit der geänderten Bereifung erneut durchgeführt werden.
Begründung: der Reifen kann den Schlag auf das Felgenhorn nicht im gleichen Maße abfedern.
Der Impact-Test wird noch nicht in allen Bundesländer verlangt. (Neue Bundesländer z.B.)
Eine weitere Hürde beim "entfremden" von OEM Felgen:
Audi gibt seit geraumer Zeit keine Traglastbescheinigungen mehr weiter.
Sehr wohl bekommt man von Audi noch Traglastbescheinigungen. Habe gerade erst letzte Woche meine bekommen. Hab zwar einige male nachfragen müssen und denen erst erklären müssen was diese „Traglastbescheinigung“ genau ist, aber hat schlussendlich funktioniert 😉
@RedBanana :
Glückwunsch und danke für den Hinweis.
Möglicherweise rudert Audi wieder zurück, oder Du hast einfach Glück gehabt.
Es wäre hilfreich für andere User, wen Du die TLB hochladen könntest. (deine persönlichen Daten geschwärzt)
@cepheid1 schrieb am 19. Dezember 2019 um 11:09:33 Uhr:
Ich hatte 235/35 R19, eigentlich ein absolut übliches Format für "sportliche" Reifen, hat der R8 z. B. auf der Vorderachse, aber der hat dort eben auch kaum Last zu tragen.
Meine 235/35 R19 hatte ich als Dunlop Winterreifen. Obwohl die Dunlop per se recht gute Winterreifen hat, hatte ich in Verbindung mit meinem A5 3.0 TDI quattro das Gefühl, dass das Lenkverhalten viel zu schwammig und unverbindlich war. Vermutlich war die Fuhre einfach zu schwer an der Vorderachse. Es ging mir so auf die Nerven, dass ich dann noch mitten in der gleichen Winter-Saison auf - sicher ist sicher - 265/30 R20 umgestiegen bin. Ergebnis: top.
Bei meinem jetzigen Golf 7 R fahre ich daher auch Winter wie Sommer identische Formate, übrigens da dann doch 235/35 R19, die perfekt zum Fahrzeug passen. Er ist definitiv kein Leichtgewicht, aber wiegt immerhin 160 kg weniger als der A5 und schleppt nur einen 2.0 als 4-Zylinder Benziner statt eines 3.0 als 6-Zylinder Diesel.
Sorry, hat ein bisschen gedauert. Anbei aber die erwähnte Traglastbescheinigung der RS5 Rotor Felge.
Habe es mit dem Handy fotografiert. Sollte es jemand „hochauflösend“ brauchen, gebt mir Bescheid, dann scanne ich es noch mal richtig ein.
PS: Unterschriften auf diesem „Dokument“ sind echt, man spürt den durchdruck des Kugelschreibers. Ist nicht aufgedruckt 😉
317f47ec-fd72-496f-9903-39774ed7c3f7
Guten Tag Jungs,
ich besitze einen A5 Coupe (2011) und habe die Möglichkeit von einem Kumpel Oxigin18 20" Felgen zu kriegen, wie kann ich diese am besten Bereifen? wäre eine Bereifung von zb 245/30 möglich, oder ist dies generell ausgeschlossen? bin in dem Themengebiet leider noch totaler Anfänger ??
Hoffe mir kann da jemand weiterhelfen
Schau ins Gutachten der Felgen
Ja Hallo an alle Motor-Talker ersteinmal, ich bin hier ganz neu in dem Forum gerade angemeldet, ich brauche auch schon den ersten Rat von euch, seit gestern Abend sind wir stolzer Besitzer eines A5 Sportback S-line 2,7 Diesel Aut. Bj. 2009 scheint alles soweit ok zu sein mit dem Audi nur hat der Wagen keine gute Bereifung mehr und die jetzigen Felgen haben mich auch nicht 100% angesprochen, daher würde ich eventuell die Puschen tauschen ich habe da schon was im Blick, es ist aber eine Felge für den F5/B9.
Würden diese Felgen auf dem A5 Sportback 2,7D passen, wie würde es aussehen weil die Felge ja schmaler zu sein scheint und muss ich es dann eintragen lassen?
Vielen Dank und viele Grüße aus SH
DATEN DER FELGEN:
Teilenummer: 8W0 601 025 EE
Größe: 8,0Jx18H2 ET31
Lochkreis: 5x112
DATEN DER REIFEN:
Hersteller: Continental
Reifenbezeichnung: ContiWinterContact TS 810 S A0 (Audi Kennzeichnung)
Saison: Winter (M+S)
Größe: 245/40 R18
(Bild von F5 Felge im Anhang)
Screenshot-20211116-130706-ebay-kleinanzeigen
Passt ohne Probleme drauf, muss aber eingetragen werden.
Conti TS810 der müsste aber schon was älter sein....?
@teletapi schrieb am 17. November 2021 um 10:22:38 Uhr:
Ok danke bin mir noch unsicher weil ich die Felgen eintragen müsste und höchstwahrscheinlich würden sie auch zu weit drinne stehen im Radkasten, das Felgendesign an sich gefällt mir sehr gut aber mal schauen.
wir haben einen Audi A5 Cabrio 3.0 TDI DSG Sportline aus 03/2012 (Schlüsselnummer 0588/ASJ000048) mit 255/35R19 Sommerreifen drauf.
Wir würden jetzt gerne mit den Originalen Audi Felgen die Ganzjahresreifen Michelin CrossClimate 2 245/40 R18 97Y XL fahren wollen ... ist das zulässig oder müssen wir auch noch neue Felgen haben...?
... welche Reifengrößen kann man auf den Originalen Audi S5 Felgen montieren...?
Vielen Dank im Voraus für Eure Hilfe!
Lieben Gruß aus Hamburg, DC
[Von Motor-Talk aus dem Thema 'Welche Reifengrösse auf die Orginalen Audi A/S 5 Felgen?' überführt.]
Audi S5 Reifengrößen
Im Grunde das was im COC steht darfst du Eintragungsfrei fahren, das Papier ist individuell zum Gefährt.
https://www.motor-talk.de/.../...eifen-kombinationen-t6471202.html?...
Stehen da 255'er drin?
Dann mit Sicherheit auch auch 18" !?
Sonst Mal auch anbei reingeschaut:
edit
Natürlich sind 19 und 18 Zoll zweierlei,...auf den 19" sind da nur die 255/35 Freigegeben.
@Don-Camilo schrieb am 11. Januar 2023 um 18:15:13 Uhr:
Die Reifengröße ist zulässig und steht auch auf dem Aufkleber der an der Fahrertürseite im Türrahmen befestigt ist.
Aber.
Die Sommerreifen 255 35 19 sind auf 19 Zoll Felgen
Die Ganzjahresreifen 245 40 18 sind für 18 Zoll Felgen. Also ja Dafür braucht ihr andere/neue Felgen.
