6.6l big block o. small block?
mich würde mal interessieren ob ein 6,6l oldsmotor ein big oder small block ist.
danke,
-fullsize-
27 Antworten
Big Block, ich glaub Small Blocks sind bis 4 Liter oder so, dadrüber is alles Big.
Glaub ich. Lasse mich gerne eines besseren belehren falls dem nicht so ist.
Hawkeye
bin mir ziemlich sicher, dass der 5.7er noch ein small block ist. aber ab wann fängen die big blocks an?
hi,
hier gibts ein paar infos.
greetz,
suffocator
Allgemeine Info:
Is it a Big Block or Small Block (1964 - 1990) Engine?
There are three ways:
A big block measures 14" between the heads at the manifold base, while a small block measure 12" between the heads at the manifold base.
Facing the front of the engine, at the top surface of the timing chain area, to the left of the oil fill tube, there is a code about 1.5" high followed by the casting number. A letter indicates a big block, a number indicates a small block.
A tell-tell sign is that the big blocks have a little hump in that area, whereas the small blocks are flat the whole way across.
Big Block CIDs
CID Years Bore Stroke VIN Color
400 '65 - '67 4.000 3.980 Bronze
400 '68 - '69 3.870 4.250 H[,V] Bronze
425 '65 - '67 4.126 3.975 O[,P,R] Red; Toronado is Blue
455 '68 - '72 4.126 4.250 W Red; Toronado & 1970+ is metallic Blue
455 '72 - '76 4.126 4.250 S,T,U,V,W metallic Blue
Small Block CIDs
CID Years Bore Stroke VIN Color Notes
260 '75 - '82 3.500 3.385 F metallic Blue
'79 - '80 3.500 3.385 metallic Blue Diesel
307 '80 - '84 3.800 3.385 Y Black No roller lifters, and w/5A heads: 150hp
'85 - '90 3.800 3.385 Y Black Roller lifters, and w/7A heads: 140hp
'83 - '90 3.800 3.385 9 Black 442, H/O engine; Roller
lifters w/7A heads '86 and up.
330 '64 - '67 3.938 3.385 T Gold
350 '68 - '72 4.057 3.385 M Gold
'73 - '74 " " " metallic Blue
'76 - '80 4.057 3.385 R metallic Blue
'78 - '79 4.057 3.385 B metallic Blue
'80 4.057 3.385 8 metallic Blue
350D '78 - '81 4.057 3.385 Z metallic Blue Diesel; Roller lifters '80 and up
350D '78 - '85 4.057 3.385 N metallic Blue Diesel; Roller lifters '80 and up
403 '77 - '79 4.351 3.385 K metallic Blue
Hoffe das hilft weiter.
Moin Fullsize!
Smallblock = Zündverteiler hinten (zwischen Motor und Fahrer)
Big Block = Zündverteiler vorne (zwischen Motor und Stoßstange).
Jedenfalls bei Mopars. Da gehört alles ab 361cui (also knapp 5,9l) zu den Big Blocks. Womit der 5,7l also ein Smallblock wäre. Ausnahme: der 350cui Big Block (1958 - 1962)
Bei den BB kann man dan noch zwischen B und RB unterscheiden. Zu den RB´s gehört alles ab 413cui. RB heißt Raised Block, weil- wie soll man das jetzt beschreiben? Wenn Du Dir ein V vorstellst (unsere Lieblingsmotoren quasi von vorne betrachtet), ist das V vom RB etwas größer als das vom B. Wobei der Winkel sich aber nicht verändert. Die Köpfe sind also weiter von der Kurbelwelle weg?!
Dennis
Also ich dachte immer diese Unterteilung würde nur auf Chevy Motoren angewendet, da reichen die BB von 366 cui bis 510 cui. Um die 400 cui gibt`s einige Überschneidungen, aber äußerlich hat der BB für mich immer einen Krümmerflansch mit gleichen Abständen und der SB die mittleren Beide eng zusammen liegend.
Gruß Helmut
Der Olds 403 ist ein Smallblock. Die Grenze zwischen Small und Bigblock liegt bei allen GMs ca. um 400cui (Olds 403 aus Trans am ist Smallblock, Pontiac 400 ist BB).
Das mit den Zündverteilern hat nix mit Big oder Small zu tun sondern nur mit der Marke.
grüassle
pat
danke für die antworten!
jetzt weiss ich endlich wie das alles zusammenhängt
-fullsize-
@ Schmuddi: Sach ich ja, bei Mopars 😁
gruß
Dennis
hey leute mal ne frage hab nicht wirklich viel ahnug von solchen motoren..
jedoch würde ich gerne wissen ob es da überhaupt grössere technische unterschiede zwischen den BIGblocks und SMALLblocks gibt.
denn ob nun der zündverteiler vorne oder hinten sitzt oder der abstand um 2" variiert ist doch keine grösseren einwirkungen auf die technik...oder seh ich dasd falsch??
ich denk mal, die big blocks sind einfach nur von den äusseren dimensionen grösser, oder?
Smallblock und Bigblock sind Bauformen. Das hat nix mit Hubraum zu tun. Bei Chevy gibt es z.B. einen 396 Bigblock und einen 400 Small Block.
Der Bigblock ist massiver, schwerer und auch grösser als der Smallblock.
Gruss Jürgen
axo..
also reintechnisch ähnlich und hat nicht solche unterschiee wie zb V oder R motoren...
danke
Small und BigBlocks sind V-Motoren. Der Big Block hat natürlich wegen seiner Grösseren Form auch vom Hubraum her mehr Möglichkeiten. Bei Chevy gehts da Serienmässig bis 502 cid! Sind ca 8 L!
Der Grösste Seriensmallblock ist glaub ich der 400 ci motor. Wobei man die auch bis 427 ci aufmachen kann. Dann ist man aber langsam an den Grenzen.
Gruss Jürgen
