Wabengrill auch für den A4 8K .. siehe Bild..
Audi A4 B8/8K
der titel ist schon selbsterklärend 🙂 gibt es einen grill ähnlich wie dieser auf dem bild zu sehende.. ist zwar nen a5, s5 aber kann ja sein das es die art auch für den 8 k gibt 🙂
ich danke schonmal 🙂
230520111983
Hello, first of all. I'm belgian and my deutch isn't that good. I had to use a translator to read this forum, so please take it easy on me 🙂.
The monza grey car with the RS5 grill is mine.
For those interested, i installed the OEM RS5 grill, not the replica grill.
Anyway, it isn't a direct fit. As shown in the above linked topics and on my audizine topic (dasquade a4 b8 avant) you will see the top arc of the grill don't fit the grill. It isn't that much different but for a proper fitment the bumper needs some grinding and repaint. I had a second hand S4 bumper for the project, so it was worth it. On the grill itself, the A5/S5/RS5 adjusting arms needs to be cut off. You will also need two custom L shaped brackets to keep the top mounting bolts attached to the car strut bar.
Additionally as seen in the pictures the bumper had a gap between bumper and hood and between bumper and enigne bay cover. I covered bought with polyester filler.
It takes some time and work, but i'm very happy with the result.
*Soon i will replace the rear with RS5 valance.
If not mistaken, that first picture posted of the white audi with honey grill is the new Reiger 'RS5 style' front bumper that will soon be released. Not sure if it will use the OEM RS5 grill or if they made their own grill. I suppose they used the RS5 grill.
If you have any question, shoot.
61 weitere Antworten
61 Antworten
Wenn es den nur in Facelift gibt was ist das dann für ein Auto ?
Zu den Rädern:
Passen nicht so einfach! Von der Breite und ET kein Problem aber die Mittelpochzentrieru g ist 57,1 und muss auf 66,5 gebracht werden! Reifen sind 245/30 20
Zur Blende:
Kann man direkt bei Audi bestellen! Wird einfach nur über die Nummernschildaussparung gesetzt und fertig. Ging meiner meiner Variante natürlich nicht! Mussten einige Anpassungsarbeiten gemacht werden, damit es auch gut aussieht! Ohne Nummernschild ist praktisch und sieht definitiv besser aus, da das Blau vom EU-Kennzeichen überhauptnicht zum Fahrzeug passt :-D
Passend zum heutigen Tag würde ich sagen "APRIL, APRIL" :-D Gibt es definitiv nicht! Sollte ich falsch liegen, kannst Dir bei mir nen Kasten Bier abholen! Wird aber nicht passieren :-D
Original geschrieben von eisenmaster
Zur Blende:
Was kostet diese? Evtl eine Teilenummer dazu?
Teilenummer hab ich nicht! Glaube 55€... Gibt's in unterschiedlichen Farben oder man lackiert sie einfach in der Wunschfarbe! Meine ist in Wagenfarbe, wie der ganze Rest ;-
Update, endlich wieder mit RINGE!!!
Ich habe meinen hier geholt
http://www.jcsportline.net/en/product-detail-3459.html
Kostet der Grill da? Stehen keine Preise
Ich habe 270.- Dollar inkl versand bezahlt. Die Teile kommen aus japan und sind ca 1 woche unterwegs gewesen. Der preis habe ich so verhandelt mit im. Wenn du mit im habdelst kannst kommst du sicherlich auch auf den preis. Ich habe den grill komplett in schwarz bestellt gehabt mit chrom audi ringe und parksensoren. Passgenauigkeit ist top und die verarbeitung auch!!! Hatte keine probleme!!
Hoffe konnte dir weiterhelfen ansonsten einfach eine PN schreiben.
Wabengrill mit US Blende und im neuem Farbkleid :-D
Servus,
wie schaut es eigentlich mit den Ringen aus ?
sind die bei der Lieferung dabei oder brauche ich die neu (ggf. Teilenummer)
Sind dabei und kanst zwischen chrom oder schwarz wählen
oh man ... stimmt, hatte ja chrom ausgesucht 😎😉
Audi-Ringe sind separat zum anschrauben!
wie hast du die Befestigung der PDC-Sensoren gelöst?
@all
Sind die Montagepunkte des Chromrahmens am Zubehörgrill die selben wie am Original?
Ich überlege mir einen Wabengrill mit Chromrahmen ohne Audilogo zu bauen, solchen gibt es soweit ich weiß mit vorhandenen Befestigungspunkten für PDC nicht zu kaufen.
Danke im vorraus für Bilder und ähnlich nützliches.
ich bin jetzt auch auf die Seite gestoßen jcsportline
gibt es da für das B8 facelift auch einen Waben Grill und gibt es Nebelscheinwerferblenden mit dem Abstandsassistenten?
Bin etwas verunsichert, da auf der Hompage folgendes steht AUDI A4 B9 2012-2013
wie sieht es mit dem Tüv aus, wenn ich mir die Spoilerlippe bestelle?
http://www.jcsportline.net/en/product-detail-4394.html
Chris
