VFIZ Endlich ist es soweit :) OBD auf FIS b6/b7
Audi A4 B6/8E
Hallo leute
War mal vorhin bischen auf youtube und da stieß ich auf folgendes Video klick . Es ist nun möglich , mann kann alles über FIS steuern , sogar Boost und Beschleuningungs Diagramme 🙂 Alles in einem soll es c.a 450 euro kosten . Es ist ein Kabelbaum was zwischen tacho angeschlossen wird , plug/play. Ich habe den entwichler angeschrieben und warte nun auf ne antwort . kabel VFIZ
Hallo leute
287 weitere Antworten
287 Antworten
Due lack of time no made official movie, but some user make preview one of screen layouts:
(Screen content is fully user configureable)
http://www.youtube.com/watch?feature=player_embedded&v=aVbn05ZRP7w
regards
Mariusz
Where i can buy it ??
@gturka36: At this you moment have to message me kicoro1@gmail.com, on days there will be official shop running.
Then soon support for A3 8P models and A6...
Hallo Mariusz
Support for Audi TT 8N?
Best regards
Not for a4 b6 ??
hallo
das hier ist auch sehr interessant.
https://www.youtube.com/watch?...
@TTDriver: "Support for Audi TT 8N?"
8N is based on vw mk4 platform, VFIZ can handle vw mk4, so it should work on 8N also but is not tested on it at all so I don't recomend it now for 8N
@golf5 dsg: vwAutopilet devices
Yes, it looks great. This based on very heavy modification of Tachometer, replacing inside screen and installind new arm cpu with its display, so milling, soldering, glueing inside tachometer electronics, it is not end user feasible. You eventually maybe could buy prepared whole tachometer then with labor it would be few times more expensive. This is probably to complicated to produce and later to maintain. In comment author wrote this was one-time tunning project. You also probably lost OEM warnings subroutines on have to rely on emulated ones if you are trustfull.
@Gturka36: "Not for a4 b6 ??"
Yes, it is for Audi A4 B6, B7 also for VW golf4, Octavia 1, Superb, Seat Leon, VW T4.. and compatibles
Gibt es in diesem Bereich was neues ? Hat jmd es bestellt -eingebaut??
Lg
Hello to all.
Long time wasn't here...
All very well, in meantime company moved to name to Qmatis and now own www.qmatis.de, www.qmatis.com, www.qmatis.eu domains.
You can browse there for devices and many accessories and order them online at once
(PayPal supported, need log-in to get access support/files areas, )
If you have some improvment suggestions don't hesitate to contact us 🙂
regards
Mariusz
gibt es neues hierzu ?
Hat jemand das Teil schon im Einsatz ? Erfahrungsbericht ?
Hello, here is actual look snapshot: http://www.youtube.com/watch?v=3jEyJ12DVq4
cheers
Mario
das sieht ja mal sehr gut aus. Wirklich sehr Interessant die Sache.
Preislich aber doch etwas hoch.
Was ich nicht so ganz verstehe ist die Aussage hier....
"Tachometerkanal so einstellen, um die Telematikdienste zu aktivieren. Im Hinblick darauf kann VFIZ mit der Telematik nicht kooperieren, wenn es in einem Fahrzeug installiert aber nur selten benutzt wird. Ich kann auch eine Version liefern, die nur auf Wunsch mit der Telematik kooperiert."
Hat es jemand schon mal ausprobiert ?
Ich meine es wird sogar ein Rückgaberecht angeboten.
Welch Version ist Sinnvoll ? Die normale oder die mit BT ??
Gruß Michael
In other words:
The VFIZ uses channel normally reserved for Telematics.
so if you have Telematics already in Car then can be confict with it,
otherwise not.
Telmatic is rather rarely installed.
Bluetooth is not needed for normall operation, this Bluetooth is not for Phone,
this is BT for sending telemetry for some custom external logging device.
Gruß Michael
