Tires DOT (manufacturing date)
Mercedes CLK 208 Cabrio
Good morning everyone.
Tires, DOT (manufacturing date) 1A57R PK1R how to decipher?
Thank you.
4 Antworten
This isn't the correct code. It must be four digits. For example, 0525. That means the fifth week of 2025.
https://www.kleinanzeigen.de/.../3018929066-223-3772
Even in this expired listing it is the same. I have never seen it either. The tires are those in the listing.
Solved, they have DOT week/year on the other side of the tire.
The code above is for something else but I'm still curious.
"for something else but I'm still curious".
From: https://www.autodoc.de/.../dot-nummer-auf-reifen?...
"The DOT number is located on the sidewall of a car tire and is usually stamped on the outer sidewall of the tire. It can be placed in different locations depending on the tire manufacturer and model, but is always in a clearly visible area. The DOT number begins with the letters "DOT," followed by a combination of numbers and letters indicating the manufacturer, production location, and date of manufacture".
Date of manufacture is missing on picture 2 of the Tirewall... 🙄
1
2
