Software-Update Kombiinstrument und Radio
Audi A4 B8/8K
ich möchte die Software meines Kombiinstrument und Radios updaten (lassen)
Muss ich dazu zum Freundlichen?
Was kostet mir der Spaß dort ca?
Kann es auch jemand anderes updaten?
Welches Equipment braucht man um das update selber durchzuführen? (Nur aus Interesse)
Vielen Dank im vorraus!
78 Antworten
you only have to update GW for display efficiency bar
sorry double post
sorry double post
For instrument cluster to display oil temperature I believe it is TPI 2019624 and SVM: B817A003.
My Q5 2009 tfsi (211) does not display oil temperature or oil temperature symbol, though lap timer works fine.
What is GW???
I read somewhere that Gateway also needs to be updated to firmware 120 in order to display the efficiency bar.
Not tried them yet. I did my research and these are my findings.
Gateway ^
you need update for Cluster instrument for oil temperature
not gateway
ok thanks 🙂 I will not ask for gateway (tomorrow is my appointment).
Why is GW update important?? Some people need 120 firmware even without towbar.
@Scotty18 schrieb am 29. Januar 2017 um 17:39:18 Uhr:
I will install a drive select so maybe this is useful, but also I would like to see the efficiency bar.
@apoelistas schrieb am 29. Januar 2017 um 16:52:40 Uhr:
1. The firmware is 8T0907468__120.sgo.
2. The towbar fitting goes with Can Bus Gateway update SVM 050200 which updates firmware to 0120.
I believe 1 and 2 are the same.
Ist das nicht der Code zur Nachrüstung AHK?
SW 0105 reicht auch für die Verbraucheranzeige und pssst zu SVM
Yes you are correct. It is the towbar SVM so it is wrong.
The correct for gateway is SVM: 19A002 (TPI 2023517/3, TPI 2029209/1)
I am happy I found it.
http://www.audiworld.com/.../#post24915601
Project is successful. All control modules were updated. Instrument cluster displays oil temperature and efficiency program, in my Audi Q5 2009 tfsi 211 hp. See my pictures in the link and the control module numbers before update and after update.
mal ne Frage gibt es hierfür schon einen SVM Code? (Kombiinstrument --> Energieanzeige)
oder ist das der SVM: 19A002
zerocrash
das ist das update vom GW damit der "balken" funktioniert
heist Energieeffizenz und die Öltemperatur
oder muss das KI auch noch geflasht werden dann.
KI muss auch geupdated werden
gibt es hier einen SVM Code? bzw wie geht der Freundliche hier vor
