Fußgängererkennung und Infotainment beim XC60
Volvo XC60 D
Pressemitteilung von VOLVO von gerade eben:
Now the Volvo XC60 also gets Pedestrian Detection and the new infotainment system
As of the end of November 2010, the Volvo XC60 can be specified with the new Pedestrian Detection with Full Auto Brake safety system.
At the same time, the XC60 gets the new infotainment system that has been introduced in the Volvo S60 and V60. All the information is presented in a five or seven inch colour screen integrated into the upper part of the centre console.
The new four-cylinder direct-injection 1.6- and 2-litre GTDi engines are now beginning to make their entry throughout the entire Volvo Cars' model range.
Pedestrian Detection with Full Auto Brake, which was introduced in the new Volvo S60 and V60, is now also available in the Volvo XC60. This is a support function that helps the driver detect potentially dangerous situations and can actively help avoid the nightmare scenario of colliding with a pedestrian.
Pedestrian collisions occur on a daily basis in the increasingly intensive traffic environment. For instance, 16 percent of all those killed in traffic in Sweden are pedestrians. The corresponding figure for the USA is 11 percent, Germany is at 13 percent and in China the figure is as high as up to 25 percent.
First a warning, then full braking power
Pedestrian Detection with Full Auto Brake uses radar and camera technology to watch out for pedestrians in front of the car. The main purpose of the initial warning is to alert the driver so he or she can brake or steer out of the way. If the driver does not respond to the warning, the car automatically brakes with full force moments before the collision becomes unavoidable. With automatic braking, collisions can in certain circumstances be avoided at speeds of up to 35 km/h.
It is estimated that if all cars were fitted with Pedestrian Detection with Full Auto Brake the number of pedestrians killed would be able to be reduced by more than 20 percent. The corresponding figure for serious injuries is almost 30 percent. In three cases out of ten, the collision may be able to be entirely avoided. The estimates are based on pedestrians being hit by the front of the car.
Pedestrian Detection with Full Auto Brake doesn't function in situations when the camera's capacity is affected, for instance in the dark and in poor weather. It is always the driver that is responsible for driving safely.
Can also avoid rear-end impacts
The collision warning system is also programmed to react if the vehicle in front is at a standstill or is moving in the same direction as one's own car. In certain situations, a collision may be avoided if the speed difference between the two vehicles is below 35 km/h. The technology is active in all speeds.
In the comfort stakes, the Volvo XC60 with automatic transmission is now available with the latest version of Adaptive Cruise Control (ACC), which automatically helps maintain a pre-set gap to the vehicle in front. New is that this works also when driving in slow-moving traffic, all the way down to standstill. The car accelerates automatically when the traffic gets moving again.
A camera in the grille with a 180 degree field of vision is one new feature in the XC60's accessories range. This camera is a significant asset in road junctions with limited visibility and also when parking. The view from the camera is presented in a screen integrated into the centre console.
Same infotainment system as the S60 and V60
The Volvo XC60 is also being upgraded with an entirely new infotainment system where information from the audio system, navigation unit, mobile phone and other functions is presented in a five-inch or seven-inch colour screen in the upper part of the centre console. This screen is positioned high up in the driver's field of vision to make it easy to keep his or her eyes safely on the road.
All the functions can be operated via buttons built into the steering wheel or controls positioned immediately below the colour screen. In addition, there is a separate remote control.
At the same time, the XC60 gets the same type of centre stack and the same range of audio units as recently introduced in the Volvo S60 and V60.
The most advanced audio unit, Premium Sound, has a Class D digital 5x130W amplifier with circuits from Swedish experts Anaview, Dolby Digital in combination with Dolby Pro Logic II Surround, the latest MultEQ from Audyssey Laboratories and 12 loudspeakers.
In addition to Premium Sound, which comes with a seven-inch screen, there are three other audio systems to choose between.
Two-litre GTDi engines in several models
The new four-cylinder direct-injected 1.6-litre and 2-litre GTDi engines are now becoming available in a wide range of Volvo models.
The new GTDi (Gasoline Turbocharged Direct Injection) T5 engine has a displacement of two litres and produces no less than 240 hp. Torque is a healthy 320 Nm.
The T5 engine in combination with Volvo's automatic six-speed Powershift transmission becomes available in the Volvo S80, V70, XC60, S60 and V60 models. Powershift works in principle like two parallel manual gearboxes with separate clutches, resulting in lightning-swift and fuel-saving gear changes.
The T5 is also available with a six-speed manual gearbox in the Volvo S80, V70, S60 and V60.
"We have succeeded in making a four-cylinder engine that is as powerful as a 2.5-litre five-cylinder unit - but much more energy-efficient. This is a welcome development both for the environment and for those customers who want high performance and good driveability. One of the most important explanations behind the result is our patented new turbo system which has been tailor-made for smaller, more energy-efficient engines," says Paul Welander, acting Senior Vice President Product Development at Volvo Cars.
Two new 1.6-litre GTDi engines
Two versions of a new 1.6-litre GTDi engine are also being introduced: the T4 with 180 horsepower and the T3 which produces 150 horsepower. Torque in both versions is 240 Nm, and both engines offer excellent pulling power throughout the speed range. The torque curve is relatively gentle, which promotes a particularly comfortable driving experience.
The T4 engine is available with Powershift or a six-speed manual gearbox in the Volvo S80, V70, S60 and V60.
In the Volvo S60 and V60 with manual gearbox there is also a start/stop function which switches off the engine when the car is at a standstill with the clutch pedal released and the gear lever in neutral. The engine starts up as soon as the driver presses the clutch pedal.
In the Volvo S60 and V60, the T3 engine is only available in combination with a manual gearbox and start/stop function.
In the S60 and V60 both transmission variants have a DRIVe button in the instrument panel to switch the fuel-saving functions off and on:
Powershift comes with a new function that disengages drive when the driver lets the car coast with the accelerator fully released. This reduces rolling resistance and helps cut fuel consumption. In cars with the manual gearbox, it is the start/stop function that is controlled by the DRIVe button.
Upgraded diesels in the XC90
In the Volvo XC90 the two five-cylinder diesel engines have been upgraded with higher performance, at the same time as their fuel consumption has decreased. Both variants come with an automatic gearbox.
The four-wheel drive Volvo XC90 D5 now produces 200 hp and maximum torque of 420 Nm. Fuel consumption has dropped from 8.5 l/100 km (EU Combined) to 8.3 l/100 km.
The corresponding figures for the front-wheel drive Volvo XC90 D3 are 163 hp and 340 Nm. Here fuel consumption is down to 8.2 l/100 km.
Both engines are certified according to the Euro 5 standards.
rausgenommen weil formatstörend ...
Descriptions and facts in this press material relate to Volvo Cars' international car range. Described features might be optional. Vehicle specifications may vary from one country to another and may be altered without prior notification.
To browse this release online, please visit
https://www.media.volvocars.com:80/go/...5-4b76-b40a-b3bde3f87b39.aspx
21 Antworten
Und ich habe es euch allen gesagt, der XC60 bekommt ein neues Amaturenbrett!😁
Und die Frontkamera gibt´s nun auch im XC60.
Vorallem aber die "Stop & Go"-Automatik würde mich echt interessieren.
alpa71
Irgendwie drängt sich der Verdacht auf, dass bei all den Neuerungen die Top-Modelle der Marke, V70 und S80, vernachlässigt werden… 🙄
Gibt es die frontkamera in irgend einem Paket ?
@ filiushh
V70/S80 und XC70 werden das Stop and Go System sowie die Fussgängererkennung im Frühling erhalten. Hab ich neulich im Geschäft gelesen...
Stimmt, das erscheint mir auch so leider! Aber einer wird irgendwie völlig vergessen: der XC90!
Aus meiner Sicht ist das keine Absicht, sondern liegt am Innendesign. V70 und S80 werden mit dem Möglichen bedacht (City Safety, Fußgänger-Erkennung), aber die Updates bei Navi und Soundsystem (Menüführung über Bildschirm etc.) passen nicht ins aktuelle Cockpit mit seinem ausfahrbahren Navi-Bildschirm. Und so einfach in die Mittelkonsole einen Bildschirm reinklatschen wäre auch nicht viel besser.
Wieso vergessen? Der Wagen basiert halt noch auf der P2 Plattform, ist das älteste Modell im Volvo Programm. Denke kaum das der viel von der neuen Technik bekommen wird.
Gruß, Olli
Gruß, Olli
... ist das älteste Modell im Volvo Programm 😕 😁
er kommt, der XC90 2011/2012 😮.
LG
Vidaman
nur die Ruhe 😉
Hab ich auch schon aus sicherer Quelle erfahren dürfen....und freue mich drauf! Er ist dann sicherlich preislich eine interessante Alternative!
Zum zweiten Teil: ich glaube eher, dass der XC90 II deutlich teuere als der jetzige wird. Das zeigt doch jegliche Erfahrung, mit allen Marken.
Der aktuelle XC90 ist auch deshalb "so preiswert" weil die Maschinen abgeschrieben sind, und er eigentlich schon aufs Altenteil sollte. Und: er basiert auf der alten Plattform.
Ja, das sehe ich auch so, Jürgen. Aber ich mag ihn irgendwie immer noch, und wenn er nun noch ein gelungenes Facelift bekommt, stellt er sicher für viele noch eine Alternative zu den wesentlich teureren
X5 und Co. dar und für Volvo wird er damit zur echten Cash-Cow. Ein Youngtimer ab Werk sozusagen! ;-)
Unter den großen SUV´s sicher auch der sympathischste!
Ein Paket habe ich noch nicht entdecken können, geschweige denn als Einzeloption. Lediglich die Möglichkeit die Frontkamera beim XC60 (ab KW46) nachrüsten zu lassen.
Hier zu den Informationen von Volvo inkl. der Einbauanleitung:
http://vccs.volvocars.se/.../drivers-support
Zu den möglichen Preisen habe ich noch nichts gefunden. Die Zubehörpreisliste ist ja seit mehreren Wochen in Überarbeitung. In der neuen Liste wird sicher dann der Preis stehen.
Eine Nachrüstung bei den XC60-Modellen, die vor der KW46-2010 produziert wurden, ist sicher nicht möglich.
alpa71
alpa71
Da hoffe ich jetzt, dass die nächsten 3 Jahre Leasing genauso schnell vergehen wie das erste Jahr. Bei diesen ganzen Updates und Neuerungen freue ich mich schon auf die MOPF. 🙂
