Adaptive Cruise Control nachrüsten
Audi A4 B8/8K
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 weitere Antworten
1798 Antworten
Scotty18
– for your records – there is example of ACC (ACC3) coding for 2013 Q5 3.0TDI, Auto Trans, Australian = Left-hand traffic; 008190
http://forums.ross-tech.com/showthread.php?...
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 008190
008190 hex = 33168 dec
According to Q7 codding translation:
3xxxx: 3.0 litre TDI with automatic gearbox 09D =OK
x1xxx: Position 4 is always coded as 1 = here we get 3 - could be Position 4 is for Left-hand traffic?
xx1xx: Position 3 is always coded as 1 = OK
xxx6x: Rest of the World (km/h) = OK
xxxx8: Without optional extra trailer function = OK
Hallo Leute,
Bin neu hier und habe nun auch vor ACC in meinem A4 8k 2.0 TDI nachzurüsten.
Nachdem ich soeben unfähiger Weise gleich mal ein Thema gestartet habe anstatt hier zu antworten waage ich noch einen Versuch.
Dazu hab ich auch gleich eine Frage, die hoffentlich noch nicht in einer der letzten 65 Seiten gestellt wurde (habe zwar einen Großteil gelesen, aber alles nicht 😉 ). Ich könnte einen Lenkstockschalter mit der Teilenummer 8K0953502AL
bekommen. Soweit ich bis jetzt erkennen konnte ist dieser aber aus einer Limo... Kann ich den auch in meinem Avant verbauen oder wird er da nicht funktionieren??
Vielen Dank schonmal
scorpy-john
limo = kein heckwischer!
mit viel Arbeit kann man den rechten Hebel wechseln
Is' vielleicht Fummelarbeit, aber als "viel" würde ich das jetzt nicht bezeichnen😉
Ich denke, man fährt am besten, wenn man den Lenkstockhebel neu beim Freundlichen bestellt. Es gibt viele unterschiedliche Ausführungen davon. Den richtigen gebraucht zu erwischen ist eher selten 😉
Hätte man auch selbst drauf kommen können 😁
Ich denke den rechten Hebel zu wechseln ist für mich keine Alternative... Was kostet denn der Lenkstockhebel neu vom Freundlichen?
ca. 185-190€
ca. 185-190€
Da ist das Lenksäulensteuergerät aber noch nicht dabei, oder?
Ich habe außer die beiden Teile jetzt alles zusammen. Gibt es denn jemand im Großraum Frankfurt, der mir das nach dem Einbau kalibrieren könnte?
nein nur der Hebel; stg noch mal das gleiche in etwa...
ich habe aber noch ein "M" da
ist für alles fähig und FL Version
Habe jetzt beides zusammen für 180 € geschossen. Eingefallen ist mir, dass ich auch noch das luftführungsgitter für acc brauche...
Kann mir einer die teilenummer sagen? Ist ein VFL ohne sline.
ich habe einen Avant EZ 06/2008 ohne S-Line. Ich habe mir das Gitter 8K0 807 682B gekauft. Müßte bei Dir auch passen.
Gruß Diabolino
Gruß Diabolino
Besten Dank! 🙂
Habe jetzt den Lenkstockschalter inkl. Schleifring verbaut. Danach habe ich die Fehlercodes gelöscht. Allerdings bleiben einige Fehler bestehen. Könnt ihr mir weiterhelfen, woran das liegen könnte? Hier der Log:
Sonntag,06,Juli,2014,14:16:11:52231
VCDS -- Windows-basierter VAG/VAS-Emulator
VCDS Version: DRV 12.12.2.0
Datenstand: 20140403
Fahrzeug-Ident.-Nr.: WAUZZZ8K3CA014770 KFZ-Kennzeichen: DA
Kilometerstand: 108130km Reparaturauftrag:
Fahrzeugtyp: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 56 5F 62 72
Fahrzeug-Ident.-Nr.: WAUZZZ8K3CA014770 Kilometerstand: 108130km
01-Motorelektronik -- Status: Fehler 0010
03-Bremsenelektronik -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: Fehler 0010
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
20-Fernlichtassistent -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAHA) Labeldatei: DRV\03L-906-019-CAG.clb
Teilenummer SW: 03L 906 022 NP HW: 03L 906 019 AL
Bauteil: R4 2,0L EDC H35 9098
Revision: 25H35---
Codierung: 12194012232403080000
Betriebsnr.: WSC 06334 000 00000
ASAM Datensatz: EV_ECM20TDI03L906022NP A02009
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 8003830383038303833-80D5
2 Fehlercodes gefunden:
4698 - Funktionseinschränkung durch empfangenen Fehlerwert
U1113 00 [039] - -
unbestätigt - geprüft seit letzter Löschung
Freeze Frame:
Fehlerstatus: 00000001
Fehlerpriorität: 6
Fehlerhäufigkeit: 2
Kilometerstand: 108136 km
Datum: 2014.07.06
Zeit: 14:06:58
4699 - Funktionseinschränkung durch empfangenen Fehlerwert
U1113 00 [039] - -
Freeze Frame:
Fehlerpriorität: 6
Fehlerhäufigkeit: 2
Datum: 2014.07.06
Zeit: 14:06:58
Readiness: 0 0 0 0 1
Adresse 03: Bremsenelektronik (J104) Labeldatei: DRV\8K0-907-379.clb
Teilenummer SW: 8K0 907 379 BH HW: 8K0 907 379 BH
Bauteil: ESP8 front H04 0060
Revision: -------- Seriennummer: --------------
Codierung: 164D04
Betriebsnr.: WSC 06334 123 12345
00778 - Geber für Lenkwinkel (G85)
013 - bitte Fehlerspeicher auslesen
Freeze Frame:
Fehlerstatus: 01101101
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 162
Zeitangabe: 0
Datum: 2014.07.06
Zeit: 14:11:59
Freeze Frame:
Hex Wert: 0x0000
Hex Wert: 0x0022
Hex Wert: 0x121C
Hex Wert: 0x23A2
Hex Wert: 0x00FF
005 - keine oder falsche Grundeinstellung/Adaption
Freeze Frame:
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 162
Zeitangabe: 0
Datum: 2014.07.06
Zeit: 14:11:59
Freeze Frame:
Hex Wert: 0x0000
Hex Wert: 0x0022
Hex Wert: 0x121C
Hex Wert: 0x23A2
Hex Wert: 0x00FF
Adresse 05: Zugangs-/Startber. (J393) Labeldatei: DRV\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 CN HW: 8K0 907 064 CN
Bauteil: BCM2 2.0 H05 0435
Revision: 00002001
Codierung: 032200
Betriebsnr.: WSC 06335 123 12345
VCID: 7EFF7DFB79F775F371F-802B
Subsystem 1 - Teilenummer SW: 8T0 959 754 D HW: 8T0 959 754 D
Bauteil: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Bauteil: J764 ELV MLB H37 0042
Kein(e) Fehlercode(s) gefunden.
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: DRV\8Tx-820-043-3Z.clb
Teilenummer SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Bauteil: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Seriennummer: 01150620111361
Codierung: 34200000
VCID: 7AF771EB65DF59D34D7-802F
Adresse 09: Zentralelektrik (J519) Labeldatei: DRV\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 P HW: 8K0 907 063 P
Bauteil: BCM1 1.0 H30 0392
Revision: 10030001 Seriennummer: 00000001108637
Codierung: 690040B10174A7210601000300005F5F4F9C060806000141000000
VCID: 3C7BB7F32F6BA7E31FB-8069
Subsystem 1 - Teilenummer SW: 8K1 955 119 A HW: 8T1 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS 150611 H07 0070
Codierung: 00FD11
Subsystem 2 - Teilenummer SW: 8K0 955 559 HW: 8K0 955 559 Labeldatei: DRV\8K0-955-559.CLB
Bauteil: RLS H04 0003
Codierung: 025028
Subsystem 3 - Teilenummer SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Bauteil: E1 - LDS H03 0031
Adresse 10: Einparkhilfe 2 (J446) Labeldatei: DRV\8K0-919-475.clb
Teilenummer SW: 8K0 919 475 AA HW: 8P0 919 475 N
Bauteil: PARKHILFE 8K H01 0081
Revision: 11001001 Seriennummer: 12591116590393
Codierung: 100203
Betriebsnr.: WSC 06335 000 00000
VCID: 78F36BE35BD34BC33B3-802D
Adresse 15: Airbag (J234) Labeldatei: DRV\8K0-959-655.clb
Teilenummer SW: 8K0 959 655 L HW: 8K0 959 655 L
Bauteil: AirbagVW-AU10 H44 0610
Seriennummer: 003JMD0CNJR9
Codierung: 30523435363030303030554A304C384B3053
ASAM Datensatz: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 468FD51B61A7ED3379F-8013
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 6334MSME6135791FK
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 6344MSME60554B2CJ
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 6352QSME220C25404
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 6362QSME280C10528
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 63732SME391F06640
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 63832SME261F19742
Adresse 16: Lenkradelektronik (J527) Labeldatei: DRV\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 G HW: 8K0 953 568 G
Bauteil: Lenks.Modul H13 0013
Revision: -------- Seriennummer: 90315IAL0000X
Codierung: 000017
VCID: 3E7FBDFB3977B5F331F-806B
3 Fehlercodes gefunden:
Freeze Frame:
Fehlerstatus: 01100101
Fehlerpriorität: 2
Fehlerhäufigkeit: 2
Verlernzähler: 162
Zeitangabe: 0
Datum: 2014.07.06
Zeit: 14:09:25
Freeze Frame:
(keine Einheit): 44.0
Text: 2CFFFFFF92FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFC0FFFFFFFF
Lambdafaktor: 4.24
Raw, Index/Key Err.: 255 255 000
Text: 1EFFFFFF86FFFFFFFFFFFFFFFF1E20060800
Geschwindigkeit: 65025.0 km/h
Klopfregelung: 16.0°
(keine Einheit): 0.0
01044 - Steuergerät falsch codiert
000 - -
Freeze Frame:
Fehlerstatus: 01100000
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 162
Zeitangabe: 0
Datum: 2014.07.06
Zeit: 14:09:25
02071 - Lokaler Datenbus
012 - elektrischer Fehler im Stromkreis
Freeze Frame:
Fehlerstatus: 01101100
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 162
Zeitangabe: 0
Datum: 2014.07.06
Zeit: 14:09:25
Adresse 17: Schalttafeleinsatz (J285) Labeldatei: DRV\8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 930 N HW: 8K0 920 930 N
Bauteil: KOMBIINSTR. H80 0639
Revision: 00000000 Seriennummer: JUG751E6C
Codierung: 0F0D100003000008000001
VCID: 3873ABE31B538BC3FB3-806D
Adresse 19: Diagnoseinterface (J533) Labeldatei: DRV\8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AE HW: 8T0 907 468 L
Bauteil: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Seriennummer: 5800F11517017B
Codierung: 00CF07
VCID: 840B8F13971B9F23A7B-80D1
Subsystem 1 - Teilenummer SW: 8X0 915 181 HW: 8X0 915 181
Bauteil: J367-BDM H07 0140
Subsystem 2 - Teilenummer SW: 8K0 959 663 HW: 8K0 959 663
Bauteil: J532_DCDCStab H17 0042
Adresse 20: Fernlichtassistent (J844) Labeldatei: DRV\8K0-857-511.clb
Teilenummer SW: 8K0 857 511 E HW: 8K0 857 511 A
Bauteil: FLA H04 0004
Revision: AA001002
Codierung: 01019164747464545425363E
VCID: 33699CCF0235689BCE1-8066
Adresse 42: Türelektr. Fahrer (J386) Labeldatei: 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 M HW: 8K0 959 793 M
Bauteil: TSG FA H12 0357
Revision: Seriennummer: 0000116972850
Codierung: 011C02204000410001
VCID: 4A97E12B75BF09539D7-801F
Adresse 46: Komfortsystem (J393) Labeldatei: DRV\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0151708947
Codierung: 0100062020B904408320023680000000
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei: 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 M HW: 8K0 959 792 M
Bauteil: TSG BF H12 0357
Revision: Seriennummer: 0000117244858
Codierung: 011C02204C00410001
VCID: 4995DE2770B9024B94D-801C
Adresse 53: Feststellbremse (J540) Labeldatei: DRV\8K0-907-801-V1.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0100
Revision: 00000003 Seriennummer: 20000000040825
Betriebsnr.: WSC 00000 000 00000
VCID: 346B9FD3073B6FA3D7B-8061
Adresse 56: Radio (R) Labeldatei: DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G1 035 053 HW: 4G1 035 053
Bauteil: Radio U Basic H41 0051
Revision: AB001007 Seriennummer: 048F+0BB012697
Codierung: 010003020100000001
VCID: DCBB97734F2B07E3BFB-8089
Adresse 5F: Informationselek. I (J794) Labeldatei: DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 8T1 035 652 G HW: 8T1 035 652 D
Bauteil: B-BN-EU H61 0147
Revision: -------- Seriennummer: 323FQ0B7654103
Codierung: 010100010006E0ED05000F0E000000030001
VCID: 3975AEE7205992CB04D-806C
Subsystem 1 - Teilenummer SW: 8T0 919 604 HW: 8T0 919 604
Bauteil: DU6 Basic H42 0084
Subsystem 2 - Teilenummer SW: 8T0 919 609 HW: 8T0 919 609
Bauteil: E0380 Bedient H08 0100
Adresse 62: Türelektr. hi. li. (J388) Labeldatei: 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 F HW: 8K0 959 795 F
Bauteil: TSG HL H11 0357
Revision: Seriennummer: 0000006371165
Codierung: 010C02204000210001
VCID: 458DD2175CA1E62B705-8010
Adresse 72: Türelektr. hi. re. (J389) Labeldatei: 8K0-959-795.clb
Bauteil: TSG HR H11 0357
Revision: Seriennummer: 0000006371151
Ende --------------------------------------------------------------------
1. Stg 13 (ACC) ist nicht in der Verbauliste eingetragen ->Stg 19 Gateway
2. Beim Lenkwinkelsensor wurde die Grundeinstellung nicht durchgeführt -> Stg 16 siehe Forum
3. Stg 16 ist falsch codiert! Auf ACC codieren.
Was mich ein bischen stutzig macht ist der Fehler mit dem lokalen Datenbus und dass das Stg 13 (ACC-Sensor) nirgend auftaucht. Ist das richtig verkabelt?
Ich habe das ACC Steuergerät bisher noch nicht eingebaut und daher normal auf GRA codiert, so wie ich es vorher auch hatte.
Sollte doch auch mit dem ACC Lenkstoclschalter funktionieren, solange ich kein ACC codiert habe oder?
