Passat 3BG 1.9 TDI 131PS Leistungsverlust
Hi Alle
Die sache ist die, mein auto macht richtig schlapp, motor klingt bei last wie ein asmatiker. haufen teile sind
(automatikgetriebe, turbolader, anlasser, hochdruckpumpe und vieles mehr)
neu oder überholt, es wäre schade um dem teil wenn s nicht reparabel aus kosten gründen.
LLM oem. wechsel hat nicht viel gebracht. LLM soll und ist wert liegt weit aus einander. nur bei rückwerts
fachren stimt es DD.
block 003
"Time","Engine Speed","Rev/Min","Intake airflow (load)","mg/h","Throttle Angle","mg/h","Throttle pos.reg. duty cycle","%"
.28125,81,"1701",116,"5800",154,"7546",212,"84"
.61328125,81,"1701",116,"5800",153,"7497",212,"84"
.94140625,82,"1722",117,"5850",158,"7742",212,"84"
1.26953125,82,"1722",116,"5800",160,"7840",212,"84"
1.6015625,82,"1722",116,"5800",152,"7448",212,"84"
1.9296875,84,"1764",123,"6150",151,"7399",212,"84"
2.26171875,84,"1764",122,"6100",160,"7840",212,"84"
Bitte um rat !! da ist log mit VW
12 Antworten
Hi Alle
Passat 3b6 tdi 131ps. motor AVF
abgase stinken gewaltig, AU werte super DD, kein rußen, keine fehler!"! scxheise((:
leerlauf
ist wert schwankt von 3900 bis 4700
"02-12-2014","04:19:04"
"038 906 019 GQ 1,9l R4 EDC ","G000AG 1524"
"Block Number = 3"
.330078125,42,"882",54,"2700",97,"4753",212,"84"
.6591796875,42,"882",54,"2700",91,"4459",212,"84"
.9892578125,42,"882",54,"2700",94,"4606",212,"84"
1.3193359375,41,"861",54,"2700",94,"4606",212,"84"
1.6494140625,42,"882",54,"2700",95,"4655",212,"84"
1.9794921875,42,"882",54,"2700",93,"4557",212,"84"
2.3095703125,42,"882",54,"2700",91,"4459",212,"84"
2.6396484375,42,"882",54,"2700",93,"4557",212,"84"
2.9697265625,42,"882",54,"2700",87,"4263",212,"84"
3.2998046875,42,"882",54,"2700",92,"4508",212,"84"
3.6298828125,42,"882",54,"2700",90,"4410",212,"84"
3.9599609375,42,"882",54,"2700",92,"4508",212,"84"
4.2900390625,42,"882",54,"2700",91,"4459",212,"84"
4.619140625,42,"882",54,"2700",90,"4410",212,"84"
4.94921875,42,"882",54,"2700",91,"4459",212,"84"
5.279296875,42,"882",54,"2700",91,"4459",212,"84"
5.609375,42,"882",54,"2700",92,"4508",212,"84"
5.939453125,42,"882",54,"2700",93,"4557",212,"84"
6.26953125,42,"882",54,"2700",93,"4557",212,"84"
hat jemand ahnung? schläuche geprüft. vtg leichtgängig. mit zwei LMM versucht gleiche resultat.
log-datei kann man mit wordpad öffnen
Hi. der AGR ist für testzwecken zu.
wenn zu wenig lüft auto wird rußen, wenn zu viel lüft wird zu wenig diesel eingespritzt. ist das so richtig?
wieso stimmt die luftmasse so gravieren nicht? was kann die ursache sein?
um fehler durch AGR ventil auszuschliessen kann man im mit eingrif in steurgerät und mit blech abstellen. mit offener AGR sind die werte genau so schlecht.
hast du das AGR Ventil einmal angeschaut? oder nur mit dem Tester?
Ein offenes AGR würde auch deine Werte verschlechtern...
Wenn die AGR mechanisch verschlossen worden ist, dann stimmt in Teillast der LMM Sollwert mit dem Istwert nicht mehr überein, das ist ganz zwangsläufig so und muß Dich bei Deinem Problem auch nicht interessieren.
Dein Problem ist mangelnde Leistung bei Last, dann mach einen Log unter Last.
Grüße Klaus
Was mich noch interessieren würde,
1. ist die Log Datei bei mechanisch verschlossenem AGR Ventil oder im normalen Zustand entstanden? und
2. Wurde die Log Datei bei stehendem oder bei fahrendem Fahrzeug gemacht?
Da bei Lastanforderung das Ventil für AGR geschlossen wird, könnte ein geöffnetes Ventil durchaus zu mangelnder Leistung führen.
Beste Grüsse
Original geschrieben von Wunderling
Was mich noch interessieren würde,1. ist die Log Datei bei mechanisch verschlossenem AGR Ventil oder im normalen Zustand entstanden? und
2. Wurde die Log Datei bei stehendem oder bei fahrendem Fahrzeug gemacht?Da bei Lastanforderung das Ventil für AGR geschlossen wird, könnte ein geöffnetes Ventil durchaus zu mangelnder Leistung führen.
Beste Grüsse
1) mechanisch und im steuergerät.
2) ganze datei bei fahrenden. ausschnitt im leerlauf.
leerlauf.
motordr.861 soll2700 ist4606 agr84%
1.3193359375,41,"861", 54,"2700",94, "4606",212,"84"
hast du das AGR Ventil einmal angeschaut? oder nur mit dem Tester?Ein offenes AGR würde auch deine Werte verschlechtern...
jap, bei turbowechsel wurde auch ansaugtrakt gereinigt und AGR getauscht auf einen gebauchten.
mit tester nicht.
Original geschrieben von Klausel
Wenn die AGR mechanisch verschlossen worden ist, dann stimmt in Teillast der LMM Sollwert mit dem Istwert nicht mehr überein, das ist ganz zwangsläufig so und muß Dich bei Deinem Problem auch nicht interessieren.Zitat:
Dein Problem ist mangelnde Leistung bei Last, dann mach einen Log unter Last.Grüße Klaus
HI. das ist unter last gang 2 oder 3
motordr.2142 (lmm soll8000) (lmm ist 9653) (agr 5% also last)
25.05078125,102,"2142",160,"8000",197,"9653",12,"5"
25.3828125,101,"2121",161,"8050",198,"9702",12,"5"
25.7109375,103,"2163",162,"8100",200,"9800",12,"5"
26.04296875,104,"2184",163,"8150",197,"9653",12,"5"
26.37109375,104,"2184",163,"8150",199,"9751",12,"5"
26.703125,105,"2205",162,"8100",198,"9702",12,"5"
27.03125,105,"2205",134,"6700",182,"8918",12,"5"
27.36328125,106,"2226",110,"5500",147,"7203",123,"49"
ich mach noch einen mit vollgas in 4ten 5ten
