Neuerungen der 3/2025er OTA Updates
Hallo Forum,
habe hier mal zusammengestellte Infos zu den OTA-Updates 3/2025 gefunden.
Vielleicht für den einen oder anderen interessant!?
Eventuell können hier User auch ihren Softwarestand eintragen, getrennt nach Mild-Hybrid, PlugIn-Hybrid und Elektrofahrzeug.
Ich habe einen X1 xDrive20d (Mild-Hybrid) mit Software-Stand 3/2025.50
Was noch nicht umgesetzt ist, ist die ortsabhängige Blockade der Öffnung des Fahrzeugs bei Annäherung.
(also Unterbindung des Komfortöffnens z.B. im Zuhausebereich)
Programming: Changes with 25-03 I level update that are perceptible to the
83598.1
H e r e y ou c a n fi n d c h a ng e s i n th e ve h i c le th a t a r e n ot i c e a ble b y th e c us t ome r, wh i c h a r e i n c lude d i n a n I le ve l u pda te 2 5 -0 3 .
The functions in this document apply to all vehicles from Service Pack 2021 and Service Pack 21R.
1. Personal eSIM
Relevant for markets: Germany, Austria, Switzerland, France, Netherlands, Belgium, Luxembourg, Spain, Portugal,
Italy, UK, USA, Japan, Korea
Affected vehicles: BMW: G45, U11, U06, F70, F74, U11, U10; MINI: U25, J01, F65, F66, F67, J05
Optional equipment required: SA-6PA
BMW: Personal eSIM expanded to include Wi-Fi hotspot and improved telephony: With this update, you can quickly
set up a Wi-Fi hotspot in your BMW that uses the vehicle's powerful external aerials. Optimised reception improves
the data connection. This enables you to make particularly good quality phone calls on the road.
about:blank 1/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
2. Lock/unlock
Relevant for markets: All BMW ConnectedDrive markets
Affected vehicles: All vehicles with Headunit High 4, Headunit High 5 and Headunit High 6
Optional equipment required: SA-322
BMW: Unlocking and locking now also via the My BMW App: From now on, you can also unlock and lock your BMW
using the My BMW App. This works from a distance of only a few metres and even if your smartphone does not
have an Internet connection. Using the BMW Digital Key Plus is the prerequisite.
MINI: Unlocking and locking now also via the MINI App: From now on, you can also unlock and lock your MINI
using the MINI App. This works from a distance of only a few metres and even if your smartphone does not have
an Internet connection. Using the MINI Digital Key Plus is the prerequisite.
3. Partial arming of alarm system
Affected vehicles: All vehicles with Service Pack 2021
about:blank 2/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
Optional equipment required: SA-322, SA-302, SA-6AE (without SA-8TV)
BMW: Reduced alarm function can now also be set via smartphone: After this update, you can control the motion
and inclination sensors by means of the My BMW App when you are near the vehicle. As soon as these alarm
functions are disabled, any false alarm caused by any movement or vibration is prevented. This is a useful option
when you park your BMW in a duplex garage or on a swaying ferry. Using the BMW Digital Key Plus is the
prerequisite.
MINI: Reduced alarm function can now also be set via smartphone: After this update, you can control the motion
and tilt sensors by means of the MINI App when you are near the vehicle. As soon as these alarm functions are
disabled, any false alarm caused by any movement or vibration is prevented. This is a useful option when you park
your MINI in a duplex garage or on a swaying ferry. Using the MINI Digital Key Plus is the prerequisite.
BMW:
MINI:
4. Open/close boot
Affected vehicles: All vehicles with Service Pack 2021 and Service Pack 2021R
Optional equipment required: SA-322 (without SA-8TV), SA-6AE, SA-316
about:blank 3/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
BMW: The tailgate can now also be operated via smartphone: With this update, you can now also open the tailgate
via the My BMW App when you are near your BMW. You can find this option under “Remote Controls”. If you keep
the button pressed, the tailgate will close again. Provided your BMW is equipped with automatic tailgate operation
and you are using the BMW Digital Key Plus.
MINI: The tailgate can now also be operated via smartphone: With this update, you can now also open the tailgate
via the MINI App when you are near your MINI. You can find this option under “Remote Controls”. If you keep the
button pressed, the tailgate will close again. Provided your MINI is equipped with automatic tailgate operation and
you are using the MINI Digital Key Plus.
BMW:
MINI:
5. MyMode efficient startup mode
Relevant for markets: All ConnectedDrive markets (excluding: USA, Canada, Korea, Brazil, India)
Affected vehicles: BMW: All vehicles with Service Pack 21 (BEV) with Headunit High 5 and Headunit High 6
Special equipment required: SA-802, SA-8LB, SA-8LA
BMW: My Mode EFFICIENT now as start mode: With this update, you no longer have to manually switch to My
Mode EFFICIENT after setting off. On request, your BMW automatically starts and drives in the most efficient
mode.
about:blank 4/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
MINI: Your MINI now drives in green mode right from the start: With this update, you no longer need to manually
switch to Green Mode after starting to drive. On request, your MINI will automatically start and drive in the most
efficient mode.
BMW:
MINI:
6. Home address exception
Affected vehicles: BMW: All vehicles with Service Pack 2021 with Headunit High 5
Optional equipment required: -
BMW: Comfort Access can now be adjusted for the home address: This upgrade allows you to adjust the Comfort
Access feature for your home address. In the Comfort Access menu, you can set your home address as an
about:blank 5/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
exception to disable automatic unlocking when passing by your BMW. This ensures your vehicle remains locked
when approaching until manually accessed.
7. Exception logic of heat management
Affected vehicles: BMW: All vehicles (BEV only) with Service Pack 2018 and 2021 (OS8, OS8.5, OS9)
BMW: Expanded battery heat management display: With this update, the “Prepare battery” icon appears not only
when outside temperatures are cold, but also when they are warm. You are therefore always informed when the
battery in your BMW has reached the ideal charging temperature. The icon is visible as soon as you have started
driving on the route to a quick charging station and as long as battery heat management for optimized DC
charging is active.
8. IPA Speech Alexa
Relevant for markets: USA
Affected vehicles: BMW: G45, F70, F74
BMW: Your BMW now understands more with Amazon Alexa: Your BMW can now process multiple voice
commands when you connect your Amazon account. With “Hey BMW”, it thus also reacts to commands that were
previously only possible using Alexa. The new function is initially available for music search and streaming. The
scope is constantly being expanded.
about:blank 6/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
MINI: Your MINI now understands more with Amazon Alexa: Your MINI can now process multiple voice
commands when you connect your Amazon account. With “Hey MINI”, it thus also reacts to commands that were
BMW:
MINI:
9. IPA Avatar Hong Kong
Relevant for markets: Hong Kong
Affected vehicles: MINI: All vehicles with Headunit High 6
MINI: New Avatar “Spike” for your MINI Intelligent Personal Assistant: Spike is available from now on as an
additional avatar for your MINI Intelligent Personal Assistant. This allows you to choose between visualisation of a
MINI or Spike. To do this, open the app settings of the MINI Intelligent Personal Assistant and select your preferred
animation.
about:blank 7/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
10. Plug and Charge PHEV
Italy, Nordics, UK, EU Mediterranean, Central Europe, Baltic States, USA, Canada, Korea
Affected vehicles: BMW: All vehicles with Service Pack 21: U06, U11, G60, G61, G70, G90, G99, G05, G09, G45
(PHEVs)
BMW: Charging with Plug & Charge soon also without app and charging card: This update prepares your BMW for
the Plug & Charge function that you will soon be able to use. In future, your vehicle will automatically authenticate
itself when you connect the charging cable. You do not require an app or charging card any more. Invoicing at the
end of the charging process also takes place automatically. The availability of the service depends on the charging
post provider.
11. Navigation user interface/user experience
about:blank 8/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
Affected vehicles: BMW: All Service Pack 2021 and Service Pack 21R vehicles with Headunit High 5
BMW: Faster starting of route guidance with navigation: Additional icons on the search bar in the BMW map view
now make it easier to select the destination. With one click, you can select your workplace and home directly or
remove stored destinations using the X button. You can use the new flag button in the search results to start route
guidance immediately. In addition, the most important functions are now opened when you open the map for the
first time.
12. Quality measure for climate comfort
Relevant for markets: USA, Brazil, Korea, China
Affected vehicles: BMW: G07 LCI (from build level >= 08/22)
Optional equipment required: SA-4NN
BMW: Faster heating and higher heater output in your BMW: Climate control performance is improved with this
update. The interior of your BMW now heats up even faster in cold temperatures. In addition, the heater output is
increased.
about:blank 9/123/3/25, 9:46 AM 13. Quality measure Remote Engine Start
Optional equipment required: SA-1CR
BMW: Remote Engine Start now functions even more reliably: This update improves the Remote Engine Start
function. The connection is more stable. Your BMW engine starts more reliably from a distance when you activate
the function using the My BMW App or vehicle key.
14. Head Unit optimisation
Affected vehicles: BMW: F70, F74, U06, U10, U11, U12 (only vehicles with Headunit High 6); MINI: F65, F66, F67,
J01, J05, U25
BMW: Control display with optimised performance: The overall performance, especially in the entertainment and
control display area, will improve after this update. Several features and functions are now even more stable. The
performance of your BMW system is thus improved and the user experience is visibly increased.
about:blank 10/123/3/25, 9:46 AM Programming: Changes with 25-03 I level update that are perceptible to the customer
15. Quality measure IPA Speech
Relevant for markets: UK, Ireland, Canada, USA, Mexico, France, Germany, Spain, Italy, Luxembourg, Liechtenstein,
Portugal, China, Austria, Iceland, Malta
Affected vehicles: BMW: G45, F70, F74; MINI: U25, J01, J05, F6x
BMW: Improved speech recognition and function for your voice assistant: Voice control access to contacts in the
selected phone book in the telephone app is now automatic - manual selection no longer necessary. Problems
with the detection of the “Drive me home” or “Drive me to work” commands have been solved. The search for and
detection of radio stations by your voice assistant has been improved.
MINI: Improved speech recognition and function for your voice assistant: Voice control access to contacts in the
Target groups : Independent Operator
Internal Location
Retailer Organisation
about:blank 11/123/3/25, 9:46 AM Branch : Car
Topic : Vehicle Programming
Sub-Group-1 : #SW#ISTA
Sub-Group-2 : BUSINESS-OP
Translate this document within
the next 5 minutes : No
2 Antworten
Seltsam, kann den PDF Dateianhang in der mobilen MotorTalk App nicht finden, in der PC-Version sieht man den Anhang?!
Wie immer eine ziemlich kryptische Beschreibung der "neuen" Funktionen.
Es wird zwar aufgezählt was alles neu funktionieren soll, aber der Weg dorthin bleibt oft im Dunkeln.
Das ist in der Anleitung / Handbuch nicht anders. Das können andere Hersteller deutlich besser.
