- Mercedes
- ML, GLE & GL
- GLC
- Mercedes GLC (C253, X253)
- Mercedes me: Adresse an Fahrzeug senden
seit Dezember fahre ich den GLC und nutze recht intensiv die Mercedes-me App (IOS). Wenn ich in der App auf meinem iPhone ein Ziel eingebe und "Adresse an Fahrzeug senden" klicke tut die App so, als wäre alles ok.
Im Auto finde ich das gesendete Ziel aber nirgends.
Kennt jemand das Verhalten oder weiß wo man die Strecke im Navi (Command online) findet?
Ein Arbeitskollege fährt einen BMW und da wird das Fahrtziel quasi als SMS geschickt und man kann es dann hierüber aktivieren.
Excuse me for my English writing, my German writing skills are not so good, and I'm afraid you will even understand less of it :-)
I also had the problem when sending an address to my vehicle, I did not get a navigation pop-up when entering the car. I did have the BT (Bluetooth) option enabled, but with no effect. My dealer also did not understand, and showed me a counter example with their own phone and a GLC, where it worked flawlessly (send address to car, put it on, and immediately after the connection with the phone the navigation address popped up on the screen).
After experimenting (had to send some screen dumps to the Mercedes Me help portal; they are very friendly and helpful), I did manage to get a pop up on the COMAND with the question whether I want to connect to Mercedes Me. I can remember this pop up before, as I was wondering why the COMAND was asking me for setting up a link, whereas I could already see all car info in the app. So I pressed "No" at that time, and that it probably the error being made in setting up the system correctly. This setting can not be found anywhere in the system settings.
During experimenting, I managed to get that same dialog box on my COMAND asking me whether I want to connect to Mercedes Me. This time I pressed "Yes", and now when I send addresses, it pops up immediately at my COMAND system.
The way I managed to get that dialog box was:
- Send an address inside the vehicle with BT enabled. The iPhone says the address is sent successfully, but no pop-up, and the address is not appearing anywhere.
- Send the address inside the vehicle with the BT option in the app disabled. The iPhone says the address is sent successfully, there is no pop-up, and the address appears in the POI app (which is an unhandy way of dealing with it)
- After this, I enabled the BT option in the Mercedes Me app again, and did send an address again. The car now put the dialog box with the question whether I wanted to connect to Mercedes Me, I answered Yes, and immediately after that the address appeared as a pop-up
Maybe this also works for other people with the same issue, in my search I saw there were many people at random that seem to have this issue.
What I realised as a side effect, is that only addresses sent via BT are entitled to pop up on the COMAND immediately. If you have no connection to the car, and connect the phone later, it seems to cache the BT request, and you get a pop up anyway.
Take care,
Marc
135 Antworten
Das kann ich dir nicht sagen, ich habe mercedesMe nicht weiter verfolgt, da mir der Jahresbeitrag für diese SpielKramApp unangemessen hoch ist.
Jedenfalls klappt es mit Here wego von der Couch aus prima. Einfach unter POI im Navi dann auswählen und übernehmen.
@Bitmac schrieb am 29. Mai 2020 um 11:00:16 Uhr:
@eva-roxi schrieb am 29. Mai 2020 um 07:50:06 Uhr:
Doch das geht. Mit https://wego.here.com wie man im Bild sehen kann.
Ich hab gedacht direkt aus der me App heraus.
MercedeMe App geht auch. Man kann in der App wählen ob über BT direkt oder über den Server gesendet werden soll.
Oder mit Apple hiermit
@alingn
Ich habe auch Probleme beim Senden der Navi-Daten. Die alte Mercedes Me App am iPhone funktionierte wunderbar. Da habe ich die Adresse auf der Couch eingegeben und nächsten Tag kam eine Push Nachricht im Auto und ich konnte die Navigation starten.
Mit der neuen Mercedes Me App "muss" das Handy per CarPlay oder Bluetooth mit dem Auto verbunden sein, bevor ich auf den Button "an das Fahrzeug senden" betätige. Vorher interessiert ihn der Knopf in der App nicht.
Ich habe die ganze App rauf und runter am iPhone durchsucht, wo steht bei dir in der App "über den Server senden". Am iPhone habe ich keinen solchen Knopf. Auch nicht unter irgendwelchen Zahnrädern. :(
Ich fahre einen W177, BJ 10/2018.
edit: Danke im Voraus
So sollte es auch gehen:
Ziel eingeben und wie auf dem Bild aufgezeigt die nächsten 3 Schritte weiter gehen.
VIN eingeben und ans Fahrzeug senden.
Hoffe das funktioniert noch.
@0815Use.r schrieb am 26. Mai 2021 um 09:31:22 Uhr:
@alingn
Am IPhone kann ich keine vin eingeben. Per app lässt es sich nur an an die Mercedes app teilen, was aber nichts bewirkt ohne Bluetooth
Die Eingabe geschieht doch unabhängig vom Telefon sonder wird im Browser durchgeführt.
Ich mache das vorzugsweise immer am PC.
Im Auto Navi erscheint dann unter Favoriten die gewünschte Routenauswahl.
@0815Use.r schrieb am 26. Mai 2021 um 10:23:09 Uhr:
Ich habe keinen PC. Und dein Screenshot geht am iPhone leider nicht. Zumindest konnte ich die Eingabe Vin nicht finden.
Danke dir trotzdem für deine Bemühungen.
Mein Beitrag ist fast ein Jahr alt. Damals konnte man in der App auswählen ob man über BT (geht dann nur im Auto) oder über den Server senden möchte. In der aktuellen Me App geht es immer über den Server. Allerdings habe ich jetzt ein Fzg mit MBUX.
Es geht auch über die Me App selbst. Einfach unten rechts auf den kleinen Pfeil zur Ortung des GLCs tippen, in der Suchmaske die Adresse eintippen und dann auf den Export-Pfeil klicken.
Klappt wunderbar. Ziel suchen an die me-App senden und im Fahrzeug unter Navigation
>Wohin?>Empfangene Ziele> (rechts oben) und auswählen.
Kommt die Meldung beim MBUX nicht mehr automatisch?
Beim Comand kommt die Meldung automatisch nach dem Start, ob die Navigation zu dem empfangenen Ziel gestartet werden soll.
Ich habe ja auch MBUX. Aber es kommt keine push Nachricht mehr. Mit der alten mercedes Me app ging das wunderbar. Bei meiner V Klasse mit mbux funktioniert es auch nicht (mehr).
Im MBUX kommt auch eine Einblendung, die verschwindet aber nach ein paar Sekunden wieder wenn man die Meldung nicht antippt und die Zielführung startet. Danach findet man die Meldung wie im Vorpost beschrieben oder im Nachrichtendienst.
Ja, so war es mal bei mir bei der alten App. Seit der neuen app funktioniert es bei mir nur noch wenn das iphone per Bluetooth oder per kabel per CarPlay verbunden ist. Ich habe da jetzt mal den Support kontaktiert.
