Lambdasonde, LMM, Temperaturanzeige??? Bin ratlos :-(
Skoda
Hallo Leute, ich hoffe dass ihr helfen könnt. Fahre einen Fabia MPI 1,4L Bj2001.
Seid kurzem stottert der Motor ganz leicht. Habe eine Daten sammeln können...
und die Temp. Anzeige unter VAG zeigt über 400° an ??!!
Vielen Dank im voraus!!!!
__________________________________________________________________
Sunday,28,August,2011,11:22:26
047 906 033 E ,,1.4l SIMOS3PA 00HSSJ32,
,Group A:,'033,,,,Group B:,'032,,,,Group C:,'034
,,Lambda, , , ,,Lambda,Lambda, , ,,UPM,Temperatur,Differenz,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP,%,,,,STAMP,%,%,,,STAMP, /min,°C,,
,0.00,2.0, , , ,0.43,-2.3,0.0, , ,0.83,832,344.0,0.000,Test AUS
,1.28,2.0, , , ,1.71,-2.3,0.0, , ,2.09,800,344.0,0.000,Test AUS
,2.51,2.0, , , ,2.94,-2.3,0.0, , ,3.37,800,344.0,0.000,Test AUS
,3.79,1.6, , , ,4.22,-2.3,0.0, , ,4.64,832,344.0,0.000,Test AUS
,5.07,2.0, , , ,5.52,-2.3,0.0, , ,5.95,832,344.0,0.000,Test AUS
,6.35,2.0, , , ,6.78,-2.3,0.0, , ,7.18,832,344.0,0.000,Test AUS
,7.61,1.6, , , ,8.01,-2.3,0.0, , ,8.43,832,344.0,0.000,Test AUS
,8.86,2.0, , , ,9.31,-2.3,0.0, , ,9.74,800,344.0,0.000,Test AUS
,10.16,2.0, , , ,10.59,-2.3,0.0, , ,10.99,800,344.0,0.000,Test AUS
,11.41,2.0, , , ,11.82,-2.3,0.0, , ,12.27,832,344.0,0.000,Test AUS
,12.78,1.6, , , ,13.18,-2.3,0.0, , ,13.60,832,344.0,0.000,Test AUS
,14.05,1.6, , , ,14.44,-2.3,0.0, , ,14.86,800,344.0,0.000,Test AUS
,15.26,2.0, , , ,15.68,-2.3,0.0, , ,16.11,832,344.0,0.000,Test AUS
,16.48,0.0, , , ,16.94,-1.6,0.0, , ,17.36,1440,344.0,0.000,Test AUS
,17.82,2.3, , , ,18.27,-1.6,0.0, , ,18.72,1536,344.0,0.000,Test AUS
,19.13,3.5, , , ,19.55,0.0,-2.0, , ,19.98,1856,344.0,0.000,Test AUS
,20.38,4.3, , , ,20.83,0.0,-2.0, , ,21.26,1856,344.0,0.000,Test AUS
,21.74,3.5, , , ,22.25,0.0,-2.0, , ,22.81,1952,344.0,0.000,Test AUS
,23.31,2.3, , , ,23.84,0.0,-2.0, , ,24.35,1952,344.0,0.000,Test AUS
,24.89,2.7, , , ,25.39,0.0,-2.0, , ,25.85,1984,352.0,0.000,Test AUS
,26.35,2.7, , , ,26.83,0.0,-2.0, , ,27.34,1952,352.0,0.000,Test AUS
,27.82,3.1, , , ,28.30,0.0,-2.0, , ,28.78,1984,352.0,0.000,Test AUS
,29.29,2.3, , , ,29.75,0.0,-2.0, , ,30.22,1952,352.0,0.000,Test AUS
,30.70,2.7, , , ,31.18,0.0,-2.0, , ,31.63,1984,352.0,0.000,Test AUS
,32.14,2.3, , , ,32.62,0.0,-2.0, , ,33.08,1952,352.0,0.000,Test AUS
,33.56,2.7, , , ,34.09,0.0,-2.0, , ,34.59,1952,352.0,0.000,Test AUS
,35.10,2.3, , , ,35.59,0.0,-2.0, , ,36.14,1952,352.0,0.000,Test AUS
,36.65,2.7, , , ,37.13,0.0,-2.0, , ,37.62,1952,360.0,0.000,Test AUS
,38.14,2.0, , , ,38.62,0.0,-2.0, , ,39.08,1952,360.0,0.000,Test AUS
,39.58,2.3, , , ,40.07,0.0,-2.0, , ,40.60,1984,360.0,0.000,Test AUS
,41.06,2.3, , , ,41.53,0.0,-2.0, , ,41.96,1600,360.0,0.000,Test AUS
,42.49,0.0, , , ,42.86,-2.3,0.0, , ,43.30,928,360.0,0.000,Test AUS
,43.72,0.0, , , ,44.14,-3.1,0.0, , ,44.55,800,360.0,0.000,Test AUS
,44.95,0.0, , , ,45.35,-2.3,0.0, , ,45.77,800,360.0,0.000,Test AUS
,46.20,0.0, , , ,46.62,-2.3,0.0, , ,47.03,832,360.0,0.000,Test AUS
,47.48,0.4, , , ,47.91,-2.3,0.0, , ,48.38,800,360.0,0.000,Test AUS
,48.81,0.4, , , ,49.24,-2.3,0.0, , ,49.67,832,360.0,0.000,Test AUS
,50.09,0.4, , , ,50.52,-2.3,0.0, , ,50.94,800,360.0,0.000,Test AUS
,51.40,1.2, , , ,51.85,-2.3,0.0, , ,52.23,800,360.0,0.000,Test AUS
,52.65,1.6, , , ,53.08,-2.3,0.0, , ,53.48,800,360.0,0.000,Test AUS
,53.90,1.2, , , ,54.34,-2.3,0.0, , ,54.79,800,360.0,0.000,Test AUS
,96.95,0.8, , , ,97.39,-3.1,0.0, , ,97.81,800,352.0,0.000,Test AUS
,98.24,0.8, , , ,98.67,-3.1,0.0, , ,99.09,832,352.0,0.000,Test AUS
,99.52,1.2, , , ,99.94,-3.1,0.0, , ,100.34,832,352.0,0.000,Test AUS
,100.77,0.8, , , ,101.20,-3.1,0.0, , ,101.63,800,352.0,0.000,Test AUS
2,102.05,0.8, , , ,102.48,-3.1,0.0, , ,102.90,800,352.0,0.000,Test AUS
,103.28,0.4, , , ,103.71,-3.1,0.0, , ,104.14,800,352.0,0.000,Test AUS
,104.54,0.8, , , ,104.98,-3.1,0.0, , ,105.39,800,352.0,0.000,Test AUS
,105.79,0.8, , , ,106.26,-3.1,0.0, , ,106.66,800,352.0,0.000,Test AUS
,107.09,0.8, , , ,107.49,-3.1,0.0, , ,107.90,800,352.0,0.000,Test AUS
,108.32,0.4, , , ,108.75,-3.1,0.0, , ,109.17,800,352.0,0.000,Test AUS
,109.60,0.4, , , ,110.02,-3.1,0.0, , ,110.43,800,352.0,0.000,Test AUS
,110.88,0.4, , , ,111.31,-3.1,0.0, , ,111.73,832,352.0,0.000,Test AUS
,112.18,0.0, , , ,112.69,0.0,-2.0, , ,113.18,2176,368.0,0.000,Test AUS
,113.58,0.0, , , ,114.01,-2.3,0.0, , ,114.43,960,368.0,0.000,Test AUS
,114.83,0.0, , , ,115.29,-3.1,0.0, , ,115.73,896,368.0,0.000,Test AUS
,116.16,-0.8, , , ,116.57,-3.1,0.0, , ,117.02,800,368.0,0.000,Test AUS
,117.49,0.0, , , ,117.90,-1.6,0.0, , ,118.38,2016,368.0,0.000,Test AUS
,118.89,0.0, , , ,119.34,-2.3,-2.0, , ,119.73,928,384.0,0.000,Test AUS
,120.17,0.0, , , ,120.61,-3.1,0.0, , ,121.12,1280,384.0,0.000,Test AUS
,121.57,0.0, , , ,122.03,0.0,-2.0, , ,122.46,2016,416.0,0.000,Test AUS
,122.88,0.0, , , ,123.34,-2.3,0.0, , ,123.76,1152,416.0,0.000,Test AUS
,124.16,5.1, , , ,124.57,-1.6,0.0, , ,125.00,896,416.0,0.000,Test AUS
,125.39,-0.8, , , ,125.82,-1.6,0.0, , ,126.25,1088,416.0,0.000,Test AUS
,126.67,-0.8, , , ,127.08,-1.6,0.0, , ,127.55,1344,416.0,0.000,Test AUS
,127.98,-0.8, , , ,128.40,-1.6,0.0, , ,128.80,1504,416.0,0.000,Test AUS
,129.16,1.6, , , ,129.63,-1.6,0.0, , ,130.08,1472,416.0,0.000,Test AUS
,130.54,4.7, , , ,131.02,-2.3,0.0, , ,131.44,1472,416.0,0.000,Test AUS
,131.87,3.1, , , ,132.32,-2.3,0.0, , ,132.75,1376,416.0,0.000,Test AUS
,133.20,0.8, , , ,133.58,-3.1,0.0, , ,134.03,1024,416.0,0.000,Test AUS
,134.44,1.2, , , ,134.86,-3.1,0.0, , ,135.29,864,416.0,0.000,Test AUS
,135.72,0.0, , , ,136.19,-1.6,0.0, , ,136.64,1152,416.0,0.000,Test AUS
,137.07,-0.4, , , ,137.51,-0.8,0.0, , ,137.93,1536,424.0,0.000,Test AUS
,138.41,0.8, , , ,138.92,0.0,-2.0, , ,139.44,2112,432.0,0.000,Test AUS
,139.95,-1.2, , , ,140.46,0.0,-2.0, , ,140.95,2880,488.0,0.000,Test AUS
,141.47,0.0, , , ,141.92,-3.1,0.0, , ,142.32,992,488.0,0.000,Test AUS
,142.71,0.0, , , ,143.15,-3.1,0.0, , ,143.58,864,480.0,0.000,Test AUS
,144.01,0.0, , , ,144.43,-3.1,0.0, , ,144.83,736,480.0,0.000,Test AUS
,145.26,-2.7, , , ,145.69,-3.1,0.0, , ,146.09,768,480.0,0.000,Test AUS
,146.51,-2.0, , , ,146.93,-3.1,0.0, , ,147.32,800,480.0,0.000,Test AUS
,147.75,-0.4, , , ,148.20,-3.1,0.0, , ,148.60,928,480.0,0.000,Test AUS
,149.02,-6.3, , , ,149.47,-2.3,0.0, , ,149.87,1152,480.0,0.000,Test AUS
,150.30,3.5, , , ,150.75,-2.3,0.0, , ,151.13,736,480.0,0.000,Test AUS
,151.58,0.0, , , ,152.14,0.0,-2.0, , ,152.57,1984,480.0,0.000,Test AUS
,153.08,1.2, , , ,153.55,-1.6,0.0, , ,153.95,1024,480.0,0.000,Test AUS
,154.35,-5.5, , , ,154.81,-2.3,0.0, , ,155.22,928,480.0,0.000,Test AUS
,155.67,0.4, , , ,156.10,-1.6,0.0, , ,156.54,1088,480.0,0.000,Test AUS
,157.00,0.8, , , ,157.43,-1.6,0.0, , ,157.86,1376,480.0,0.000,Test AUS
,158.31,0.8, , , ,158.71,-1.6,0.0, , ,159.10,1472,480.0,0.000,Test AUS
,159.53,2.3, , , ,159.93,-1.6,-2.0, , ,160.38,1568,480.0,0.000,Test AUS
,160.84,-0.4, , , ,161.35,0.0,-2.0, , ,161.88,1984,488.0,0.000,Test AUS
,162.34,0.8, , , ,162.90,0.0,-2.0, , ,163.42,2368,496.0,0.000,Test AUS
,163.94,1.2, , , ,164.38,0.0,-2.0, , ,164.78,1888,504.0,0.000,Test AUS
,165.18,0.0, , , ,165.59,-3.1,0.0, , ,166.01,896,504.0,0.000,Test AUS
,166.42,0.0, , , ,166.82,-3.1,0.0, , ,167.21,800,496.0,0.000,Test AUS
,167.64,0.0, , , ,168.02,-3.1,0.0, , ,168.44,768,496.0,0.000,Test AUS
,168.85,-2.3, , , ,169.27,-3.1,0.0, , ,169.70,800,496.0,0.000,Test AUS
,170.10,-1.6, , , ,170.52,-3.1,0.0, , ,170.97,800,496.0,0.000,Test AUS
,171.38,-0.4, , , ,171.78,-3.1,0.0, , ,172.21,800,496.0,0.000,Test AUS
,172.65,-0.4, , , ,173.06,-3.1,0.0, , ,173.46,768,488.0,0.000,Test AUS
,173.88,-0.4, , , ,174.28,-3.1,0.0, , ,174.69,800,488.0,0.000,Test AUS
,175.13,0.4, , , ,175.56,-3.1,0.0, , ,175.97,768,488.0,0.000,Test AUS
,176.41,1.6, , , ,176.84,-3.1,0.0, , ,177.25,768,488.0,0.000,Test AUS
,177.70,1.2, , , ,178.13,-3.1,0.0, , ,178.52,768,488.0,0.000,Test AUS
,178.92,0.8, , , ,179.33,-3.1,0.0, , ,179.75,768,480.0,0.000,Test AUS
,180.18,1.6, , , ,180.60,-2.3,0.0, , ,181.01,800,480.0,0.000,Test AUS
,181.48,0.4, , , ,181.86,-1.6,0.0, , ,182.28,1664,480.0,0.000,Test AUS
,182.77,-0.8, , , ,183.30,0.0,-2.0, , ,183.73,2304,496.0,0.000,Test AUS
,184.15,0.0, , , ,184.55,-3.1,0.0, , ,185.00,896,496.0,0.000,Test AUS
,185.43,0.0, , , ,185.83,-3.1,0.0, , ,186.21,800,496.0,0.000,Test AUS
,186.63,0.0, , , ,187.04,-1.6,0.0, , ,187.51,2048,496.0,0.000,Test AUS
,188.04,0.0, , , ,188.52,0.0,-2.0, , ,188.96,1760,520.0,0.000,Test AUS
,189.38,0.0, , , ,189.86,-3.1,0.0, , ,190.24,768,520.0,0.000,Test AUS
,190.64,0.0, , , ,191.04,-3.1,0.0, , ,191.46,768,520.0,0.000,Test AUS
,191.89,0.0, , , ,192.29,-3.1,0.0, , ,192.71,768,512.0,0.000,Test AUS
,193.14,0.0, , , ,193.64,0.0,-2.0, , ,194.07,1952,520.0,0.000,Test AUS
,194.50,-1.2, , , ,194.93,-0.8,-2.0, , ,195.40,1152,528.0,0.000,Test AUS
,195.83,0.0, , , ,196.23,-3.1,0.0, , ,196.67,896,520.0,0.000,Test AUS
,197.09,0.0, , , ,197.52,-3.1,0.0, , ,197.92,864,520.0,0.000,Test AUS
,198.35,-2.7, , , ,198.75,-3.1,0.0, , ,199.19,768,520.0,0.000,Test AUS
,199.59,-1.6, , , ,199.99,-2.3,0.0, , ,200.42,1472,520.0,0.000,Test AUS
,200.90,0.4, , , ,201.38,0.0,-2.0, , ,201.79,1280,520.0,0.000,Test AUS
,202.26,0.0, , , ,202.67,-3.1,0.0, , ,203.06,864,520.0,0.000,Test AUS
,203.46,0.0, , , ,203.87,-3.1,0.0, , ,204.31,864,520.0,0.000,Test AUS
,204.74,-3.9, , , ,205.20,-3.9,0.0, , ,205.65,736,512.0,0.000,Test AUS
,206.08,-2.7, , , ,206.51,-3.1,0.0, , ,206.93,768,512.0,0.000,Test AUS
,207.35,-1.2, , , ,207.78,-3.1,0.0, , ,208.16,768,512.0,0.000,Test AUS
,208.58,0.0, , , ,208.99,-3.1,0.0, , ,209.41,800,512.0,0.000,Test AUS
,209.84,0.0, , , ,210.27,-3.1,0.0, , ,210.67,800,504.0,0.000,Test AUS
,211.11,-0.4, , , ,211.54,-3.1,0.0, , ,211.95,800,504.0,0.000,Test AUS
,212.35,-0.4, , , ,212.80,-3.1,0.0, , ,213.22,800,504.0,0.000,Test AUS
,213.65,-0.4, , , ,214.08,-3.1,0.0, , ,214.46,768,504.0,0.000,Test AUS
,214.90,-0.4, , , ,215.31,-3.1,0.0, , ,215.70,800,504.0,0.000,Test AUS
,216.10,-0.4, , , ,216.53,-3.1,0.0, , ,216.96,768,496.0,0.000,Test AUS
,217.41,0.0, , , ,217.84,-3.1,0.0, , ,218.27,768,496.0,0.000,Test AUS
,218.66,-0.4, , , ,219.09,-3.1,0.0, , ,219.52,768,496.0,0.000,Test AUS
,219.95,-0.8, , , ,220.38,-3.1,0.0, , ,220.78,800,496.0,0.000,Test AUS
,221.20,-0.4, , , ,221.60,-3.1,0.0, , ,222.03,768,496.0,0.000,Test AUS
,222.46,-0.4, , , ,222.90,-3.1,0.0, , ,223.30,768,496.0,0.000,Test AUS
,223.71,-0.4, , , ,224.14,-3.1,0.0, , ,224.58,800,488.0,0.000,Test AUS
,224.98,-0.4, , , ,225.41,-3.1,0.0, , ,225.84,800,488.0,0.000,Test AUS
,226.27,-0.4, , , ,226.70,-3.1,0.0, , ,227.10,768,488.0,0.000,Test AUS
,227.54,0.0, , , ,227.97,-3.1,0.0, , ,228.38,800,488.0,0.000,Test AUS
,228.78,-0.8, , , ,229.20,-3.1,0.0, , ,229.65,768,480.0,0.000,Test AUS
,230.08,-0.4, , , ,230.51,-3.1,0.0, , ,230.93,768,480.0,0.000,Test AUS
,231.36,-0.4, , , ,231.79,-3.1,0.0, , ,232.21,800,480.0,0.000,Test AUS
,232.62,-0.4, , , ,233.04,-3.1,0.0, , ,233.45,800,480.0,0.000,Test AUS
,233.85,-0.4, , , ,234.30,-3.1,0.0, , ,234.75,800,480.0,0.000,Test AUS
,235.20,-0.4, , , ,235.65,-3.1,0.0, , ,236.08,800,480.0,0.000,Test AUS
,236.49,-0.4, , , ,236.91,-3.1,0.0, , ,237.34,800,472.0,0.000,Test AUS
,237.74,-0.8, , , ,238.16,-3.1,0.0, , ,238.57,768,472.0,0.000,Test AUS
,238.99,-0.4, , , ,239.41,-3.1,0.0, , ,239.84,800,472.0,0.000,Test AUS
,240.25,-0.4, , , ,240.65,-3.1,0.0, , ,241.07,800,472.0,0.000,Test AUS
,241.49,-0.4, , , ,241.89,-3.1,0.0, , ,242.32,768,472.0,0.000,Test AUS
,242.73,-0.8, , , ,243.12,-3.1,0.0, , ,243.56,768,472.0,0.000,Test AUS
,243.98,-0.8, , , ,244.38,-3.1,0.0, , ,244.81,800,464.0,0.000,Test AUS
,245.23,-0.8, , , ,245.64,-3.1,0.0, , ,246.06,800,464.0,0.000,Test AUS
,246.48,-0.8, , , ,246.92,-3.1,0.0, , ,247.36,768,464.0,0.000,Test AUS
,247.76,-0.8, , , ,248.19,-3.1,0.0, , ,248.64,768,464.0,0.000,Test AUS
,249.04,-0.4, , , ,249.47,-3.1,0.0, , ,249.88,800,464.0,0.000,Test AUS
,250.27,-0.8, , , ,250.70,-3.1,0.0, , ,251.10,768,464.0,0.000,Test AUS
,251.50,-0.8, , , ,251.93,-3.1,0.0, , ,252.36,768,464.0,0.000,Test AUS
,252.76,-0.8, , , ,253.16,-3.1,0.0, , ,253.58,800,456.0,0.000,Test AUS
,254.03,-0.8, , , ,254.44,-3.1,0.0, , ,254.88,800,456.0,0.000,Test AUS
,255.27,-0.8, , , ,255.69,-3.1,0.0, , ,256.09,800,456.0,0.000,Test AUS
,256.54,-0.8, , , ,256.94,-3.1,0.0, , ,257.35,800,456.0,0.000,Test AUS
,257.77,-0.8, , , ,258.17,-3.1,0.0, , ,258.59,800,456.0,0.000,Test AUS
,259.00,-1.2, , , ,259.43,-3.1,0.0, , ,259.87,800,456.0,0.000,Test AUS
,260.27,-1.2, , , ,260.71,-3.1,0.0, , ,261.11,800,448.0,0.000,Test AUS
,261.50,-0.8, , , ,261.93,-3.1,0.0, , ,262.33,768,448.0,0.000,Test AUS
,262.75,-0.4, , , ,263.16,-3.1,0.0, , ,263.72,768,448.0,0.000,Test AUS
,264.09,-0.4, , , ,264.51,-3.1,0.0, , ,264.92,768,448.0,0.000,Test AUS
,265.34,-0.8, , , ,265.77,-3.1,0.0, , ,266.19,800,448.0,0.000,Test AUS
,266.62,-0.4, , , ,267.05,-3.1,0.0, , ,267.47,800,448.0,0.000,Test AUS
,267.88,-0.8, , , ,268.30,-3.1,0.0, , ,268.73,800,448.0,0.000,Test AUS
,269.13,-0.8, , , ,269.56,-3.1,0.0, , ,269.95,768,448.0,0.000,Test AUS
,270.35,-0.8, , , ,270.78,-3.1,0.0, , ,271.23,800,440.0,0.000,Test AUS
,271.64,-0.8, , , ,272.06,-3.1,0.0, , ,272.52,800,440.0,0.000,Test AUS
,272.94,-0.8, , , ,273.40,-3.1,0.0, , ,273.85,800,440.0,0.000,Test AUS
,274.30,-0.8, , , ,274.74,-3.1,0.0, , ,275.19,768,440.0,0.000,Test AUS
,275.64,-0.8, , , ,276.07,-3.1,0.0, , ,276.50,768,440.0,0.000,Test AUS
,276.94,-0.8, , , ,277.38,-3.1,0.0, , ,277.82,768,440.0,0.000,Test AUS
,278.25,-0.8, , , ,278.65,-3.1,0.0, , ,279.08,768,440.0,0.000,Test AUS
,279.50,-0.8, , , ,279.91,-3.1,0.0, , ,280.33,800,440.0,0.000,Test AUS
,280.74,-0.8, , , ,281.14,-3.1,0.0, , ,281.58,800,432.0,0.000,Test AUS
,282.01,-0.8, , , ,282.39,-3.1,0.0, , ,282.83,768,432.0,0.000,Test AUS
,283.24,-0.8, , , ,283.66,-3.1,0.0, , ,284.09,800,432.0,0.000,Test AUS
,284.54,-0.8, , , ,284.94,-3.1,0.0, , ,285.35,768,432.0,0.000,Test AUS
,285.75,-1.2, , , ,286.17,-3.1,0.0, , ,286.58,768,432.0,0.000,Test AUS
,287.03,-0.8, , , ,287.45,-3.1,0.0, , ,287.85,800,432.0,0.000,Test AUS
,288.26,-0.8, , , ,288.66,-3.1,0.0, , ,289.09,800,432.0,0.000,Test AUS
,289.51,-1.2, , , ,289.93,-3.1,0.0, , ,290.36,768,432.0,0.000,Test AUS
,290.76,-1.2, , , ,291.14,-3.1,0.0, , ,291.56,800,424.0,0.000,Test AUS
,291.97,-1.2, , , ,292.36,-3.1,0.0, , ,292.79,768,424.0,0.000,Test AUS
,293.21,-1.2, , , ,293.59,-3.1,0.0, , ,294.04,800,424.0,0.000,Test AUS
,294.47,-1.2, , , ,294.90,-3.1,0.0, , ,295.30,768,424.0,0.000,Test AUS
,295.75,-1.2, , , ,296.17,-3.1,0.0, , ,296.58,800,424.0,0.000,Test AUS
,297.01,-1.6, , , ,297.41,-3.1,0.0, , ,297.83,800,424.0,0.000,Test AUS
,298.25,-1.6, , , ,298.66,-3.1,0.0, , ,299.08,768,424.0,0.000,Test AUS
,299.49,-1.6, , , ,299.89,-3.1,0.0, , ,300.34,768,424.0,0.000,Test AUS
3 Antworten
hm was sollen mir diese Daten jetzt sagen - wenn es wirklich ein 1,4 L MPI ist dann ersetze die 4 fach Zündspule vorne am Zylinderkopf und gut ist.
Habe auch Bilder eingestellt...Mir sagen diese Daten ja auch nichts, habe aber auf einen Expertentipp gehofft :-) Aber wie kommst du jetzt auf die Zündspule??!!
Also ich persönlich tendiere eher zum temperaturfühler ......... ;-)
Usta
Programi nerden bulabilirim? Bende Program ariyorum
