- Mercedes
- S-Klasse & CL
- S-Klasse
- Klima von jetzt auf gleich ausgefallen
habe heute nen W220 320er Benziner gekauft....
Erst lief die Klimaanlange normal, dann habe ich geparkt und bin später wieder gefahren und sie ging nicht mehr ;-( einfach so...
weiß jemand rat und hat ne idee was das sein kann ?
bitte nichts teures :-//
lieben gruß
Auf die schnelle......
0 AAC in-car temperature sensor (operating module)
1 Overhead control panel for in-car temperature sensor
2 Outside temperature sensor
3 Left heater-exchanger in car temperature sensor
4 Right heater-exchanger in-car temperature sensor
5 Evaporator core sensor
6 Engine temperature
7 Refrigerant pressure
8 R134A refrigerant in-car temperature sensor
10 Blower control voltage
15 Average insolation value between 0 and 125%
16 Carbon monoxide value between 0 and 1023
17 Nitrogen oxide value between 0 and 1023
18 Dew point temperature
20 Fan output value between 0 and 100%
21 Engine speed
22 Ground speed
24 Battery voltage
27 Left hand potentiometer engine speed value between 0 and 100%
28 Centre potentiometer engine speed value between 0 and 100%
29 Right hand potentiometer engine speed value between 0 and 100%
30 Temp of blow air in left rear passenger-compartment
31 Temp of blow air in left rear passenger-compartment
32 Temp of evaporator core in rear passenger compartment
33 Blower voltage in rear passenger-compartment
34 Specified temperature in left rear passenger-compartment
35 Specified temperature in right rear passenger-compartment
40 Left hand defroster door value (open/closed plain text at limit stop)
41 Right hand defroster door value (open/closed plain text at limit stop)
42 Left hand footwell flap value between 0 and 100%
43 Right hand footwell flap value between 0 and 100%
44 Left hand blend flap value between 0 and 100%
45 Right hand blend flap value between 0 and 100%
46 Left hand diverter flap 0 and 100%
47 Right hand diverter flap value 0 and 100%
48 Recirculation door 0 and 100%
49 AKF bypass flap 0 and 100%
50 AAC Software
51 AAC Hardware
52 Software for rear passenger compartment air conditioning
53 Hardware for rear passenger compartment air conditioning
54 Software for stepper motor unit
55. Hardware for stepper motor unit
56 Software for centre nozzle
57 Hardware for center nozzle
58 Software for multifunction sensor
59 Hardware for multifunction sensor
60 Sofware for day-brightness sensor
61 Hardware for day-brightness sensor
36 Antworten
Hallo ich hab ein Problem mein s55 w220 geht auf einmal nicht mehr die Klima ?
Dann wirst du um einen Werkstatt Besuch nicht rumkommen aus mehreren Gründen. Die hier die Vorredner schon erwähnt haben..
Und selber an seiner Klimaanlage schrauben ohne die Möglichkeit das Kühlmittel Umwelt gerecht zu handhaben.
Sehe ich sehr kritisch.
Da 1g Kühlmittel um ein sehr viel faches Umwelt schädlicher ist als 1g CO2
?? 10 000 oder waren es 100 000 Fach je nach Kühlmittel. ??
Nachtrag es sind ca. 1430 mal bei R134a
Zunächst einmal müsstest du den Fehlerspeicher auslesen, um zu wissen welcher Fehler vorliegt.
Unter Umständen ist es nur ein Sensor der falsche Werte liefert und deswegen die Klimaanlage auf Störung geht.
Oke mit was soll ich denn Fehlerspeicher auslesen mit denn obd2 ??
Mit deiner Bedieneinheit der Klimaanlage.
Einfach mal für ein paar Sekunden die Filter-Taste und die Rest-Taste gleichzeitig drücken.
Die Anzeige springt dann auf Fehlersuche um.
Wird ein Fehler gefunden, erscheint der entsprechende Fehlercode in der Anzeige.
Löschen kann man den Fehler mit der linken Auto-Taste.
Den Fehlermodus verlässt man wieder mit der Rest-Taste.
Eine Liste der Fehlercode ist im FAQ hinterlegt, glaube ich.
