Dual-zone digital air conditioning faults
Mercedes CLK 208 Cabrio
Hello everyone, my 2001 A208 EVO has a dual-zone digital climate control system that has the following malfunctions:
At the 3rd/4th speed, it adjusts the airflow intensity by one notch at will, and as it does so, the dashboard lights dim and brighten at the same rate.
If I set it to minimum or maximum, the speed remains constant.
For some time now, when I turn off the car, the cabin fan won't turn off, and I have to try different adjustment combinations, reinserting the key and turning it until it starts again and then turning the engine off. I set it to OFF, for example, and try many other random combinations, and finally it turns off.
Does anyone have any idea what happened?
Thanks
2 Antworten
"Does anyone have any idea what happened" ?
At first watch this:
https://www.youtube.com/watch?v=anNnhZnBuHg
https://www.youtube.com/watch?v=Yts_rOYuR4Y
01 Innentemp-Sensor
02 Aussentemperatur-Sensor
03 Temperatur des linken Wärmeaustauscher-Sensors
04 Temp. des rechten Wärmeaustauscher-Sensor
05 Verdampfer-Sensor
06 Kühlwassertemperatur
07 Kühlungsdruck in bar
08 Kühltemp.sensor (23*9 = 23.9deg C)
09
10 Gebläsesteuerspannung !!!
11 Emission-Sensor (B31) z.B. 3.1 = 31.v
12 Sonnestandssensor 4.2 = 4.2v
20 Zusatzkühlventilatorsteuerung 6.1 = 6.1A (max 10A)
21 Motordrehzahl 1/min*1000
22 Fzg-Geschwindigkeit km/h
23 Stromkreis 58d z.B. 99 = 99% von Batteriespannung,
24 BATTERIE-SPANNUNG z.B. 12.5 = 12.5v
40 Steuermodul-Version Software-Version
41 Steuermodul-Version Menü-Hardware-Version
42 Steuermodul VarantenCode 1. Zahl
43 Steuermodul VarantenCode 2. Zahl
English:
01 Indoor temperature sensor
02 Outdoor temperature sensor
03 Left heat exchanger sensor temperature
04 Right heat exchanger sensor temperature
05 Evaporator sensor
06 Cooling water temperature
07 Cooling pressure in bar
08 Cooling temperature sensor (23*9 = 23.9°C)
09
10 Fan control voltage !!!
11 Emissions sensor (B31) e.g., 3.1 = 31.v
12 Sun position sensor 4.2 = 4.2v
20 Auxiliary cooling fan control 6.1 = 6.1A (max. 10A)
21 Engine speed 1/min*1000
22 Vehicle speed km/h
23 Circuit 58d e.g., 99 = 99% of battery voltage,
24 BATTERY VOLTAGE e.g., 12.5 = 12.5v
40 Control module version: Software version
41 Control module version: Menu hardware version
42 Control module variant code, 1st number
43 Control module variant code, 2nd number
It is also recommended to read out
the fault memory with Stardiagnosis and report it here...
best of luck, mike.
Where is the relay that cuts off the power to the cabin fan?
Thanks
