- Opel
- Astra, Cascada & Kadett
- Astra J & Cascada
- Von Navi 600 Navi 900 machen kostenlos
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 Antworten
@Flensburger33
Kannst du vor dem Einbau noch ein Foto vom Label des Steuergerätes einstellen - als Anhaltspunkt :confused: ?
Das sollte doch ein SD-Karten-Navi sein, oder?
Es hat alles geklappt und das Radio funktioniert wieder :D
Da ich beim Einbau nicht so versiert bin, habe ich es vom FOH machen lassen.
Dies kostete mich 51,50€
Die Gesamtkosten der Reperatur beträgt: ...trommelwirbel
815,40€ :eek: :(
letztendlich muss man sagen, dass es immernoch günstiger ist als ein Austauschgerät.
Der Nachteil bei der Reperatur ist, dass es mindestens 2-3 Wochen dauert, die man ohne Radio verbringen muss.
Ich hoffe ich konnte euch bei der Entscheidungsfindung helfen und verbleibe
Mit besten Grüßen...
Kannst du vor dem Einbau noch ein Foto ...
Bitte waaaaas? :confused:
Sorry so Versiert bin ich nicht... :rolleyes: ;)
Gruß aus Flensburg
hier mal eine kurze Zwischenfrage...
Ich habe nun einige Male versucht auf meinem Navi 600 die 900 Firmware zu installieren. Dazu habe ich verschiedene Firmwares getestet (Carbon, Red und was es alles nicht so gibt) das Ergebnis war immer das die neue Firmware installiert und erkannt wurde, schon mal positiv.
ABER! Ich habe danach nie die Extras des 900er Navi (3d, Fahrtenbuch etc.) geschweige denn eine Veränderung des Designs! Sprich lade ich eine Firmware mit Carbon Design, zeigt das Navi die erfolgreiche Installation und die neue Firmware an, aber an den Funktionen und dem Design ändert sich nichts! Woran mag das liegen?
@ zappoBHV
Das habe ich auch auch die 3d Navigation des 900 ters wird bei mir nicht angezeigt es sieht wie früher aus.
Hat noch jemand die Dateien unten?
Die ISO kann ich herunterladen, aber die USB-Dateien leider nicht mehr. Wäre nett wenn mir die jemand senden könnte. Danke!
@pegasusjan schrieb am 7. Oktober 2013 um 15:26:42 Uhr:
Habe gelesen on
You need:-
* A blank CDR
Sie auch :
Grüßen aus Holland
ich hab die files noch, wenn du mir eine pm mit emailadresse schickst, lade ich sie bei "wetransfer" hoch und du kannst sie dort abholen.
@enrgy schrieb am 14. November 2017 um 09:13:37 Uhr:
Könntest du mir bitte auch die Files zum Updaten bzw flaschen des Navi 600 schicken.
Hast du auch die File für das rote Desgin der Bedienoberfläche oder ist die dann schon dabei ?
MFG Erlacher
Hallo zusammen, kann mir jemand die zweite Datei zukommen lassen. Denn leider funktioniert der Link nicht mehr!!
LG
Moin nochmal,
bei mir klappt soweit auch alles. Ich war am Anfang skeptisch über die Themes. Kann ich diese im Nachhinein noch importieren?
Wenn ja, muss ich den gesamten Flash-Vorgang erneut durchführen inkl. Themes oder kann ich die Themes einzeln einspielen?
Wäre nett, wenn mir jemand eine kurze Beschreibung erstellen könnte.
Hi @all, kann mir auch jemand die zweite Datei zukommen lassen?
Danke im Voraus
Lg
@Tribalmike schrieb am 7. Oktober 2013 um 22:37:43 Uhr:
Ich habe es gerade nach Anleitung Cruze Forum gemacht .....alles prima und 3d...
für die Sprachsteuerung fehlt wohl das 2 Micro!!! sonst geht alles
Gruß MK
Ich habe einen Opel Mokka mit einer SD Karte Navi 600 drin. Da es zu.B. nicht viele Straßennamen drin hatte wollte ich ein aktuelles und habe mir bei Amazon eine SD Karte mit Navi 900 gekauft. Ich kann aber keine große Verbesserung feststellen. Hier schreiben aber viele was das 900 können müßte, z.B. Blitzerwarner, 3D usw. . Deshalb würde ich versuchen meine alte Karte zu aktualisieren. Ich habe von so etwas aber wenig Ahnung ?? könntest du mir vielleicht den Link und eine kurze Anleitung in Deutsch schicken?
Gruß Steffi
Gruß Steffi
Hast du dir eine neue SD Karte mit Europakarte für des Navi 900 gekauft?
Die funktioniert auch auf dem 600er, aber enthält natürlich nur die Strassenkarten.
Wenn dir nun manche Strassen fehlen, dann nützt dir ein Upgrade deines Navi 600 auf 900 nichts.
Damit rüstet man nur die 3D-Ansicht und den Poi-Warner nach.
Aber Vorsicht:
Ich habe schon von einigen kaputtgeflashten Geräten gehört, steht auch hier im Thread.
Die 900er Karte bringt dir im Navi 600 ohne flashen ganz Europa statt nur D. Dafür fehlen dann die kleinen Gassen und Straßen. Die Karte für D ist detaillierter, aber eben nur für D ... ;)
