- Passat
- Passat B6
- ABS 3AA614109AG in Passat B6
I want to share with you the wonderful news. I managed to install pack abs from Passat B7 Passat B6 in.
For what it's done:
1 Buttons handbrake now works as a Passat B7.
2 Perhaps enable electronic differential lock XDS.
3 You can set a full-Park Assist 2.0 + OPS 360.
Here are a few photos how it works.
http://data.motor-talk.de/.../2c75fccs-960-3308177035041247224.jpg
http://data.motor-talk.de/.../dab5fccs-960-7761245703361303768.jpg
Later add video
Ok, to sum it up. You figured out, that it's possible with a simple type of coding - but you don't provide it. Ok, thank you.
126 Antworten
PD - TDI, 2008; BMP
Handbrake:
Adresse 53: Feststellbremse Labeldatei: DRV\3AA-907-801.clb
Teilenummer SW: 3AA 907 801 H HW: 3AA 907 801 E
Bauteil: J540 EPB4 VW-86594 0010
Revision: H18 Seriennummer: 00000000322302
Codierung: 0021057
Betriebsnr.: WSC 12345 123 45725
VCID: 3668B4F341094F8EB7-8062
Need the scan machine
Adresse 01: Motorelektronik Labeldatei: DRV\03G-906-021-BMM.clb
Teilenummer SW: 03G 906 021 NK HW: 03G 906 021 AB
Bauteil: R4 2,0L EDC G001SG 9972
Revision: --H07--- Seriennummer: VWZCZ000000000
Codierung: 0000072
Betriebsnr.: WSC 12345 123 07412
All blocks
What shift transmission?
@46otdmil schrieb am 6. Februar 2016 um 11:34:46 Uhr:
As there is no 02 in the scan, it has to be manual.
Starting code abs 176
ich kann es erst codieren wenn ich die b7 mittelkonsole und den b7 epb schalter verbaut habe
danke für die codierung
Hello everyone I have this error abs b7
vcds with him then delete reappears
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 Q HW: 3AA 614 109 Q
Component: J104 C2 450M VE5D 0011
Revision: --H07--- Serial number: 00000003237673
Coding: 0117168
Shop #: WSC 05311 000 00000
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 149095 km
Time Indication: 0
Date: 2018.14.29
Time: 21:01:21
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 307
Hex Value: 0x0000
Ich möchte auch die elek. Vom Abs einbauen, ich habedie vom b6 mit AG und wollte die vom b7 mit AG einbauen.
Mal sehen ob es geht ohne die Abs Einheit auszubauen,.
Geht nicht
das sind doch zwei verschiedene ABS-Blocke, die nicht mal annähernd gleich sind. Bin gespannt, wie du das realisieren möchtest :-)
