Relais und solid state relais für Fahrzeug Elektrik
Databytes gives you essential insights to help you to improve your data analysis skills each month, as Cosworth’s electronics engineers share tips and tweaks learned from years of experience with data systems.
Pulse Width Modulation setup
Using relays to manage power consumption
Last month’s article looked at Pulse Width Modulation, and how PWM could be implemented, technically, on a PWM compatible power device. This month we will look at how a system must be configured, practically, in order to implement PWM. This will include a brief look at current
demands, and how relays can be used to manage devices with high power consumption.
In order for any electric power consuming device to operate, it requires a potential difference across it, or voltage. This is usually made up of a positive voltage supply, either directly from the battery or an output from another vehicle device, and a negative connection such as chassis ground, a low-level voltage or ground output from an on-board device. This is a basic fundamental of any electronic device and one which is central to motorsport wiring harness design when it comes to power consumers.
When wishing to control a device via PWM, these basic principles are still followed by modulating either the positive or negative side of the
device. This means that the potential difference across it also modulates, which gives the desired response. From a principle perspective this may seem very basic, but in order to implement correctly in practice there are some areas which may need some care.
Direct versus relay
Four examples will be given for driving a device with PWM. The first two of these are basic, with direct connection of the PWM signal to the load device, and the second two include the implementation of a relay to drive a device.
The first example, as shown in Figure 1, is a schematic of how a device could be driven using a high side PWM output from a PWM-enabled device. In this simple configuration, the low side of the load device is fixed to chassis ground while the high side of the load device is modulated by the PWMenabled device.
The second example, shown in Figure 2, shows how a device could be connected when driving directly from a low side PWM output. In this example, the high side of the device is connected directly to the battery and the low side is modulated from the PWM device.
Both of these examples would give the same response from the device, provided the PWM is configured in the same way. The only difference is one switches to a high level (high side) and one switches to a low level (low side). This, in principle, works well. However, in these cases all of the power which is being consumed by the load device is also being fed into the PWM-enabled device. For low current applications or devices with high power capable PWM outputs, this is acceptable. However, when driving a 10Amp Fan from a 1Amp PWM pin these schematics are ot
appropriate. It is these instances where a relay is required.
Relays are commonly used throughout electrical power systems and in short, they allow switching of high current circuits, with a low current input. There are two types of relay which will be discussed – a mechanical relay and a solid state relay, as shown in Figure 3.
A mechanical relay uses a low current circuit to induce a magnetic field, which then closes a mechanical switch of a high current circuit. A solid state relay is essentially the same, but uses more intelligent circuitry in order to close the high current switch, depending on the logic state of the low current switch.
The choice of relay used needs to be considered depending on the application. Mechanical relays are inexpensive and only need basic wiring, however they have slower switching times when compared to the more expensive, faster switching solid state relays. For use with a PWM application, which is a fast modulating signal, solid state relays are the more common choice as they can respond fast enough.
Most commonly, relays can be used to switch the high side of a device. However, there are relays which are capable of switching the low side as well. The principles for both remain the same.
Figure 4 and Figure 5 show how PWM can be implemented with the integration of a relay to drive a high current load device, even if the PWM current capability is low. Note how the load device high side supply comes from the relay in both instances, with the PWM high side or low side determining which side of the low current side of the relay is modulated. If the relay is used to switch the low side of the device, the schematics would be similar. However, instead of high power in of the relay connected to the battery’s positive terminal, it would be linked to ground, and the high power out would be linked to the low side of the load device. The positive side of the load device would then be linked to the battery’s positive terminal.
Last month’s article gave a software and theoretical overview of PWM, and combining this with the practical information provided in this month’s article, configuring and implementing a PWM-driven load device on a racing car should now be possible.
Figure01
Figure02
Figure03
+2
4 Antworten
Kompliziert geschrieben aber schön erklärt wozu ein Relais gut ist.
Ich habe noch keine solid state relays fürs Auto gefunden. Das würde mein klacken vom Blinker durch die Umrüstung entfernen. Hast Du dazu schon eine Adresse gefunden?
Dir ist klar, dass es hier in dem Artikel um das schalten und steuern mit PWM-Signalen ging?
Da du gerade fragtest und ich dir spontan keine Werbung oder Hersteller verlinken konnte. Einfach mal bei Autospeed geschaut, und Julian Edgar hat natürlich schon vor langer Zeit einen Artikel mit Bauteilbeschreibung darüber geschrieben
Using Solid State Relays
Lets you do new things
by Julian Edgar
Relays have been around since the year dot, but solid state (ie electronic) relays are much newer devices. They don’t have any moving parts that can wear out, can be triggered by tiny currents but can in turn switch enormous currents, and can be tweaked to do quite a few interesting things.
Let’s take a look.
Traditional Relays
A relay is simply a remote-triggered switch. Traditional relays use a set of switching contacts and an electromagnet. When power is applied to the coil of the electromagnet, the contacts are physically pulled across, closing the switch.
Fig01
Using Relays is a good grounding in relays and their automotive uses.
Traditional relays suffer from two problems. The first is that the more heavy duty a relay is (that is, the more current it can switch), the greater the current that’s drawn by the coil. This is because the switch contacts need to be larger (and so heavier), and the contacts need to be closed with force. These aspects require a strong electromagnet that draws higher currents.
The second disadvantage is that traditional relays wear out. The contacts tend to arc (especially when opening) and the contact faces get pitted. The more operations they perform, the faster they wear out.
However, a relay is a cheap and effective device, one which because of the variety of switch contacts that are available, can also be very versatile.
Electronic Relays
An electronic relay uses a big switching transistor to replace the mechanically moving contacts of a traditional relay. This means that an electronic relay will never wear out – nothing is moving. (Incidentally, the switching transistor is known as a MOSFET.)
Fig02
In addition to never wearing out, an electronic relay can potentially switch very large currents. When equipped with a suitable heatsink, the relay shown here can handle 100 amps continuously and cope with a very short term switch-on current gulp of 240 amps. Those are huge numbers.
Electronic relays can be triggered with extremely small currents – for example, 20 milliamps. With traditional relays, only very light duty units have such low coil currents. The very low operating current has major advantages that we’ll come to in a moment.
Finally, an electronic relay can be pulsed very fast. Nope, we’re not talking about just switching on and off a few times a second, but instead being pulsed hundreds of times per second. In applications like motor speed control and light dimming, and injector/solenoid operation, this has major positives.
Jaycar SY4086
Das gleiche Relay das is dem Cosworth Artikel oben zu sehen war
he Jaycar SY4086 solid state relay costs about AUD$40. (Oh yes – that’s a disadvantage; electronic relays cost more than mechanical relays!) It’s made by Hongfa Relay and its data sheet can be downloaded by following the link at the end of this story.
The relay has four connections. The ones marked ‘input’ are connected to power (anything from 3 to 32 volts DC) to switch the relay on. Note that these connections are polarity conscious – positive must go to positive and negative to the car’s chassis or negative terminal of the battery.
The other end of the relay is the output – you can treat these terminals as the two connections of a switch (although note that the terminals are again polarised.)
Here is the relay wiring. In this diagram the relay is operated by a switch. Close the switch and power is applied to the left hand end of the relay – what in a mechanical relay would be the coil connections. This switches the relay on, so allowing current to flow to the load (the load could be a lamp, pump, motor, etc).
Fig03
Here’s the same diagram but in this case the one power supply feeds the relay the juice needed to switch it on and also powers the load.
Fig04
Finally, the electronic relay can be switched on and off by another electronic module – if the module outputs any voltage between 3-32V DC, it can be used to switch the electronic relay.
Fig05
Uses
  • Replacing Traditional Relays
The most obvious use of an electronic relay is to replace a traditional relay. However, in most automotive cases this isn’t worth doing. To replace existing relays, much rewiring will be need to be done and unless the existing relays are being used in an application that is causing them problems, no real benefits will occur.
However, there are some cases where it would still be a positive. For example, in a car using really high powered driving lights, and where the lights are switched on and off a lot, traditional relays may have a short life. The electronic relay would then be a good upgrade.
  • Triggering From Small Currents
A better use is to use the electronic relay where only a small switch-on current is available.
For example, sensitive pressure switches, micro-switches and many temperature switches are rated for very low currents. But because of the low current draw of the electronic relay, these switches can be used without problems.
Existing switches such as radiator temperature switches and oil pressure switches can also be used without problems.
Pretty well any warning light or LED can be used to additionally trigger the relay – the relay’s input connections are simply wired in parallel with the LED or warning light (use a multimeter to check the polarity of the power feed to the light or LED.)
  • Using an Electronic Module
If an electronic module has a pulsed output but cannot handle the load current, the electronic relay can be used to increase the capability of the module. For example, the The Nitrous Fuel Controller is a very cheap kit that can be used to:
  • pulse injectors
  • dim filament lights
  • control the speed of motors
  • pulse lights or horns
However, the output transistor of this module is limited to 10 amps. That’s a fair bit but not enough current to speed control big motors like radiator fans or fuel pumps, or happily pulse multiple car horns (eg as an alarm indication). But by using this module to trigger the electronic relay, each of these uses becomes possible.
However, note that there’s a trick to it. Rather than outputting 12V when the Nitrous Fuel Controller’s output is switched on, this module connects to ground when switched on. Therefore,
the module connects to the ground line of the relay input rather than the positive side of the input.
(The new range of pre-built electronic modules that we’ll be covering soon will use the electronic relay in the same way – allowing the control of very large currents.)
Fig06
  • Adding a Delay
If more than a tiny current is available to trigger the relay, it’s very easy to add an extended ‘on’ time to the relay’s operation. This could be useful if for example an intercooler water spray is being operated by a pressbutton switch – you push the switch and release it and the spray continues for (say) 10 seconds.
Fig07
To achieve the extended ‘on’ time, all that’s required is a capacitor wired across the input side of the relay. A 4700uF, 25V cap, for example, extends the ‘on’ time for about 7 seconds. To increase the delay, increase the capacitance. These capacitors are polarised, so make sure that the negative lead of the cap (shown by a line of minus symbols on its body) goes to the negative connection of the relay input and the positive side goes to the positive relay input. Cost of such a capacitor is only about $2.
Inductive Loads
There’s one other thing to keep in mind when using an electronic relay.
On inductive loads (eg those with coils like solenoids, injectors, motors and horns) a big voltage spike is produced when the power is turned off. To protect the relay, a diode (eg 1N4004) should be wired across the load, band on the diode towards the negative side of the relay output.
Heatsinking
When working at very high current levels, the electronic relay covered in this story requires heatsinking.
As this graph (taken from the data sheet) shows, at up to 40 degrees C ambient the relay can handle 25 amps continuously. At higher ambient temps (like found in an engine bay, for example!), the relay is de-rated.
If high currents need to be handled, bolt the relay to a large heatsink (using thermal grease between the heatsink and the metal back of the relay) and check that the relay does not exceed 40 degrees C in operation.
Fig08
Conclusion
In many cases traditional relays are still the best pick for the job. These applications include those where multiple switching contacts are required, cost is a factor and switched currents are small. But where large currents need to be handled, only very small currents are available to energise the relay, or where delayed ‘on’ times or high speed pulsing are required, the electronic relay is unbeatable.
Download the Jaycar SY4086 data sheet hereHFS33_en.pdf
Fig01
Fig02
Fig03
+5
@falloutboy schrieb am 17. März 2015 um 15:32:54 Uhr:
Ja habe ich schon. Aber im Grundsatz beschreibt der Artikel für mich die Relais Steuerung.
Habe den Artikel bei Autospeed gefunden.
http://www.autospeed.com/cms/article.html?...
Danke! Bitte weitermachen.
Korrekt, ein SS-Relay ist im Prinzip auch nichts anderes als ein Relay, deswegen wirds ja auch so genannt. 🙂
Nur wirst du kein Steuergerät oder ähnliches mit nem normalen Relais steuern können, wenn du schnelle Signaländerungen hast. Deswegen der Einsatz der SS Relais weil sie dank der kürzeren Schaltzeit in der Lage sind höhere Frequenzen abzubilden, wobei sie gleichzeitig in der Lage sind hohe Dauerströme (~100A) bei niedrigen Schaltströmen (~ 24mA) und über einen breites Spektrum an Spannungen (3 - 32V DC) zu bedienen.
