  3. English-Talk
  4. SVM 8K0919475R 0070 Control Unit
Audi
Hello,
I have the following graphical 8 sensor back up camera control unit
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Proposed firmware update:
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
I need the SVM. Does anyone have such information??
Cheers
33 Antworten
I found the information which was missing in Ross Tech
10 = Aui Q5 (8R)
So the 6c back up camera coding is 1020010.
Will test tomorrow and report 🙂
@spuerer schrieb am 20. Juni 2017 um 23:36:57 Uhr:
VCDS Update!
pdc unit needs no .rod file, your label files are not correct.
and...
the newest update for PDC unit is 0082 Index AA 😉
Thank you
I have updated PDC firmware successfully to 8K0919475AA 0082 (from previous 8K0919475R) as you suggested. You were right that firmware is compatible. So I assume that PDC with suffix G, R, and AA are the same in harware
I could still not code my aftermarket back up camera control unit or enable radar graphical distance to display on smaller car picture even with PDC update. Disconnecting the camera contol unit radar works.
Only hope radio concert 0350 firmware, if someone could share this, and/or changing gateway from AF to AG or facelift gateway (if it is not AG)??
Just a small correction of the following which did not make any sense.
"I could still not have my PDC update. Disconnecting the camera contol unit radarworks."
TO:
Radar to display on camera, still does not function, even if, PDC was updated.
Need to test a different can-h can-l connection. Cables to be connected directly to gateway (pins 5 15) rather than CAN-BUS brown plug.
@spuerer schrieb am 16. Juni 2017 um 22:48:47 Uhr:
die optische Anzeige ist doch beim 8Kanal-Steuergerät bereits vorhanden.
SVM-code für Update: 10A001 (für was der TE das auch immer benötigt...)
This is the correct SVM. Found the TPIs so I am giving a correction.
SVM 10A003 (unless there are more than one)
TPI 2028503/4
TPI 2025502/4
