VCDS Fehlercode ?
kann mir jemand folgende Fehlercodes entschlüsseln?
Kann das von einer leeren/defekten Batterie kommen?
Wenn nicht, bitte ich um Hilfe und Einschätzung von den Profis hier ;)
Danke VG
Address 01: Engine (J623-CGQB) Labels: None
Part No SW: 4G0 907 589 G HW: 4G0 907 589
Component: 3.0BTD EDC17 X24 0003
Revision: 57X24---
Coding:
Shop #:
ASAM Dataset: EV_ECM30BTD0114G0907589G 001003
ROD: N/A
VCID:
No ASAM data for: "EV_" (AU57)
2 Faults Found:
4528 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 332609 km
Date: 2024.03.27
Time: 08:04:19
4532 - ROD - Unknown Error Code
- 00 [047]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 332606 km
Date: 2024.03.27
Time: 07:55:57
Readiness: 0 0 0 0 0
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0076
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 63C5198D6A55BF52A8-8036
3 Faults Found:
0237 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 332606 km
Date: 2024.03.27
Time: 07:55:54
Voltage terminal 30: 12.04 V
Outside air temperature: 14.5 °C
Engine speed: 0 /min
0291 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 249
Mileage: 332606 km
Date: 2024.03.27
Time: 07:55:54
Terminal 15 status: Terminal 15 on
0314 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 249
Mileage: 332606 km
Date: 2024.03.27
Time: 07:55:54
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number:
Coding: 0907A01109749FE2898100C0A0001800CF9CE7082E080201000108546F01
Shop #: WSC 02391 785 00200
VCID: 6FED65BDBE9D0B323C-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 121106 H36 0080
Serial number: 121119221220
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20839260
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 03 01 2013 00000979
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000007121200010563
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000003121200010096
Coding: 110000
1 Fault Found:
03608 - Humidity Sensor in Fresh Air Intake Duct
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 249
Mileage: 332606 km
Time Indication: 0
Date: 2024.03.27
Time: 07:55:00
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0400
Serial number:
Coding: 7D04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285F4EA153F31C0ABD-807C
1 Fault Found:
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 34
Mileage: 332606 km
Date: 2024.03.27
Time: 07:55:55
Control Module temperature: 25 °C
Voltage terminal 15: 12.031 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000773192
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 71E963C5A0A91DC22A-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001050750297
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1209220000000000010F
1 Fault Found:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 332614 km
Date: 2024.04.12
Time: 19:21:17
Voltage terminal 30: 11.7 V
Voltage terminal 15: 0.0 V
Control Module temperature: 20 °C
System status: Awake_Timer_active
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H33 0433
Revision: 00002001 Serial number: 0300004664
Coding: 0100062020B93094832009842E010F0F0000000000000000000000000000
VCID: 7
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Serial number: WOO19089528
Coding: 901F00
Subsystem 2 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00002419367
Coding: 010000
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Serial number: WOO19089034
Coding: 801F00
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 332611 km
Time Indication: 0
Date: 2024.03.27
Time: 08:06:41
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 33
Mileage: 332611 km
Time Indication: 0
Date: 2024.03.27
Time: 08:07:13
17 Antworten
Stell VCDS doch auf Deutsch um.
Möglich wäre es.
Batterie laden und Fehlerspeicher löschen un neu lesen
Es geht nicht um die Sprache es geht darum das dort Sachen stehen wie
U1113 00 [008] - -
und vorallem bei Engine
2 Faults Found:
- 00 [032]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 332609 km
Date: 2024.03.27
Time: 08:04:19
Kann jemand was anhand der Informationen herausfinden was gemeint ist?
wieso ist das denn alles in Englisch, hast du einen billigen China Nachbau im Gebrauch, also ein Plagiat?
Alter was habt ihr mit eurem scheiß Englisch?
Es geht mir um die Fehlercodes, die ich nicht zuordnen kann.
Ich kann es für euch ins deutsche übersetzen, wenn es dann einfacher wird.
mein Schulenglisch aus den 70ern ist nicht geeignet, um englische Fehlertexte lesen und verstehen zu können. Da nicht selten Plagiate hinter den englischen Texten stecken habe ich nachgefragt. Da du darauf nicht antwortest, denke ich mir meinen Teil.
Der Ton läßt sehr zu wünschen übrig
wessen?
Des Themenstarters
Es soll ja Menschen geben ,die bereit sind zu helfen,aber dem Englischen nicht so mächtig sind wie andere.
Für die wird es dann schwierig zu helfen
genau, das sollte man dann auch so sagen. Auch @Atomickeins hätte sich angesprochen fühlen können.
Ich nehme an @Atomickeins wird sich noch melden,der ist immer am Start :)
ja, ich bin noch da :D, aber wenn der TE in dem Stil weiter macht nicht mehr lange.
Dieser Spruch vom TE hat mich allerdings dazu bewogen, meine Hilfsbereitschaft in seiner Angelegenheit zu überdenken.
Mal schauen, wie es hier weitergeht.
Die ROD Dateien der VCDS Version passen garnicht ...
4528 - 4532 könnte Kühlerlüfteransteuerung sein, kommt selten von einer schwachen Batterie ...
Die Muttersprache von VCDS ist eigentlich Englisch ;-), das mal auf Deutsch übersetzt wurde.
Aber kein Problem, es sind etliche Fehler vorhanden. Für den besseren Überblick habe ich die nicht relevanten Infos in den tar pit versenkt (Teergrube wird gerne in Linux verwendet, um die nicht erwünschten automatisierten Anfragen zu versenken).
2 Faults Found:
- 00 [032]
- 00 [047]
3 Faults Found:
U1111 00 [009] - -
U1111 00 [009] - -
U1111 00 [009] - -
1 Fault Found:
1 Fault Found:
U1113 00 [008] - -
1 Fault Found:
2 Faults Found:
Hier gibt es einiges zu tun.
In der "Computer-Fremdsprache" ;-) bedeuten diese Fehler:
Address 01: Motorsteuergerät
unbekannter Fehler (dürfte an einer veralteten VCDS-Version liegen, wenn Fehler nicht angezeigt wird).
Address 08: Klima
Wird nur "Funktion ist eingeschränkt" angezeigt.
Hier fehlen die erweiterten UDS-Fehlerdetails, da eine alte Version von VCDS verwendet wird.
Könnte man mit einer neueren VCDS-Version anzeigen lassen.
Rosstech schreibt dazu: (aus dem Englischen übersetzt)
Ältere Versionen hatten die "erweiterten UDS-Fehlerdetails" überhaupt nicht.
Ich weiß nicht mehr genau, in welcher Version sie hinzugefügt wurde, aber es war auf jeden Fall, nachdem das ältere HEX+CAN eingestellt worden war und wir uns dafür entschieden hatten, sie nur für aktuelle Schnittstellen zu implementieren.
Quelle:
https://forums.ross-tech.com/index.php?threads/21244/
Address 09: Zentralelektrik
kein Signal Luftfeuchtigkeitssensor im Frischlufteinlasskanal
Address 13: Automatische Abstandsregelung
Funktionseinschränkung aufgrund von Fehlern in anderen Modulen
Hier fehlen ebenfalls die erweiterten UDS-Fehlerdetails aufgrund alte VCDS-Version.
Optischer Datenbus
Offener Stromkreis
Adress 46: Komfortsystem
Kraftstofftankdeckel Schloss sperren
Offen oder Kurzschluss gegen Masse
Seltsamer Thread, ich habe lange überlegt, ob ich Popcorn hole oder was sage…
Repariere Deinen Feuchtigkeitssensor im Einlasskanal (Adresse 09), dann wird vermutlich die Klimaanlage ruhig (Adresse 08). Deinen Tankdeckelverschluss kannst Du machen oder so lassen (Adresse 46)
Kümmern würde ich mich um den optischen Bus (Adresse 19), es könnte sein, dass dann das ACC den Mund hält (Adresse 13).
Was im Motorsteuergerät (Adresse 01) los ist, kriegst Du so nicht raus, da gibt es im Netz wenig Infos zu den Fehlercodes, auslesen mit einem frischen originalen VCDS könnte helfen.
