ForumPassat B6
  4. Volkswagen
  5. Passat
  6. Passat B6
  7. how to open a car with a discharged battery
VW Passat 3CC
Themenstarteram 24. November 2020 um 0:44
Hi everbody, my problem is that i have dead battery in the car. how do I open the door when the window doesn't go down?I used to key to the door but the window does not go down as mam further progress what is the solution only break the window? please no:( passat cc battery is in trunk.
Thank you so much sorry for my language but i cant speak germany so sorry but im very sad...passat cc
8 Antworten
you have a mechanical key at (in) your regular key. Remove the cap from the drivers door handle. Can be, that you have to turn the lock with some continuous pressure, as the mechanic will move slowly. And first you habe to find out the direction cw or ccw, I never remember that.
For safety reasons you could place a cable connector somewhere outside. I have that, primarily to easily charge the car battery without open bonnet.
Themenstarteram 24. November 2020 um 9:30
@Orlando78 schrieb am 24. November 2020 um 08:28:54 Uhr:
https://m.youtube.com/watch?v=weS_LpkaZy0
https://m.youtube.com/watch?v=1VNArTQUg5M
https://m.youtube.com/watch?v=5Q1M4Hg6XbQ
thank you for the videos I used the boy but on passat cc the window goes down so you can open the door
Themenstarteram 24. November 2020 um 9:31
@Bnuu schrieb am 24. November 2020 um 03:59:45 Uhr:
thank you for the videos I used the key mecanical but on passat cc the window goes down so you can open the door
@marcel6661 schrieb am 24. November 2020 um 09:30:37 Uhr:
pull the door, nothing will happen
You have to get the car 12V via trailer hitch, if your car hase one! PIN 9 is 12v Klemme 30, and PIN 3 is Ground!
@marcel6661 schrieb am 24. November 2020 um 09:31:11 Uhr:
nothing will happen with the windows, you unlock mechanical with the key and then pulling the handle to open the door
but turning is tricky, feels close to break the key at my B7. bring in strength and keep the force constant, the key turns slowly forward, IIRC close to 90 degrees - open
I do not remember the direction.
  4. Volkswagen
  5. Passat
  6. Passat B6
