ForumEnglish-Talk
  3. Dialog
  4. English-Talk
  5. Dynamische Richtungsanzeige/Dynamic direction display
Audi
Themenstarteram 9. November 2019 um 22:22
This is a question from Japan. Help me.
MY2016TTS used car was purchased around May 2019, and it was a matrix LED, but the front and rear were not dynamic blinkers.
I showed it to the dealer, but it was a reply that I didn't understand.
The former one is purchased in Audi in Osaka, so I think it is domestic sales.
I suspect it might be coding, but what about it?
Thank you.
I use OBDeleven PRO.
Where do you see it?
8 Antworten
Can you post a scan of the vehicle?
I suspect though that if the car doesn't have dynamic indicators the hardware fitted does simply not support it.
Themenstarteram 11. November 2019 um 7:13
Vielen Dank für Ihre Antwort.
Es ist Nachschrift. Dieses Fahrzeug ist eine Matrix-LED.
Ich weiß nicht, ob dieser Anhang in Ordnung ist.
Bitte geben Sie an, ob es anders ist.
???????????????LED???
You can have Matrix lights but this does not have to do with dynamic indicators necessarily.
I'll post an example of a scan I mean!
Code:
Tuesday,31,January,2017,16:47:14:14667
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170127 DS267.1
www.Ross-Tech.com
VIN: WVWZZZAUZHW051XXX License Plate:
Mileage: km-mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZHW051XXX Mileage: km-miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUNA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 BS HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1541
Revision: B5H23---
Coding: 011D0012036505083000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
ROD: EV_ECM20TDI011_AU37.rod
VCID:
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 042 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4903
Revision: 06354004 Serial number:
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID:
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number:
Coding: 01FA8AA13425096D477D060241C52980512C90E26082947518625078C20903
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
VCID:
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number:
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002019
ROD: EV_KessyHellaMQBAB_002.rod
VCID:
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00120104202110011005004000101022
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID:
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
1 Fault Found:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 14517 km
Date: 2017.01.26
Time: 20:30:23
Voltage terminal 30: 13.8 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.value: 2
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number:
Coding: 03011A46C24122FB0BA44080B11C07281800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_016_AU37.rod
VCID:
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160702 042 0551
Serial number:
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number:
Coding: 90A8DD
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number:
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number:
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number:
Coding: 0071051011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID:
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500478151FFC428949C8045000006
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
VCID:
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
4 Faults Found:
0836 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 176
Reset counter: 153
Mileage: 5870 km
Date: 2016.12.09
Time: 09:17:18
1127 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 10748 km
Date: 2017.01.05
Time: 15:05:29
1218 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 10748 km
Date: 2017.01.05
Time: 15:05:29
1219 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 10748 km
Date: 2017.01.05
Time: 15:05:29
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number:
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID:
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number:
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number:
Coding: 333135
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 001 607 16
Component: SideSensor_Df 001 0887
Serial number:
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 001 607 16
Component: SideSensor_Pf 001 0887
Serial number:
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 401 207 16
Component: SideSensor_Dr 001 6149
Serial number:
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 16
Component: SideSensor_Pr 001 6149
Serial number:
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 401 807 16
Component: FrontSensor_D 001 6149
Serial number:
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Coding: 0410
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_SK48.rod
VCID:
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G1 920 957 B HW: 5G1 920 957 B
Component: KOMBI 304 8311
Coding: 27AD09182F80260001887F011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID:
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Coding: 030100041F086800FB00027E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID:
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number:
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number:
1 Fault Found:
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 13826 km
Date: 2017.01.19
Time: 20:43:16
Supply voltage: Terminal 30: 12.8 V
Terminal 15: OFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_SK25.rod
VCID:
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number:
Coding: 001F1220D001048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID:
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_DRV 005 0005
Serial number:
Coding: 0D0000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID:
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number:
Coding: 001F1020DE01048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID:
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_PSG 005 0005
Serial number:
Coding: 150000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 029E01000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID:
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Serial number:
Coding: 02730001FF00000051110101008808001F0202C601200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID:
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H53 1031
Serial number:
Data medium:
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Serial number:
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number:
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID:
End-------------------------(Elapsed Time: 04:39)--------------------------
Themenstarteram 11. November 2019 um 11:10
Ich werde HEX-V2 kaufen.
Ich denke es wird ein paar Tage dauern.
No worries, just le me know.
Themenstarteram 23. Dezember 2019 um 9:37
Almost
Themenstarteram 23. Dezember 2019 um 9:39
Fast
Themenstarteram 27. Dezember 2019 um 10:17
Friday,27,December,2019,13:39:09:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: TRUZZZFV800000000 License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 42 44 47 52 55 57 5F
6C A5 A9
VIN: TRUZZZFV8XXXXXXXX Mileage: km-miles
08-Auto HVAC -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
47-Sound System -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CJXF) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 0A1D00322426050B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208S0906259B 001005
ROD: EV_ECM20TFS0208S0906259B.rod
VCID:
Readiness: 0000 0000
Part No SW: 0D9 300 013 D HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4904
Revision: 06253104 Serial number: TFK01511131302
Coding: 0014
Shop #: WSC 04742 780 00200
VCID:
Part No SW: 8S0 907 379 D HW: 8S0 907 379 D
Component: ESC H42 0522
Revision: 00000000 Serial number: 63295000000729
Coding: 24AA608D1A9B15AA409908680292970EA3240658A8021040E970C5
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID:
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number:
Coding: 030C0C1720
ASAM Dataset: EV_KessyHellaMQBAB 004032
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID:
Sensor Controlled Power Rear Lid:
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0030
Revision: 20009000 Serial number: 15250000009000
Coding: 410040140011141100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID:
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number:
Operating and display unit 1 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number:
Operating and display unit 2 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number:
Operating and display unit 3 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Serial number:
Operating and display unit 4 for air conditioning:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Serial number:
Operating and display unit 5 for air conditioning:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Serial number:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 BH HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number:
Coding: 07055E46C20106FD41044004001007A80080000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_015.rod
VCID:
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 151009 038 0371
Serial number:
Coding: 1BC7F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number:
Coding: 00005D
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number:
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Revision: -------- Serial number: 39391532700013
Coding: 0070150051
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID:
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number:
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID:
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number:
Coding: 88CCC0000C8000005C00000000C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X.rod
VCID:
Subsystem 1 - Part No SW: ----------- HW: 480 001 811 15
Serial number:
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 001 811 15
Serial number: 3580000000094999D71Y
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 012 311 15
Component: SideSensor_Dr 004 0108
Serial number: 351001A05673DAE23CDM
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 401 609 15
Serial number:
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 5 - Part No SW: ----------- HW: 480 401 609 15
Component: FrontSensor_P 001 6149
Serial number:
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 6 - Part No SW: ----------- HW: 480 400 210 15
Component: PedP_Sensor_C 001 6149
Serial number:
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 7 - Part No SW: ----------- HW: 480 001 611 15
Component: PedPSensor_D2 001 0887
Serial number:
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 8 - Part No SW: ----------- HW: 480 001 611 15
Component: PedPSensor_P2 001 0887
Serial number:
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8S0 907 129 AG HW: 8S0 907 129 AG
Component: Lenks. Modul H07 0140
Revision: -------- Serial number: 91335OL601198
Coding: 201C
ASAM Dataset: EV_SMLSKLOMQB 019002
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID:
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 A HW: 8S0 920 790 A
Component: FBenRDW H35 0265
Coding: 242D08403882000C0F21E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
ROD: EV_DashBoardBOSCHAU33X.rod
VCID:
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8S0 907 468 C HW: 8S0 907 468
Component: GW MQB TT3 012 0244
Revision: -------- Serial number: 15111510800592
Coding: 030100042F025A004B00026ABC0000000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 011003
ROD: EV_GatewContiAU33X_011.rod
VCID:
Alternator:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number:
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number:
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number:
Coding: 0101
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID:
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Serial number: 121015BJC05132
Coding: 001F53225C01040100001402
VCID:
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 397998E3B8599B87A0-806C
Address 47: Sound System (J525) Labels:* None
Part No SW: 8S0 035 465 C HW: 8S0 035 465
Component: MIB2_amp_P_TT H06 0240
Revision: 00000001 Serial number: AUZ8ZAFH70098U%
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID:
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Serial number: 161015BJF15821
Coding: 001F53225E01040100001402
VCID:
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 03E602202B100200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
VCID:
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01400
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01400
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01400
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01400
Matrix Headlamp Powermodule 1 Left:
Subsystem 5 - Part No SW: ----------- HW: -----------
Component: MxB LeiMo li. H05 S007
Coding: E01400
Matrix Headlamp Powermodule 1 Right:
Subsystem 6 - Part No SW: ----------- HW: -----------
Component: MxB LeiMo re. H05 S007
Coding: E01400
Address 57: TV Tuner (R78) Labels:* None
Part No SW: 8V0 919 129 D HW: 8V0 919 129 D
Component: JP-DTV H12 1930
Coding: 01041C0000000100000000
ASAM Dataset: EV_TVMELC 001039
ROD: EV_TVMELC_VW37.rod
VCID:
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8S0 035 034 M HW: 8S0 035 034 C
Component: MU-H-LN-JP 051 0037
Serial number:
Coding: 013354060000000011330002001200102F0000E2007000007E
ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
ROD: EV_MUHig6C3Gen2AW7_VW41.rod
VCID:
Data medium:
Subsystem 1 - Part No SW: V03 959 801 QD HW: -----------
Component: JPN 2018 --- 7910
Serial number: --------------------
Chip Card Reader Control Module:
Subsystem 2 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
Component: DSRC UNIT H08 0002
Serial number:
Traffic Data Aerial:
Subsystem 3 - Part No SW: 8V0 035 504 B HW: 8V0 035 504 B
Component: VICS Antenna H06 0001
Serial number:
Multimedia Operating Unit:
Subsystem 4 - Part No SW: 8S0 919 614 B HW: 8S0 919 614 B
Component: ControlUnit_H H22 0136
Serial number:
Compact Disc Database:
Subsystem 5 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2009
1 Fault Found:
2570 - Control Module for Smart Card Reader
B128F 31 [008] - No Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 188
Mileage:km
Date: 2019.12.27
Time: 13:19:11
Voltage terminal 30: 12.4 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 A HW: 5Q0 980 556
Component: RVC Compact H08 0172
Coding: 0233540102002001000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID:
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number:
Coding: 0000040000010305000501000000010100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID:
Part No SW: 8S0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number:
ROD: EV_SoundActuaGen2AU64X.rod
VCID:
End-------------------------(Elapsed Time: 05:32)--------------------------
  3. Dialog
  4. English-Talk
