ForumAstra J & Cascada
  4. Opel
  5. Astra, Cascada & Kadett
  6. Astra J & Cascada
  7. Von Navi 600 Navi 900 machen kostenlos
Opel Astra J
Themenstarteram 7. Oktober 2013 um 13:26
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 weitere Antworten
341 Antworten
am 20. März 2014 um 11:21
Nen gebrauchtes Navi 600 kostet im Internet ab 900€
Wenn du deins, Insofern es funktioniert, in dem Rahmen weg bekommst, könntest du etwa nem 1000er landen ja..
Soweit ich meinen FOH verstanden habe, kostet das Navi 600 rund 1600€
Beim Wechsel zum 900er oder zum Wechsel vom nicht- zum IntelliLink-Gerät ist ein anderes Steuergerät + Kabelbaum nötig (weitere Kosten) + Einbau + Programmierung + Friedenslösung
Freischaltung
am 21. März 2014 um 17:24
So, mein Update auf die aktuelle Version incl. Red-Theme verlief problemlos... :)
Mein update auch, merke aber bis auf die Farben keinerlei Unterschied.
Und genau das ist mein Problem, ich finde die Schrift extrem schwierig zu erkennen, Carbon Theme war Bombe von der Darstellung.
http://www.imgbox.de/show/img/AuTxoFNeU4.jpg
http://www.imgbox.de/show/img/pcBHN27gAP.jpg
http://www.imgbox.de/show/img/NntODOOYhq.jpg
http://www.imgbox.de/show/img/jaK6G0P6P9.jpg
Olli
am 28. März 2014 um 7:01
Was mich jetzt stört ist, dass die Sonderziel Warnung nur funktioniert wenn KEINE Navigation aktiv ist.
Bei mir steht ein Blitzer 200m hinter einer Kreuzung auf der ich aber links abbiege statt geradeaus zum Blitzer zu fahren.
Die Warnung kommt dort ohne Zielführung genau im Kreuzungsbereich - Navi kann ja auch nicht wissen das ich abbiege. Mit Zielführung kommt keine Warnung, da das Navi ja weiß das ich nicht an dem Blitzer vorbei komme sondern vorher abbiege.
Also eigentlich alles so wie es sein soll...
Nun mal die IDee zu einem Experiment. AAktiviere mal Deine typische Zielführung und fahre dann mal einfach geradeaus und lass uns Wissen wie schnell das Navi dann reagiert um Dir doch den blitzer an zu sagen :cool:
am 4. April 2014 um 9:58
Hallo zusammen
habe die Dateien herunter geladen und bin nach Anleitung durchgegangen.
Mein Problem: Alles wie vorher???
Erst von USB, dann die CD, alles duchgelaufen, Update erfolgreich stand dann da. Und nu is alles wie vorher?
Ich kann kein 3D auswählen, keine POIs, wie es hier beschreiben wird. Habe dann die Dateien für den Carbonstyle ausprobiert. Wieder wird alles auf dem Display durchgeführt. Aber imme rnoch alles wie vorher.
Was ist das Problem? Kann mir da einer helfen?
Danke schonmal...
am 4. April 2014 um 11:43
Original geschrieben von kleinaberfein
Hallo zusammen
Danke schonmal...
Bei mir ist es umgekehrt. Hab erfolgreich die Software aufgespielt und wollte nun mal versuchen die original Software draufzuspielen. Hab mir extra die neuste von FOH besorgt und aufgespielt. War auch erfolgreich, zeigt mir auch an, das ich die neusten Version drauf habe ( wie auf der CD angegeben ). Aber ich hab immer noch die 3D Ansicht und das Fahrtenbuch. Schon sehr merkwürdig!!
Oh man, jetzt verticken schon irgendwelche geschäftstüchtigen Typen die SW als Download oder auf Stick für bis zu 50,-€ in der Bucht. :rolleyes:
Wenn das nicht mal wegen Urheberrecht und so in die Hose geht ... ;)
am 14. April 2014 um 8:12
Scheint Opel nicht zu interessieren...
Original geschrieben von EFreak2014
Ich habe das Update erfolgreich durchgeführt.
Was mich jetzt stört ist, dass die Sonderziel Warnung nur funktioniert wenn KEINE Navigation aktiv ist. Also ohne aktive Routenführung.
Ist das bei Euch auch so? Kann man das Konfigurieren?
da ich das navi selten nutze, ist mir das bisher nicht aufgefallen. er meldet schön jeden morgen und abend die starenkästen auf dem weg zur arbeit. aber da ist das navi ja auch aus bzw. keine zielführung aktiv.
ich habe das dann gestern mal getestet und bei mir ist es genauso! was ein schei$$! habe auch noch keine einstellung gefunden, wo man da was ändern könnte...
so ist das natürlich ziemlich blöd, weil gerade dort, wo man sich nicht auskennt und sich leiten läßt, man auf die sonderzielehinweise angewiesen ist. dort wo ich kein navi nutze, kenne ich auch fast alle blitzer.
am 9. Mai 2014 um 6:57
auch ich habe erfolgreich den Sprung in 3D geschafft.
Nun habe ich zwei Fragen.
Hab die Links von der 1. Seite benutzt.
Sind die Blitzer POIs schon mit dabei?
Gibts einen zuverlässigen Link auf das Carbon Theme oder hätte ich dafür eine aktualisierte Version ziehen müssen wo diese integriert ist?
Danke schonmal!
bei meiner etwas hakeligen installation waren die pois nicht dabei. ich hab mir dann für´n 10er das abo bei scdb genommen.
aber obacht, teste das dann mal, ob bei eingeschaltetem routing auch wirklich blitzer gemeldet werden. bei mir und auch anderen scheint das nur zu funktionieren, wenn das navi aus ist (also kein ziel eingegeben wurde).
doch auch dieses verhalten ist nicht durchgängig vorhanden, ich habe mich letztens aus köln heraus leiten lassen und da wurden zu meiner verwunderung die blitzer trotzdem gemeldet. ein weiterer versuch brachte dann wieder das (erwartete) ergebnis ohne meldung.
Hab mich bei SCDB angemeldet und Kinos importiert.
Wollte dann mal testen ob die Blitzer zu sehen sind. Unter myPois zeigt er mir auch Standortdaten an. Wenn ich aber auf "Auf Karte zeigen" gehe, zeigt er kein Kamerasymbol an. Ist das normal?
Zeigt er das nur während der Fahrt in Echtzeit an? Alle anderen POIs kann ich auch so sehen.
Hab ich die Karte auf und navigiere per Steuerkreuz an Stellen wo ein Blitzer ist, sehe ich auch nichts.
Hab gelesen, dass einige das Problem hatten, aber keine Lösung gefunden.
hatte letzte woche wieder so einen effekt:
von der arbeit nach hause hab ich mich mal mit der hinterlegte heimatadresse leiten lassen, und siehe da, die blitzer wurden akustisch gemeldet. wähle ich manuell eine adresse aus über stadt/straße/nummer, passiert nix.
aber wiederholbar ist das wohl auch nicht, denn am nächsten tag auf gleicher strecke hat es wieder nicht geklappt.:confused:
andersherum wollte ich mal testen, ob er mir die schon serienmäßig vorhandenen pois meldet, also apotheke/bank/arzt etc. hab alle aktiviert und keiner wurde gemeldet. egal ob mit oder ohne zielführung.
ich sehe zwar das symbol für supermarkt/arzt etc, aber ich fahre dran vorbei ohne daß er piept. also so ganz koscher ist die sache nicht. ich hab allerdings auch nicht vor dem patch von 600 auf 900 getestet, ob da die pois gemeldet wurden.
Hat schon mal jemand getestet ob die dynamische Zielführung noch
Funktioniert z. B. wenn Stau ist und eine neu berechnete Route benutzt werden soll??
Hier soll angeblich die neue Route dann nicht ausgewählt werden können....??
Kann das jemand bestätigen?
Grüße irgendwie
